Question about Hunter Ceiling Fan Light Remote Control
My hunter fan remote will not turn off the light.
I have cleaned the contacts and the remote will turn on/off the fan but wont turn off the light or dim it. I have to unscrew the light bulbs to get them to turn off. There is no wall switch to control the fan.
  • Patrick Diemer Mar 04, 2012
    I would assume that since the remote controls the fan perfectly then the remote would work. For some reason, I never thought that maybe part of the remote was broken. I will go to Menards and give it a try in the next couple of days.
KMusselmann
  • 247 Answers
SOURCE: Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Posted on Mar 17, 2009
SOURCE: Remote controlled ceiling fan has mind of it's own.
I have the same fan. The fan and the remote have some "jumpers" which allow you to change the codes, useful if someone else nearby has the same fan. You can see the jumpers inside the remote, open the back cover... you'll see "4 3 2 1" on the circuit board. Unfortunately you'll need to dismount the fan to change its jumpers, they need to be the same as the jumpers in your remote (which you can move around pretty easily).
Posted on Jul 03, 2009
SOURCE: Hunter Fan Remote Control Part No. 85095-01:
I had the same problem. I found that the reverse button needs to be pressed really hard. It now works but I need to press that button really really hard.
Posted on Jul 17, 2009
  • 1114 Answers
SOURCE: Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Posted on Jul 21, 2009
  • 5 Answers
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
if the battery's are good then you broke it and you have to order a new one which you can do by calling the place that you got the fan from tell them what kind of fan you have and let them know that you nead a new remote and they will be able to help you do that.
Posted on Aug 13, 2009
Fan will not turn under it's own power, but turns freely by hand. Light bulbs light up very dimly. Light sockets show 120volts when the switch is turned on if all light bulbs are removed, but if a...
You probably have a wire nut connection that is just barely connected. Perhaps it's a connection between stranded wire and solid wire where only one of the strands is making contact with the solid wire.
Jan 09, 2011 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
The light is very dim despite changing the light bulb and trying higher wattage light bulbs. All of the other fans in the house have good lighting and no other electrical problems in the room. The blades...
Try holding the remote light button down it has a dimmer built in it should go all the way as bright as it can go then start back down to dim.That is how mine works .
Jan 08, 2011 | Minka -Aire Brushed Nickel Remote Control...
I have a 3 year old Panasonic Whisperlite FV-08VQL4 ceiling fan for the bathroom, with two CFL bulbs (18W each). One of the two bulb locations is bad -- it won't turn on, regardless of replacing the bulb...
Sounds like a loose wire inside the unit. But, I would try this. With the power off, both switch and circuit breaker, try and bend the center contact for the light bulb out; pull it out away from the back of the socket. This may be the bad contact. The center contact on the bulb touches this in order to get power up into the bulb. Using a small screw driver, try and scrape the surface of this contact to clean it a bit. DO ALL OF THIS WITH THE POWER OFF!!!
Hope this helps.
Sep 05, 2010 | Panasonic FV-08VQL4 Fan
Light will not dim
Clean the contacts on your remote pcb as well as the carbon contacts on your remote pads and replace the batteries with a new one
Jun 06, 2010 | Hunter 27177 Remote Control
Remote wont' work after changing battery
Seem like you have a bad lectronic control circuit in that fan.
Jun 29, 2009 | Oasis Hunter 54' Ceiling Fan
Wall remote that controls ceiling fan & lights not working
Either the bulb is blown or the connection under the wire nut is loose. First check the bulb then turn off the power at the panel and check each wire nut by unscrewing it and making sure that the wires are tightly twisted together before reinstalling the wire nut.
Mar 26, 2009 | Hunter 27187 Remote Control
40w candleabra bulb blew now can't turn lights off with remote
There is a receiver in the fan that when the light blew might have damaged that part of the receiver. I think you can buy them,but you will have to get into the base of the fan(ceiling cover).
Jan 02, 2009 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Remote control possibley defective
Does your remote have a variable control for the bright and dim for the light??sounds like yu have it in the dim mode..
Mar 26, 2007 | Westwind Classic Hugger Polished Brass 52"...
Dryers Logo
637 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
