Question about HP Computers & Internet
MY HP DC5800 RESTART WHENEVER I PRESS SHUTDOWN
ONLY WHEN I KEEP DOWN MY FINGER ON THE MAIN POWER BUTTON IT TURNED OFF
5 Suggested Answers
SOURCE: i shutdown my emachine E725 through windows it doesnot shutdown automatically and hands and ive to shut it down manually through power button
I had the same problem on E725 model, I fixed it by installing XP SP3.
Posted on Sep 12, 2009
  • 6 Answers
SOURCE: Hi a have to HP dc5800 minitower itgoes in windows
So after the windows logo shows...the pc restarts? Sounds like it might be bluescreening. Could be bad memory or some other type of hardware issue. Hard to say without more detail but you may want to try booting it into safe mode but repeatidly hitting the F8 key until it gives you the bootup options DOS screen. Choose boot to safe mode and see if it does this successfully. If so...could be a corrupted application or bad third party hardware like a usb device or sound card.
Posted on Nov 19, 2009
  • 15 Answers
SOURCE: My Gateway 700X PC (Windows XP) will not Shutdown/Will not Start.
Best to format and reinstall a fresh copy of your operation system.
Regards
Posted on Feb 26, 2010
anas-ka
  • 97 Answers
SOURCE: HP IQ 526 When I press the power button the backlights flash and the power led goes yellow after a few seconds the screen flashes again and the fans restart then it just stays dark, if I hold the powe
Hi Jerry,
Do follow the steps below...
1. Remove the RAM from the motherboard and switch it on. (you'll get 6 continuos beeps) Refix the RAM and check whether it is working or not...
2. Remove the CMOS battery and switch on the PC_ Switch off_Re fix the battery to the slot_Switch on...
3. Disconnect the hard disk from the PC and switch it on...
Posted on May 22, 2012
Testimonial: "Very good it was the cmos"
Mid tablet wont shut down
So you need to be In the main menu interface then press the power button for about 5 seconds to shut it down. Below is the power section out of the manual.
1.2 POWER
startup: Long Press and hold the power button, the system will enter the main interface
shutdown: In the main menu interface, Press the power button about 5 second to shutdown, The system can hint "power off" option, Clike"ok". you can safely shut down.
Lock screen: Short press Power button to lock screen or unlock screen.
Remark 1.When power is empty,system will shut down automatically.
2.Illegal turn off the device,restart will scan and restore the disk,it may take longer time to enter into system
Jan 30, 2013 | mid Archos M729B Android Tablet
I shut down my computer to reboot it and when I went to turn it back on it would not go back on. Everything seems fine all the plugs are ok and the green power light is on.
u may be selected the standby mode in the shutdown option,press the power button it will power on quickly andthen shutdown properly.if u want to restart then select the RESTART option while shutdown.
Aug 15, 2008 | HP Computers & Internet
My shut down button is not responding at all. what will I do?
Remove main battery and unplug the adapter from the laptop, press and hold power button for 60 seconds, now hook everything back up and power on.
Jun 07, 2012 | Toshiba NB520-11W
Hi, whenever I connect a USB cable (even charger) the E72 is locked
ITS A SOFTWARE PROBLEM. RESET YOUR PHONE . HOW TO RESET YOUR NOKIA E72
The way to button-press Hard Reset your E72 is the SAME as the N97.
Hold these buttons:
- Capslock
- Space
- Backspace
and Press the power on. As usual, keep the buttons pressed and voila!
NUMBER 2
Switch your phone off.
Then, lay it down on a flat surface
With 3 finger of one hand, keep pressed shift, space bar and back space all at the same time
With one finger of the other hand, press the power on button
Do not release neither the 3 keys nor the power key till you see the nokia shakehands animation
Feb 10, 2012 | Nokia E72 Smartphone
My unit turned off during gameplay now i cannot turn it back on even to eject the game
Follow the procedure below to fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
Restart System: Restarts the PLAYSTATION®3 System.
Restore Default Settings: Reset all system settings back to default.
Restore File System: Checks for corrupt/missing system files.
Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
System Update: Update the PLAYSTATION3 System
Feb 09, 2011 | Sony Playstation 3 (PS3) Console
The ps3 is not going to main menu it keeps loading and loading trying to get to the main menu what can i do about it?
How to Access Playstation Recovery Menu
2. Hold The power button down; The system will turn on and turn off once again.
5. You will be promted to plug in your controller via usb and then hit the PS button
try this and restore it from there it will erase all data but if its a working system you want this could help :)
Nov 19, 2010 | Sony Playstation 3 (PS3) Console
It will no restart.. no matter if I press the power button
press the power button for 4 SECONDS... The computer will shut down completely; Then you could turn it up again whenever you want.
Nov 04, 2010 | HP Compaq nc6230 Notebook
It turn on and it stay on the main screen
Try these steps below to see if it will fix the problem on your ps3,
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 03, 2010 | Sony Playstation 3 (PS3) Console
No main menu, just wavy lines with sony entertainment
This is a hard reset of the system, used when there is a catastrophic error etc. I have trawled these kind of sights and the main concensus is to ensure you have a back up of all important data. I experienced the same issue but the method above was advised by my games shop.
Nov 03, 2008 | Sony Playstation 3 (PS3) Console
Turning my computer off
Assuming you havent hust pressed it and let go straight away, as that is a reset, if you have pressed and held until the pc has gone off, then there is a problem with the poer down, go to control panel>power options, click advanced button and at the bottom of the window it says when i press power button on computer, then give the instruction in the drop down list see below
Sep 07, 2007 | HP Compaq Presario SR1350NX (PP196AA#ABA)...
Computers & Internet Logo
191 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
