Question about Coffee Makers & Espresso Machines
Took apart Farberware Percolator Model 134 B. Seem to have an extra part after reassembling. Little red piece of slotte rubber that looks like it may hold some of the insulated wire. not sure that this even goes with unit but did show up suddenly
  • 3 Answers
SOURCE: Farberware superfast perculator
I have found a good source of parts for Faberware urns and percolators at goodmans.net. The thermostats and heating elements can be easily replaced and the urn returned to original condition. Rich of Colorado
Posted on May 14, 2008
  • 21 Answers
SOURCE: Farberware 12-cup percolator, #FCP 412-A, that does not work.
just resolder it, i did and it lasted a long time
part here
http://www.marbeck.com/percolator_home_farberware.html
Posted on Oct 24, 2009
  • 176 Answers
SOURCE: Percolator not working
The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. You have 1-nut and 1- screw to remove. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers.O eBay the KW element is $8.00 and $2.00 S/H. You can BUY-IT-NOW with this auction. Thanks and please ask if you need more help.
Posted on Jul 17, 2010
  • 176 Answers
SOURCE: How do I make coffee in a Farberware 'superfast'
Hi 2 scoops of coffee to 3 cups. Then work it from there, to get it to your taste. It is done when it stops perking. When that happens the keepwarm element takes over until you unplug it. Good luck. Ron
Posted on Jul 27, 2010
  • 176 Answers
SOURCE: looking the glass knob for the farberware FCP512
Hi. Go to eBay and search for farberware coffee pot parts. Good luck
Posted on Aug 11, 2010
Safety 1st model number 1c034 I took it apart to clean it and now cant put it back to together.... I have 2 extra medel pieces... HELP!!
Find a fitting station at www.nhtsa.gov. They will help you reassemble the seat. DO NOT GUESS!
-- Marc
Passionate Child Passenger Safety Instructor
Aug 13, 2014 | Baby Gear
Vintage farberware percolator does not stop percolating
There is a thermostat in the bottom of the percolator that is broken. It would normally cut off the percolator heating element after the water reaches a certain temperature. It can be replaced but it takes a little skill. There is a video on eBay.
If you want to just unplug the percolator, time it for 1 minute per cup.
Jan 25, 2014 | Faberware Coffee Makers & Espresso...
Farberware millenium coffee percolator does not heat
There is a thermostat in the bottom of the percolator that is broken. It would normally cut in to perc the coffee and then cut off the percolator heating element after the water reaches a certain temperature. It can be replaced but it takes a little skill. There is a video on eBay.
If you want to bypass the thermostat and just unplug the percolator, time it for 1 minute per cup.
Mar 04, 2013 | Farberware Coffee Makers & Espresso...
Maui outlets for Farberware percolator do not carry filters? Why?
I think it is because water goes through the coffee while it goes around and through the pipe inside the percolator Let the coffee stand for a few minutes when it is through, then .the coffee will be fine.
enjoy your coffee
kolbrun
Jul 03, 2012 | Farberware FCP280 Stainless Steel...
Need to know how much coffee to use in Farberware auto percolator
Farberware manuals do not seem to be available online. Try contacting Farberware Customer Service at the following site:
http://www.farberware.com/customerservice.html?hm=Y&ct=N&anw=N
For coffee makers try the e-mail address for Electric appliances. Send your model number with your request for a manual.
Thank you for using FiXYa!
Jul 29, 2011 | Farberware FSU236 36Cup Coffee Maker
When I try to check continuity across the two thermostat leads I get none. Shouldn't I get a circut when it is cold and when hot there should be none?
We have a Farberware Percolator / "Superfast" #FCP412-A...This morning we plugged it in and nothing happened...I took the base off and found one of the connectors loose, but not totally disconnected. After I tightened it, we plugged it in and it still did not heat up. Any suggestions would be appreciated. Thank you. / JP
Feb 05, 2011 | Farberware FCP280 Stainless Steel...
Thanks for letting us know that there was no solution other than one I would have to come up with entirely on my own. My dad who is old school wouldn't let me give up so we took the thing apart and it was an easy fix. Take the 5/16 nut off the bottom. Pull the slide pins off the thermostat. Take the philips screw out of the support holding the thermostat in place. Use a sharp pointed knife and with the silver Aluminum cap flat on the bench, make a slice on one edge. Use the knife to pull the edge away from the plastic housing and the cap will pop off. Be careful not to loose the small piece of ceramic that lies in a small whole on top of the contact. Use a sharp knife to clean the contacts and check with an ohms meter or continuity light. If it makes a good contact, put it back together. It took my dad and me about 10 minutes to do the entire job. We looked for a part for 20 minutes. Good luck. Rick and Adam Schmitt of Maryland.
Dec 08, 2007 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
284 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
