Question about Garden
Gas leaks out of small hole in carbuerator - Garden
2 Suggested Answers
  • 52 Answers
SOURCE: small hole on carbuerator opposite where gas hose connects leaks
perhaps there was a hose on/in it at one time cause it sounds like an over flow/vent.
Posted on Apr 18, 2010
Small hole on carbuerator opposite where gas hose connects leaks
Apr 18, 2010 | Garden
I have fuel dripping in the front near carbuerator
Most often the leak is at the fuel line connection at the carb. Replace this gasket and check the fuel filter at the same time. Do not use thread sealant! Do not drive it with this leak!! Frankster016
Nov 26, 2008 | 1984 Oldsmobile Delta 88
Engine dies when excelerating - more gas
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Nov 17, 2008 | Homelite Mighty Lite Lawn Trimmer
My echo260 and will not run right all new gaskets in carb willnot but25% on choke
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and clean with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Oct 30, 2008 | Garden
Gas blower craftsman leaf older modle
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Oct 27, 2008 | Craftsman 4 Cycle Blower/Vac
Leafblower
Oct 18, 2008 | Husqvarna Backpack Blower 25cc, 140 Mph,...
Stops running
if you bought it recenly and still able to return or exchange at store, try that first. if not, check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Sep 21, 2008 | Troy Bilt Tb70ss Gas Trimmer
Weed trimmer
Sep 02, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Bad Carb
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal. if that doesn't work have the carb repaired at a service center or replaced.
Aug 03, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi gas
Jul 05, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
