Question about Quinny ZAPP Stroller
How to fold it, got the 1 & 2 step but not 3 - Quinny ZAPP Stroller
    Problem Solver:
  • 5 Answers
So you push the buttons in at the side then fold it to the half open position, then the second bit there is a bit of a nack, usually only acheivable by women (well in my household), its easier to bend down to it level at the back of the buggey,then press the grey button (2) a bit like a triangle in, and as you extend your arm pushing it along the bar going underneath the buggey. It can sometimes be a nusiance whenever i'm in a rush it never works.
Posted on Dec 06, 2008
Simpson eziset 605 wont take in hot water
Hot valve in washing machine required. Part is between $25 & $60 STEP 1: unplug machine STEP 2: undo the 3 Phillips screws on top of machine the fold top console forward STEP 3: Undo hot tap,disconnect 2 wires running to hot valve,remove valve,fit new valve. STEP 4: Refit top console. DONE
Jun 17, 2012 | Washing Machines
How do I play regional dvd's that the player is not tuned to. I have been trying to find a code but I am struggling. Can you help me?
Hi
You need to follow these instructions.
To unlock the Region Code on a Panasonic DMR EZ48 using a One for All - URC 7040
1. Switch on the player (make sure the drive select is DVD).
2. Select DVD on the URC.
3. Hold the magic button on the URC until the DVD button on the URC blinks twice
4. Enter device code 0490 on the URC, (DVD button blinks twice), URC takes control of the Player.
Point the URC at the Player and program the URC buttons using the following procedure:
1. Hold magic button until the DVD button on the URC blinks twice
2. Press 994 (DVD button blinks twice)
3. Briefly press magic.
4. Enter 4 digit code 1911 (DVD button on URC blinks twice)
5. Repeat steps 1, 2 & 3
6. Enter 4 digit code 1202 (DVD button on URC blinks twice)
7. Repeat steps 1, 2 & 3
8. Enter 4 digit code 0653 (DVD button on URC blinks twice)
9. Repeat steps 1, 2 & 3
10. Enter 4 digit code 1804 (DVD button on URC blinks twice)
11. Repeat steps 1, 2 & 3
12. Enter 4 digit code 1435 (DVD button on URC blinks twice)
13. Repeat steps 1, 2 & 3
14. Enter 4 digit code 1556 (DVD button on URC blinks twice)
15. Repeat steps 1, 2 & 3
16. Enter 4 digit code 1227 (DVD button on URC blinks twice)
17. Repeat steps 1, 2 & 3
18. Enter 4 digit code 1178 (DVD button on URC blinks twice)
19. Repeat steps 1, 2 & 3
20. Enter 4 digit code 1299 (DVD button on URC blinks twice)
21. Repeat steps 1, 2 & 3
22. Enter 4 digit code 1230 (DVD button on URC blinks twice)
23. Press the One For All URC buttons in the following sequence
1, 2, 3, 4, 5, 6, 7, 8, 9, THEN hold down 0 until "HELLO" appears in the display;
After about 1 minute the Player comes back to life as Multi Region.
Please dont forget to vote if you liked my answer
thanks
Feb 13, 2011 | Panasonic DMR-EZ48 DVD Recorder
How do you fold this twin stroller?
1. Loosen the plastic catches on both sides
2. Push up the red safety lever and fold the seats in half
3. Step on the top rim of the rubberized, lower compartment of the buggy to fold the frame
Jul 25, 2010 | Valco Twin Runabout ATS Jogger
What is the torque settings on the head bolts for 2002 nissan x-terra 2.4litre?
① Step 1: 22 ft. lbs. Step 2: 59 ft. lbs. Step 3: Loosen completely then retorque to 22 ft. lbs. Step 4: 18-25 ft. lbs. Step 5: Plus 86-91 degrees ② 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs. ③ The cylinder heads and the lower intake manifold are installed together Step 1: Tighten the cylinder head bolts to 22 ft. lbs. Step 2: Tighten the cylinder head bolts to 43 ft. lbs. Step 3: Loosen the cylinder head bolts completely Step 4: Tighten the cylinder head bolts to 84 inch lbs. Step 5: Tighten the intake manifold fasteners to 35 inch lbs. Step 6: Tighten the intake manifold fasteners to 13 ft. lbs. Step 7: Tighten the intake manifold fasteners to 12-14 ft. lbs. Step 8: Loosen all intake manifold fasteners completely Step 9: Tighten the cylinder head bolts to 22 ft. lbs. Step 10: Tighten the cylinder head bolts 60-65 degrees Step 11: Tighten the cylinder head sub-bolts to 80-105 inch lbs. Step 12: Tighten the intake manifold fasteners to 35 inch lbs. Step 13: Tighten the intake manifold fasteners to 78 inch lbs. Step 14: Tighten the intake manifold fasteners to 70-84 inch lbs. ④ 10-12 ft. lbs. +60-65 degrees ⑤ Step 1: 72 ft. lbs. Step 2: loosen completely to 0 ft. lbs. Step 3: 29 ft. lbs. Step 4: Plus 75 degrees clockwise Step 5: Plus 75 degrees clockwise ⑥ Step 1: bolts 11-22 19 ft. lbs. Step 2: bolts 1-10 29 ft. lbs. Step 3: bolts 1-10 Plus 60-65 degrees ⑦ Step 1: 20 ft. lbs. Step 2: loosen to 0 ft. lbs. Step 3: 14 ft. lbs. Step 4: Plus 85-95 degrees ⑧ Step 1: 31 ft. lbs. Step 2: Plus 60 degrees ⑨ 83 inch lbs. ⑩ Stud bolt: 11 ft. lbs. Nuts: 31 ft. lbs. ⑪ Step 1: 72 ft. lbs. Step 2: loosen completely to 0 ft. lbs. Step 3: 29 ft. lbs. Step 4: Plus 90 degrees clockwise Step 5: Plus 90 degrees clockwise ⑫ Bolts: 17-24 (M8) 16 ft. lbs. Install rear main seal Bolts: 1-16 (M10) 26 ft. lbs. Bolts: 1-16 (M10) Plus 90 degrees clockwise ⑬ Step 1: 33 ft. lbs. Step 2: Plus 84-90 degrees clockwise ⑭ Intake manifold collector: Bolts and nuts: 8 ft. lbs. Stud bolts: 61 inch lbs. ⑮ Intake manifold: Bolts and nuts: 5 ft. lbs. and than to 21 ft. lbs. Studs: 8 ft. lbs.
Jan 10, 2010 | 2002 Nissan Xterra
Does anyone have instructions for Nike Imara Fit WR0076?
How to set time(hour minutes)/date(day, month, year)/power hour on nike imara fit:
PLEASE READ CAREFULLY
STEP 1:
First hold the button for set/light.
STEP 2:
wait for the "hold to set" message to appear
once it appears, keep on holding the button until the hour is ready to be set or when the hour blinks.
TIP: Pressing the mode will enable you to choose from setting (HOUR, MINUTE, DAY, MONTH,YEAR, 12/24 HOUR FORMAT, POWER HOUR.)
STEP 3:
To set HOUR: press the start(for higher values) or stop (for lower values) button, choose whatever hour you want to set the time.
*If you are done setting the time press the set/light button, and there you have it.
If you still need to change the minutes of your digital watch proceed to step four.
STEP 4:
After, you have undergone step 1, & 2, or step 1, 2, & 3 (either way it'll still work), press the mode button and then, minute is ready to be set or when the minute blinks.
To set MINUTE:
press the start (for higher values) or stop (for lower values) button, and choose whatever minute you want to set the time.
*If you are done setting the minute, press the set/light button, and there you have it.
If you still need to change the date specifically, the day of your watch proceed to step five.
STEP 5:
To set date, specifically, DAY:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode twice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode once.
To set DAY: press the start (for higher values) or stop (for lower values) button, and choose whatever day you want to set the date.
*If you are done setting the day, press the set/light button, and there you have it.
If you still need to change the date specifically, the month of your watch proceed to step six.
STEP 6:
To set date, specifically MONTH:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode thrice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode twice. If you did it step by step until 6, press the mode once.
To set MONTH:
press the start (for higher values) or stop (for lower values) button, and choose whatever month you want to set the date.
*If you are done setting the month, press the set/light button, and there you have it.
If you still need to change the date specifically, the year of your watch proceed to step seven.
STEP 7:
To set date, specifically YEAR:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode four times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode thrice. If you skipped step 6, press the mode twice. If you did it step by step until 7, press the mode once.
To set YEAR: press the start (for higher values) or stop (for lower values) button, and choose whatever year you want to set the date.
*If you are done setting the year, press the set/light button, and there you have it.
If you still need to change the 12/24 hour format of your watch proceed to step eight.
STEP 8:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode five times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 4 times. If you skipped step 6 & 7, press the mode thrice. If you skipped step 7, press mode twice. If you did it step by step until 8, press the mode once.
To set 12/24 HOUR FORMAT: press the start (for higher values) or stop (for lower values) button, and choose whatever format you want to set the time.
*If you are done setting the 12/24 hour format , press the set/light button, and there you have it.
If you still need to change the power hour of your watch proceed to step nine.
STEP 9:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode six times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 5 times. If you skipped step 6, 7, & 8, press the mode 4 times. If you skipped step 7 & 8, press mode thrice. If you skipped step 8, press mode twice. If you did it step by step until 9, press the mode once.
To set POWER HOUR: press start for 3, 6, 12, 24 to set the power hour.
Press set/light to set POWER HOUR.
May 13, 2009 | Nike Imara Fit WR0076-002 Wrist Watch
How do I set the time for nike imara fit WR0076-002 wrist watch?
STEP 1:
STEP 2:
STEP 3:
STEP 4:
To set MINUTE:
STEP 5:
STEP 6:
To set MONTH:
STEP 7:
STEP 8:
STEP 9:
Mar 26, 2009 | Nike Imara Fit WR0076-002 Wrist Watch
I dont know how to set the time
STEP 1:
STEP 2:
STEP 3:
STEP 4:
To set MINUTE:
STEP 5:
STEP 6:
To set MONTH:
STEP 7:
STEP 8:
STEP 9:
Nov 11, 2008 | Nike Imara Run WR0075-014 Wrist Watch
Setting the date and time on watch
time:
hold left button -- hour will appear and begin flashing.
press right button to set.
press left button to advance to minutes, press right to set.
date:
press left -- date will appear. now hold left until day flashes.
press right to set.
press left to advance to month, right to set. then same again for year.
Nov 11, 2008 | Nike Imara Soar WR0103 201 wristwatch
Quinny zapp, how to open & fold?? really struggle with it. there must be an easier way
I find to fold it, I place my foot on number 3 and push a little then press number 2 and 1 and the same time and fold the seat unit. Then just push down ontyo it untill t is fully folded. I find it to difficult to press 1 then 2 then 3 - 3 always gets jammed if i follow their instructions.
To unfold pull number 3 untill it clicks then nfold seat unit an click the middle handle - hey presto buggy shuld work :)
i thk the instructions tey give a more work than needed.
Aug 14, 2008 | Quinny ZAPP Stroller
How to fold it up
Push the nuber 3 button then push it towards the front of the buggy then push the 2 back wheels together
Jun 18, 2008 | Quinny Zapp Umbrella Stroller
Quinny ZAPP Stroller Logo
126 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Al Toledo
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
