Question about Honeywell HZ-709 Oil Filled Radiator Heater
Tip-over switch location - Honeywell HZ-709 Oil Filled Radiator Heater
  • butlerjosh77
    butlerjosh77 Feb 24, 2012
    tried tipping it multiple times, but no-go.
  • 499 Answers
It will be inline with the power entering, meaning probably by the thermal overload, it may not be equipped with that , but rely on a thermal overload as the oil units surface temps are no way near the point of combustion if it does touch aything as curtains or rugs etc.
Posted on Feb 25, 2012
1995 ford festiva inertia switch location
Karl, Ford installs inertia switches in most fuel-injected vehicles.
In passenger cars, the switch is typically located in the trunk and is identifiable by the red button on its top. Switch could be behind a trim panel/ piece/door. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
OEM Ford Lincoln Mercury fuel cut off inertia control module switch XS7T...
1993 Ford Festiva No power at fuel pump relay
Aug 12, 2016 | Ford Cars & Trucks
Oil pressure switch for 1991 GMC?
Jeff, oil pressure sending unit/switch is located back of engine pretty much under distributor location a little to the driver side. Check the attached links,instruction and guides, Good luck
https://d3nevzfk7ii3be.cloudfront.net/igi/xgyZlxN2pvFheVol
https://ca.answers.yahoo.com/question/index?qid=20100131213343AA5JgO4
Fixing Low Oil Pressure Gauge
Oil pressure sending unit location
Apr 17, 2016 | Cars & Trucks
Bike wont start changed coil not it maybe tip over switch
Looks like it is attached to the battery box. On the rear side just under the drivers seat by one screw.
Apr 20, 2014 | 2000 Harley Davidson XL 1200 S Sportster...
Emission switch dodge journey
The switch is located on the EVAP Canister. But I would check for things such as a loose or leaking gas cap or a hose obstruction before I got replacing the switch. Just a tip.
Jul 24, 2012 | Emission System for Dodge Journey
Camera will not always power up even with newly recharged batteries. Appears to be problem with on/off switch
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jan 10, 2011 | Canon PowerShot A610 Digital Camera
How to remove high beam switch from 1994 silverado
The headlight dimmer switch is located about 1/2 way down the steering column. it is attached with 2 screws and is adjusted up against a rod that goes up and into the steering wheel housing. Tip. take a large plastic wire tie and secure the rod before removeing the switch so the rod stays in place when the switch is removed. after installing and adjusting the new switch just cut the wire tie and discard.
good luck. P.S. the ignition switch is in the same location. its the switch with only one black connector going to it.
Jul 10, 2010 | Chevrolet Silverado 1500 Cars & Trucks
The camera will not switch on
Jun 12, 2010 | Kodak EasyShare C1013 Digital Camera
My Canon Powershot SX100 IS is not switching on, dont know for what reasons. I changed new batteries, still not working. Pls help!
May 12, 2010 | Canon PowerShot SX100 IS Digital Camera
I need brake light troubleshooting tips for 1993 940 Volvo turbo
the BOO switch, (Brake On Off) located on or near the brake pedal
Apr 29, 2010 | 1993 Volvo 940
How to replace brake light switch?
How to Replace a Brake Light Switch
Parts:
1. Brake Light Switch
Tools:
1. Needle Nose Pliers
2. Flashlight
3. Combination Wrench Set
Steps:
Step 1 * Insert your key and turn the ignition switch to the ON position.
o Tip: Safety Tip:Always wear safety glasses when working on your vehicle. Wear other personal protective equipment (PPE) when necessary, for example latex gloves or safety shoes.
Step 2 * Turn your headlights on.
o Tip: Have an assistant check to make sure your tail lights are both working properly.
Step 3 * Step on your brake pedal and have an assistant check to see if the brake lights illuminate.
Step 4 * If all the brake lights are out, locate the brake light switch on the brake pedal linkage. Check for 12 volts into and out of the switch.
o Tip: Turn the key to the OFF position before starting any electrical work.
Step 5 * Disconnect the wiring harness from the brake pedal switch.
Step 6 * Disconnect the brake pedal switch from the brake pedal linkage.
o Tip: You may need to remove a c-clip to do so.
Step 7 * Remove the old brake pedal switch and replace it with a new part.
Step 8 * Reconnect the wiring harness to the brake pedal switch.
Step 9 * Repeat steps 1-3 to confirm that the repair has solved your problem.
Hope help with this (remember rated an comment this help) Good luck.
Mar 02, 2010 | 1993 Buick LeSabre
Honeywell HZ-709 Oil Filled Radiator Heater Logo
694 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
