Question about Brother IntelliFax-2820 Laser Fax
Brother 4750e not sending in sleep mode
Busy nursing area caims they cannot send faxes when their fax is in sleep mode
  • 26 Answers
SOURCE: Sleep
You should be able to send and recieve faxs in the sleep mode. You need to reset the machine, pull out the plug, hold down the menue key while you plug the machine in. When maintanence comes up in the display enter 01 and wait. Whwn maintanence comes up again press 99. DO NOT PRESS ANY OTHER NUMBERS OR YOU WILL DAMAGE THE MACHINE BEYOND REPAIR. Your fax is now reset and completley empty, you will have to put in your name etc and sleep mode will be set to "0" minutes
Posted on May 20, 2007
  • 22 Answers
SOURCE: "Receiving Sleep" on Brother Fax 4100
The sleep mode is only a power save mode. You may not have the machine in the correct fax receive mode. If the machine is on a line by itself it needs to be set to fax only, if line is shared with a telephone it needs to be in fax/telephone, if you share the machine with an answering machine it needs to be in TAD mode, and so forth. Each time you press the MODE key it will change the receive mode. Most people hit this key by mistake and change the MODE and the unit will not pick up calls. Press the MODE key until you are in the correct mode. To make sure the machine will print, press reports and then the 1, this will print a help list. If the help list prints you know that the machine works. Then check to make sure the machine is in the correct fax receive mode.
Posted on Oct 04, 2007
  • 22 Answers
SOURCE: IntelliFAX 4750E - Printer Busy
The printers memory may be full depending on the type of documents they are printing. The first and most simple step is to unplug the power cord from the back of the unit for 30 seconds, put your finger on the stop key while plugging the unit back up and continue holding the stop key until the time and date are back on the display of the Brother unit.
If that does not work unplug the USB cable from the PC. Unplug the power cord from the unit again. Put your finger on the menu key first and then plug the unit back up. You want to hold the menu key unit the until the LCD says maintanence and all the lights are flashing. Let the menu key go and press the number 82 and will give you an error code. If the error code is 00 then there are no errors. If there is an error code record it and contact brother or check a service manual if you have one. Most laser products all have the same error codes with Brother.
To reset the unit press stop and then 91, this will reset the unit and all faxes or print jobs will be lost. This should clear the issue.
Posted on Jan 02, 2008
  • 120 Answers
SOURCE: Brother Fax 4750e Super G Drum
Open the front door. the drum is the unit the toner goes into. make sure you follow the instuctions that come with it. I think you have to press the clear button with the front door open to clear the drum warning code. Lawrence
Posted on Feb 14, 2008
  • 101 Answers
SOURCE: Brother Intellifax 4750e with black line (1-1/2" wide on right)
The drum is scratch ,or there is a paper jammed .
Posted on Apr 22, 2008
Unable to enter faxes while the machine is either sending or rece
turn off
Real Time Transmission
When you are sending a fax, the machine will scan originals into memory before
sending. Then, as soon as the phone line is free, the machine will start dialing and
sending the fax. If memory becomes full, the machine will send the document in real
time (even if REAL TIME TX is set to OFF).
Sometimes you may want to send an important document immediately, without
waiting for memory transmission. You can set REAL TIME TX to ON.
1 Place the original face down in the ADF.
2 Press Menu, 2, 2, 6.
3 To change the default setting, and then
press or to select ON (or OFF) and
then press Set. Go to Step 5—OR—For
the next fax transmission only, press or to select NEXT FAX ONLY,
and then press Set.
4 For the next fax only, press or to select ON (or OFF), and then press Set.
5 Press 1 if you want to select additional settings. The LCD returns to the SETUP SEND
menu—OR—Press 2 if you are finished choosing settings, and then go to Step 6.
6 Enter fax number and then press Fax Start.
May 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother fax 4750e can not receive or send fax. sender said the line just ring and ring endlessly
To set up for receiving Fax, do the following:
Press Mode button repeatedly untin Fax and Fax/Tel lights are lit.
Faxes will automatically print and answering machine will take the calls. If you have a dedicated fax line, do the following:
Press Mode button repeatedly until just the FAX light is lit. Then the machine will answer every call as a fax.
Apr 23, 2009 | Brother IntelliFAX 4100 Laser Fax
I can send but cannot recievefax. Fax is on SLEEP all the time.
The machine is set with the sleep mode as a default. The fax part can be changed to recieve a fax by pressing the fax mode button. Press it until it says Fax only, not F/T. F/T means Fax/Telephone. This mode would make it to where you have to pick up the reciever and press start when a fax comes in. The Fax only mode means it will pick up everytime a fax comes in automatically. Let me know if this was helpful. Please give my helping a rating. Thanks!
Feb 11, 2009 | Brother IntelliFax-4100e Fax
How to send the same fax to several fax numbers?
it's called "broadcasting". open your owners manual, turn to page 7-3, and begin following the directions. quite simple, but too long to explain here.
hth,
razors
Jan 09, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
BROTHER FAX MACHINE 2800
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Able to receive fax but cant send
sleep mode is just a status of the machine when it is in idle mode.you cannot turn this off however you can delay the time before the unit goes into a sleep mode.it has nothing to do when you are sending out faxes.so here are a few things you need to check when sending a fax (1)dial tone by pressing hook/hold button (2) insert the doc into the adf, make sure it will change to "enter fax # and start,or copy press copy (3) dial the number (4) wait for fax tones of the receiving unit before you press start. now if you can hear an operator on the line,that has to be verified with your phone company since brother machine does not restrict incoming and outgoing faxes UNLESS that is restricted from your phone line.
Nov 18, 2008 | Brother IntelliFax-2820 Laser Fax
The fax machine is in sleep mode
Fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line . Filter makes no difference.
Nov 18, 2008 | Brother IntelliFAX 2800 Laser Fax
Can't find info - comfirmation
Its called "Transmission Verification Report"
Press Menu, 2, 4, 1
Select ON or On+Image
This will come with every fax you send.
If you want to customize, see owners manual under, "Printing Reports"
Oct 15, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother intellifax 4750e
if the copy comes out black and/or sends black the Contact Image Sensor in the scanner may be needed.
Hope that helps...
Jun 17, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
You need to open the front cover, then press the "Clear" button, and then press "1". This will reset the drum counter.
Mar 27, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother IntelliFax-2820 Laser Fax Logo
527 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
