Question about Lexmark X2650 All-In-One InkJet Printer
Lexmark X2650 printer--How to remove a paper jam when you cannot see the paper
  • Official Brand Answer
  • 3,344 Answers
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Posted on Feb 27, 2012
Ajkill
  • 2035 Answers
SOURCE: Lexmark X4850 paper jam
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on May 13, 2008
SOURCE: paper jam lexmark x3470
Buy an HP!
Posted on May 20, 2008
SOURCE: PAPER JAM ERROR MESSAGE
your sensor flag in the back is broken or missing
Posted on Jul 22, 2008
  • 684 Answers
SOURCE: Lexmark X4650 ink jet printer has paper jam
Please follow these steps to set your printer to defaults:
1. Please make sure your printer is set in Copy Mode.
2. Press the "setup" button, you will find "Maintenance" displayed.
3. Use your arrow keys to locate "Set Defaults" and press "OK".
4. Press the arrow key to find "Use Factory" and press "OK"
This process would reset your printer to Factory defaults.
Posted on Apr 29, 2009
  • 7 Answers
SOURCE: Can't Fill ink in X2650 Lexmark
If your looking for cheap ink, try buying a more expensive printer as ink for the expensive printers are relatively cheaper. I also tried refilling the inks for my printer but to no avail, it simply leaked out the bottom making a big mess
Posted on Jun 09, 2009
Lexmark x2650 printing vertical on pages not horizontal why
when you click print, select preferences and then paper layout, choose portrait or landscape there to change the print layout.
Dec 29, 2012 | Lexmark X2650 All-In-One InkJet Printer
Paper jam and I don't know how to fix it, I have a 2600
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
Aug 17, 2011 | Lexmark X2650 All-In-One InkJet Printer
Paper jam
try a different type of paper
Jun 12, 2011 | Lexmark X2650 All-In-One InkJet Printer
I have a lexmark x2650 it wont feed the paper keeps jamming and not printing there is no paper stuck in it
try cleaning the paper supply roller with alcohol and a lint free cloth. if it helps for a short time, then you need to have someone replace the rollers in the paper supply
Feb 19, 2011 | Lexmark C533DN InkJet Printer
I do not have any instructions and want to photo copy.
Go to link below, you should be able to download your printer manual from it. Lexmark X2650 All-In-One Inkjet Printer User Manual Free Download User Manual: Lexmark X2650 All-In-One Inkjet Printer - Service Manuals, User Guide, Reviews, Instruction Manuals and Owner's Manual.
www.generalmanual.com/Printers/Lexmark-X2650-All-In-One-Inkjet-Printer.htm ·
Nov 04, 2010 | Lexmark X2650 All-In-One InkJet Printer
X2650. False Paper Jam indicator.
There are a few options for you. You can power it completely off for a few moments to see if that clears the error. During that time I would recommend using a can of air to spray out the inside of the printer. The sensors can get dust on them and make it appear that you have a paper jam. Also if there is a small piece somehwere the pressurized air will hopefully dislodge it.
Good Luck!
Oct 30, 2009 | Lexmark X2650 All-In-One InkJet Printer
I just bought a lexmark x2650 printer it came
Here is the link to the exact manual you need:
http://www.lexmark.com/publications/pdfs/2007/2600/v7649663_en.pdf
Jul 26, 2009 | Lexmark X2650 All-In-One InkJet Printer
Lexmark printer x 2650 won't print.
u need to remove the stuck paper turn off the printer and start again
Feb 24, 2009 | Lexmark X2650 All-In-One InkJet Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Lexmark X2650 All-In-One InkJet Printer Logo
158 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
