Question about Ace Hardware OAKBROOK COLLECTION DESIGNERS CHOICE TUB/SHOWER
I have oakbrook 48012 faucet, and i lost my manuel, i need to know if there is a water inhibitor for the flow of water
Slow water flow
I installed oakbrook tub and shower faucet 48011 and no hot water is coming out either side just water. What could be wrong?
If you have just water coming out you have not urned on the hot water valve that was turned off during install. check other faucet for hot . If you have hot there its not the hot water tank its the hot side valve.
Sep 30, 2015 | Home
How to remove cartridge from oakbrook shower faucet with 3 handles
You take off the handles, then the packing nut and you should see the valve stem and it unscrews all the way out. You can then look at the seal on the steam and the seat is in the valve. To change the seat, you need a special tool that fits in the fixture to twist the seat out.
Jun 12, 2015 | Ace Hardware OakBrook& Three Handle Tub...
We have a Grohe Lady Lux Plus kitchen faucet and the water flow is slow on both hot and cold sides. We took the faucet apart to see if there was trash impeding the flow and found nothing. We put the...
Take it back apart and check the placement of all the o-rings and or seals.
The low water pressure may be no more then the aerator being dirty where the water comes out of the spout.
Feb 05, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
I installed Series 26 Avalon faucet. The water flow rate is very slow. All fittings to the faucet are new. Could the problem be a faulty valve ?
Remove and clean the Price Pfister aerator. Turn the water on after you remove the aerator and check the flow-rate. Many new Lavatory and kitchen faucets are now equipped with Eco friendly water saver aerators. if the flow is normal without the aerator, the faucet is OK. if you want more water flow from your lavatory faucet, you will need to buy one of the old style high flow aerators from your hardware store. If you remove the aerator and still get low pressure from both hot and cold faucets, you may need to replace the faucet. Call the Price Pfister warranty phone number that came with your faucet.
Aug 28, 2010 | Price Pfister Plumbing
Slow water flow
first try and clean the air ratter where the water comes out the faucet it is a screen that un screws off the tip of the faucet. these can get clogged up over time from sediment and particles in the water. if the screen is fine then you can try and replace the supply lines to the faucet if that still doesn't fix it then you will need to replace the faucet because it has clogged up from minerals and particles in the water and there is no way to clean out the inside of the faucet.
May 16, 2010 | Globe Union N58022CP Do it Best 2Handle...
My water supply has little pieces of grit that clog up the strainer in the Price Pfister 548E0BK faucet. I periodically clean out the grit. Recently the water flow rate decreased, and cleaning the strainer...
'DO NOT REMOVE"! lol JUST KIDDING. >You may need to remove again to find out why the valve seat is not sealing In fact, expect that you will. The grit is white in color? did you see any special washers or seals in the DNR zone? wHEN REINSTALLING THE VALE BODY, YHE STEM SHOULD BE ALL THE WAY OPEN . cLOSE THE VALVE ONLY AFTER ALL IS IN PLACE. AND YOU NEED An INLINE STRAINER IN YOUR WATER SYSTEM.. gOOD lUCK _nED_
Sep 27, 2009 | Price Pfister 548E0BK Catalina...
Installed a new oak brook collection tub and shower faucet and no water comes out.
You may have to disassymble the faucet to see if there is something that is stuck in there or that the assymbly internally is stuck in the closed position.
Mar 19, 2009 | Ace Hardware OAKBROOK COLLECTION DESIGNERS...
Slow and nonexistent water flow.
Start by removing the spray head from the hose. Pull the spray head out and with a channel lock pliers unthread connection between the spray head and hose. BE CAREFUL not to let the hose fall back down into the faucet. With the hose directed down toward the sink test for volume by turning on the faucet. If you get a nice volume the problem is in the spray head. This is usually the case. Put the spray head back on then remove the aerator. It's the screen where the water comes out of the spray head. Clean out the assembly ( 3-4 parts). Reassemble and test.
Good luck, Phil
Dec 11, 2008 | American Standard Bath Faucet Ceramix...
Ace Hardware OAKBROOK COLLECTION DESIGNERS CHOICE TUB/SHOWER Logo
173 people viewed this question
Top Ace Hardware Home Experts
guitar zan
Are you an Ace Hardware Home Expert? Answer questions, earn points and help others
