Shutdown warning this message keeps appearing on my tv screen about every 6 hours
    Sergeant:
  • 302 Answers
Your tv timer might be set for it to shut down every hours. If you canot change it try a factory reset of your tv. If that does not help then you might have a bad signal board.
you can get parts for this tv at www.interliquidparts.com
Posted on Feb 25, 2012
2 Suggested Answers
SOURCE: My tcl tv always shutdown every 10 sec with the
PLS TXT ME.I CAN HELP
Posted on Jan 04, 2011
VOIP 321 upgrade for Skype 6.3.0.105 on Windows7 x64
Have you checked for Win 7 recent updates?
Apr 25, 2017 | Computers & Internet
Why does shutdown warning show on40bv801b after 3 to 4 hours
go to menu go tv set up scroll to feature scroll down to ext out scroll down again to auto tv off you can now choose the amount of time you want or turn off shutdown warning for good
HOPE THIS HELPS JAWS
Nov 06, 2011 | Toshiba 40BV801B LCD TV
My receiver wont stop recording after the program ends it will just keep recording how do i stop this
My name is Anthony Thomas with DISH Network Customer Service. This issue is usually due to a faulty program guide with "No Information Available" or incorrect information as to when the programming ends. This can be caused by a faulty Electronic Program Guide (EPG) download, a faulty box, or by signal loss. By pressing the guide button to bring up the guide, and then pressing the numbers 999 and then browse (the right arrow by select) it should give a message that says "The guide information is outdated, download from satellite now?" or something similar. Try it and see if that helps.
If not, that means there is likely a signal issue or an issue with the DVR. To check signal, Press Menu (top left corner of remote under SAT, has three horizontal lines on it), and then press 6-1-1 like you are changing the channels. That should get you to Point Dish. Check Switch will be an option on the right side. Select it and then select TEST at the bottom of the Install Summary screen that will show up. Select YES if there is a warning about TV2, otherwise it will bring up a 058 message saying to wait while test is done. The message 058 will disappear by itself. If a warning 836 message appears, your issue may require a technician due to signal loss. If not, select done to exit Install Summary, Done again to exit Point Dish, and then press the 0 button three times to select the cancel option. This should put you to an "Acquiring Satellite" Message(Attention 015/535 message) and then download the guide (Attention 330). Check it then. If it still doesn't work, the box may need replacing. If it works, you are all done! Hope this helps!
Sep 23, 2010 | DISH Network DVR-625 DTV Receiver /...
Acer aspire 2920z is automatically shutdown only message appear warning critical battery low and then shutdown
Sounds like your battery is faulty and not charging. Try replacing the battery or just use the mains lead with the battery removed. If this keeps happening replace the system board
Feb 23, 2010 | Acer Aspire 5610-4648 Notebook
DVI warnings when you connect HDMI cables
TV IS IN DEMO MODE GO IN OPTIONS MENU OF VIDEO AND TURN OFF. READ OWNERS MANUAL PAGE 80,81,82
Sep 22, 2009 | LG 32LH20 32 in. LCD HDTV
Temperature too hot warning
Check the proper working of its cooling fans. . If you wish to get some details; check the site linked here. Pull up older posts.
Jun 06, 2017 | LG RU-44SZ63D Television
Optoma RD50 TV which shuts down on #1 fan failure
This could be a variant of, or a newer (or older) version of the "DMD fan failure" message.
Symptoms I had are, I stop hearing a fan when the message is displayed.
Then the temp LED keeps flashing RED until I either try to turn the TV on again,
Or turn MAIN power off/on again. BUT it repeats when I try to turn the TV on.
The picture appears normal until this happens ( about 15 sec.)
The solution is to FORCE a normal shutdown by hitting the TV off button
before the message appears.
You should see the power LED flashing RED/GREEN (cool down) and then RED (standby).
Apr 20, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
