Question about Jenn-Air PRG3010 (NP) Gas Kitchen Range
Jenn air model prg3010np oven will not heat, broiler will not heat
Oven stopped heating all of a sudden. Broiler will not work either. The range still lights and works fine. Wondering if it's the oven's ignitor? When I turn the dial, I hear the click, but no heating. No brief light for ignition in the oven when I turn it on. No gas smell when turned on. Also heard noises (like a car with a muffler problem - a quiet put-put sound) for a couple of weeks beforehand when oven was heating.
SOURCE: prg3601p oven
I also have this problem Ihave replaced the igniter twice this helps some for a while  I AM GETTNG READY to order my third one. had dealer replace once they had no answer cut lighting time from fifteen to twenty minutes to maybe five
Posted on Sep 14, 2008
SOURCE: OVEN WILL NOT CLEAN JENN-AIR SVE47100B
It was recommended to me by your service that I call a service person. I did that. thanks.
Posted on Jan 04, 2009
NephetZ
  • 9 Answers
SOURCE: Oven heats very slowly (Jenn-Air JGS9900BDS).
hi, Could be a bad bake element or a bad temperature sensor. If the element will glow bright red/orange with no hotspots it is OK. Take a volt/ohm meter set for ohms and check the temp sensor. If less than 1050 ohms replace it.
NephetZ
Posted on Jul 08, 2009
SOURCE: re: Jenn Air #svd48600b Gas Stove Top works...
Having a problem with the stove on this Jenn Air svd48600b.
Often with the oven warms up to 350F it starts beeping at and shuts off.
It flashes either just an FC error code, or FC and F5.
It is often possible to get the oven to work again if you wait 10-15min and cycle the power.
I imagine something is wrong with a heat sensor? The temperature sensor responsible for displaying temperature on the control panel seems fine though.
One other detail, even when the oven doesn't shut off at hot temperatures, the fan comes on (at around 220F) and stays on for over an hour after the oven is turned off.
Does anyone know if there is a different temperature sensor that might cause this? Is there a specific electronics board that may be leading to this problem.
when it heats up.
Posted on Sep 03, 2009
  • 189 Answers
SOURCE: Gas oven doesn't work. Broiler does.
Hello - Most likely failed lower burner ignitor. Tests good if above 4ohms. Part is 40$. Can give replacement instructions if needed. Let me know if this helps. Thanks. -ED
Posted on Mar 03, 2010
Kenmore electric range model 790 oven stopped functioning, both broiler and bake. however, oven light still comes on.
I believe there is a thermal fuse (also called a TCO or Thermal Cut-Out) located either on the back of the oven, or between the top of the oven and the cooktop that has opened up. Did this happen after running a self-clean cycle?
Sep 09, 2014 | Kenmore Kitchen Ranges
JennAir Gas Oven won't heat up, it stays at and displays 100 degrees, but it isn't warm. Moedel JGR8885RDP. The gas range works fine and so does the broiler. No error codes pop up on the display.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 24, 2011 | Jenn-Air JGR8885RDP Gas Range
Oven does not heat up Broiler works but takes a while to ignite. Range top burners work
heatman101
Sep 29, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
Broiler works oven doesn't heat
Based on your description, the igniter is dead.
The broiler and the oven heat each have their own igniter. Look for the characteristic glow when the oven is turned on. If it is not visible, then you will need to replace the "OVEN" igniter...
Google the stove model for repair parts and locate the igniter. Not too hard to replace... directions are packed with the new igniter...
Jan 08, 2010 | Maytag MGR5750 Gas Kitchen Range
My oven heating element doesn't get red and the oven temperature rises only until 270 degrees. The broiler element works fine. Any thoughts?
I removed the heating element and checked it with an ohmeter, which showed the element had shorted out. I've purchased another element on line.
Nov 21, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Jan 02, 2009 | Jenn-Air SVE47100 Slide-In Electric...
JENN AIR WALL OVEN ELECTRIC
Are you sure the breaker didn't trip on one side? If one leg of the 220 is out, the lights and controls will appear to work, but the elements will not heat up. Make sure you have 220 to the appliance. It's also possible that you pulled a wire off somehow when changing the broil element.
Dec 12, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Oven, broiler don't work
The main control board is what you need to replace here.Please Rate This !
Jul 06, 2008 | Kenmore Kitchen Ranges
Jenn-Air PRG3010 (NP) Gas Kitchen Range Logo
129 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
