Question about Vacuums
I'm Looking for a parts diagram for garlock Model 86 sweeper
Kenmore canister,model 116 52512201
Do check and make sure you've removed all screws as some are recessed then look at the front of sweeper to see if there are what I would call clips/hinges holding the bottom plate on gently seperate plat e from head Hope this helps
Sep 26, 2012 | Vacuums
Brush does not spin
Here's a parts diagram for the machine. It took me a bit to find it. Dyson doesn't want to give any kind of parts diagrams or such that I could find. Anyway, I'd say your drive belt is probably either broken or slipping. More than likely the first one. Just make sure that the Brush bar isn't all jambed up with hair and whatnot. Which you've probably already done, but I fixed my neighbors about a year ago, and her's was so clogged up that it would barely turn with the belt intact.
The diagram will also give you a good idea of how they go together and what parts will come off of what. Hope this helps.
http://www.searspartsdirect.com/partsdirect/part-model/Dyson-Inc-Parts/Vacuum-Parts/Model-DC25/3207/0645000/50033527/00004?blt=06&prst=&shdMod
Mike
Aug 08, 2011 | Dyson DC25 All Floors Bagless Upright...
My sweeper will not pick up anything,
Quite simply, if you don't own an air compressor
and I doubt many people do.
You need to thoughly blow out all vacuums after
every 2 or 3 uses
Then 1 or 2 times a year completely disassemble
them to clean the brush assy & keep it running.
If you have a bagless vacuum & most people probably do,
you have to have the compressed air to keep it working at all
When you say sweeper, I hope your referring to a vacuum
cleaner.
I haven't heard the word sweeper in 50 years
May 23, 2011 | Vacuums
Is it a good idea to lubricate any of the plastic parts on the 12amp upright bag sweeper? If so, what should I (and shoud I NOT) use to do so?
Old fashioned Vaseline ointment is probably the best lubricant to use. Works great and is longlasting. Don't use liquids/oils.
Apr 12, 2011 | Dirt Devil 12 Amp HEPA Filter Vacuum...
I have a Hoover WindTunnel Model # U6445-900. The on/off switch needs to be replaced and I'm not sure what parts are needed to repair it. Thanks Gloria
You can order any parts needed at the below link. This is a parts diagram. The switch kit doesn't have a part number here, but it's the second item on the list.
http://www.fiorijanitorial.com/p-447-hoover-windtunnel-parts-self-propelled-body-u6423-900-u6425-900-u6425-920-u6431-900-u6445-900.aspx
I recommend using the below site to order. It provides a clear picture of the switch kit.
http://www.sweeper-city.com/howiswkit.html
Mar 16, 2011 | Hoover Vacuums
My swivel sweeper 2 caught a carpet string and stripped the small plastic gear on the motor. How can I get another gear so I can repair my sweeper? Thanks, Ivol...
We were able to find every part ofr the swival sweeper exact for the gears you are looking for.
You can get a new complete sweeper head for 19.99 at:
http://www.swivelsweepercatalogs.com/
Mar 06, 2011 | As Seen On TV Swivel Sweeper Vacuum
Shark model V1700Z The handle broke off at the
Look it up online. I found a place that charges 7.95 for the part & 6.99 shipping. Get the Model # off the bottom. Mine is V1700Z. And look it up that way on Google or Bing. I think it's listed online as EuroPro.
My servers love this little baby, but they keep breaking that little piece. I understand that the rechargible batteries may wear out in a year, but I have yet to have a handle base last that long.
A Bissel sweeper costs more, clogs faster & does not do as nice of a job. so even if I have to replace it 2x a year, it's not a total, loss
Jul 14, 2010 | Euro-Pro Shark Cordless Stick Vacuum...
Shark Cordless Sweeper ModelVI1900SI
Solution #1 You helped me out Thanks a bunch!! I just have one thing to add when you go to the site on the left side click on Vacuums then click on Cordless Sweepers in the middle of page their you will see what Model you are looking for ...
Aug 12, 2008 | Euro-Pro S3325 Handheld Steam Vacuum
Vacuums Logo
66 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
