Question about Kenmore 24032\24036 Top Load Washer
Cloth stocked up under spinning basket
Mywashing machine doesnt spin my daugther'spajama was stocked up under the spinning basket I tried to take it out but unsuccesful,please help.
  • lilgie2003 Oct 28, 2008
    ill appreciate verymuch if you can help me.
    Sergeant:
    Champion:
  • 324 Answers
Is the agitator loose? the dogs may be worn.
Posted on Nov 02, 2008
I have a Whirlpool Ultimate Care 2 Imperial Series washer that doesnt spin out very well. It will sometimes spin out but leaves the clothes very damp. Sometimes the washer will try to spin itself out but ...
First thought is that the cycles are off.we have the same problem with ours right now. That slow spin speed concerns me. The motor could be going bad. If this washer is 10-12 years old, you may want to look at replacing it. Does the machine ever start agitating before it finishes filling. If so, the cycle mechanism is going bad. This has a whole host of potential problems. Ave a rep look at it. He can narrow it down quickly.
Feb 06, 2013 | Whirlpool Washing Machines
My Kenmore Elite Oasis top load washer will start when is ready. We press the start button several times and hold it down for minutes at a time then maybe it will start. Plus even the smallest load will be...
If the washer is shaking and actually going out of balance and generating the UL error and the drum is empty the most likely cause of this problem is something under the spin basket.Clothes can end up under the spin basket and cause it to turn crocked and cause the out of balance. First I'd recommend removing the spin basket and check under it for any clothing or other obstruction that might cause the out of balance. Here is a diagram of how to Check.. Click Here
May 22, 2011 | Kenmore Washing Machines
Washer doesn't spin
let the machine rest for a long time (cool off) then with no water or clothes try spinning it...
no spin problem can be several headaches:
too much clothes (too heavy)
drive coupler broken
broken lid switch
basket freeze
pump locked
clothing in pump
clothing in between basket
clutch locked up
brake locked up
transmission seized!!!
it is hard to determine exactly without being there to help you...just check what you can... if you have additional questions let me know
Apr 07, 2010 | Kenmore 24032\24036 Top Load Washer
MY WASHER DOESNT SPIN OUT YOU HAVE TO KEEP GOING IN THERE TO ADJUST THE CLOTHES TO MAKE IT SPIN
i am assuming this is a top load. if so place a screw driver in the lid switch button, turn dail to spin and while holding the spin basket in place turn on. is it very easy to hold basket from spinnihg? if so you may have a slipping clutch. to replace, remove washer body by removing 2 screws from timer console. they may be in front or behind. remove body clips located under timer console and lift off body. next remove agitator. next remove 3 , 1/2 inch bolts at bottom of transmission. slide out. clucth is right there on top side of transmisson. part # 285785
can be purchased at repairclinic.com
Jan 29, 2010 | Whirlpool Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
My Whirlpool Cabrio 6600sw2 has lots of problems, it stops and flashes F50 over and over again, it also flashes many of the other codes, it doesn't fill with enough water and it is not washing the clothes...
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question****
Jan 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer will make noise while spinning. Took clothes out of machine tried to turn basket by hand. Basket will catch however it does not make any noise. If I spin clockwise it spins fairly free spin...
There is a clutch on the bottom of the washer that the tub sits in. Most likely it is wearing out. The machine will get worse, as if the tub is out of balance.
Jul 08, 2009 | Washing Machines
Sounds like a jet engine at full spin cycle
These things are notorious for sucking clothing under the the drum , it could cause it to be noisy spin slow and have drain problems . This is such a poor design . Try removing the drum and see if there is an article of clothing under it , mine sucked up a mans large shirt . Even if the drum seems to spin freely it still could be the problem .
Mar 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Noise at the *** end of the spin cycle
Hi pils,
As before I am not sure how your machine is built, but what you describe sounds like a problem with either the basket drive block or the brake system.
The basket is going to be mounted to the spin tube with some sort of aluminum adaptor and a nut, at least that's how most all our machines are made. Sometimes the drive block becomes unseated from the drive tube coming up from under the machine and will make a lot of noise when the brake applies at the end of the cycle. This is usually accompanied by the water not being spun out of the clothes as well as it should.
It may be the brake "jumping" when it applies to stop the basket.
What ever it is, it has something to do with the load being reversed when the spin stops. When the machine is spinning, the torque from the motor is transferred through the drive mechanism to turn the basket. When the motor shuts off, this torque is reversed as the momentum of the weight of the spinning load of clothes becomes the driving force and it is transferred back down through the machine until it stops.
Try turning the basket by hand in the direction of the spin and see if you can recreate the noise at at a slow enough speed to be able to pinpoint where it is coming from.
mike
Sep 26, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
24 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
