Question about Casio QT 6000 Point of Sale Terminal
How to switch off auto receipts
How to switch off auto receipt printing?
flexion1
  • 737 Answers
SOURCE: Royal alpha 601 sc cash register
Hmm. That is almost NEVER a paper problem, so forget about that.
It is always difficult to diagnose head problems without seeing the machine.
It can be a dirty thermal head, but that's not common unless something has been spilled on it. If you want to try cleaning the head, open the printer, and find the head. It is usually a small aluminium block that clamps against the paper when the printer is closed. it will always sit against the front of the paper. On that block, you will see tiny lines all very close together. They go to a connector at one end, and a thin black line at the top of the head. Wipe this black line firmly with a dry cotton bud.
Here is a picture of a thermal head:
http://www.jarltech.co.uk/ger_new/new/pix/products/web/printhead.jpg
Just above the light brown strip, you can just see the black line. This is what you would rub clean.
Otherwise, make sure the paper is clamping hard against the head while closed. If the clamp is not pressing with the same force at both ends of the head, then you will miss some printing. Try pressing against the back of the paper at the head while it prints, and see if it prints any more than before, then you know if your'e on the right track.
Hope this helps.
Mark.
Posted on Aug 18, 2008
SOURCE: casio TE-2200
Ok, currently u must have used the default 25 buttons as department keys for your items on the TE2200 right?
If u said, the CUSTOMER receipt prints out Department info, what kind of info are they? Can u type out a sample?
Usually, if ur biz sells fewer than 30 items, then the 25 department can be used as PLUs coz Department buttons can have a descriptor & price if u programmed it properly.
Posted on Sep 07, 2008
  • 14 Answers
SOURCE: Programming Logo on Receipts for Casio TE 2000
Sorry to inform u but u can not do customize logos with a TE-2000 if u had a TE-2200 then u could do customized logos. The Te-2000 has preset logos that u can select from like season greets etc. The settings should be in general features in the manual. Link sales totals haveing a PLU update a dept sales this in under the dept /plu peogram under linking if its offered Heres a contact for u had CASIO , try DWONG@CASIO.COM
Posted on Nov 19, 2008
flexion1
  • 737 Answers
SOURCE: I have problem with my casio pcr-272 register...I
Hi.
I don't have information on this model, but it sounds like it is one of the very low end registers. These machines can not have the printing turned off. They were designed to be journal printers or continuous receipt printers. You need to buy a machine with receipt memory to get this function. (PCR-T series and above)
Mark
Posted on Oct 12, 2009
  • 5 Answers
SOURCE: How to turn off cash register journal printing (casio CR140)?
If it's not in your manual you can't turn it off. Besides why would you want to turn it off. It's there to make it easier to find mistakes and to make it easier for you to catch your employees stealing from you. Leave it on; paper's cheap.
Posted on Feb 04, 2010
Hi the receipt will not print out but the journal is fine, do you know i can fix it?
Have you checked to see if the paper is in the correct way round, most tills have a receipt turn off mode. Consult your manual to find out how to switch back on
Aug 02, 2014 | Casio Cash Register
We just got a new xe-a102, we do not need to print receipts...how do you turn off that function?
To disable receipt printing:
  • Press the Rcpt/PO key in the OP X/Z position. This key toggles the receipt printing status ON andOFF.
  • To check the receipt printing status, turn the mode switch to the OP X/Z position or press the CL key in the REG mode.
  • When the function is in the OFF mode, the receipt off indicator “_” illuminates.
To issue a receipt when receipt ON/OFF function is set to OFF:
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function in the OFF
mode, press the RCPT/PO key. This will produce a receipt. If more than 50 items were entered, the receipt will be
issued in a summary receipt format. Your register can also print a copy receipt when the receipt ON/OFF
function is in the “ON” status.
Oct 27, 2009 | Sharp XE-A404 PC Desktop
How do i get it to stop printing customer receipts
The following is the process to stop customer receipt printing. It will also describe how to print an individual receipt on demand. Best of luck and thank you for using Fixya! Kindly return to rate this solution.
Greg
Receipt ON/OFF function
You can disable receipt printing in the REG mode to save paper using the receipt ON/OFF function. To disable
receipt printing, press the Rkey in the OP X/Z position. This key toggles the receipt printing status ON and
OFF.
To check the receipt printing status, turn the mode switch to the OP X/Z position or press the lkey in the REG
mode. When the function is in the OFF mode, the receipt off indicator “_” illuminates.
The register will print reports regardless of the receipt state, so the paper roll must be installed.
"To issue a receipt when receipt ON/OFF function is set to OFF:
mode, press the Rkey. This will produce a receipt. If more than 50 items were entered, the receipt will be
function is in the “ON” status."
Sep 24, 2009 | Sharp XE-A404 PC Desktop
Receipt won't print after paper change (and it IS thermal...)
not knowing what the model is I suspect the machine suffered a power surge or got a spill
Aug 26, 2009 | Casio Parts Cash Register PC Desktop
Change on/off receipt function to off
The following is the method to turn the receipt printing on/off:
OFF.
All the best!
Greg
Aug 01, 2009 | Sharp XE-A404 PC Desktop
Receipt not printing
I believe this might help, not exactly familiar with this exact model but here it goes.
When you use the printer to issue receipts, you can disable receipt printing in the REG mode to save paper
using the receipt ON/OFF function. To disable receipt printing, press the Rkey in the OP X/Z position. This
key toggles the receipt printing status ON and OFF.
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function being OFF
status, press the Rkey. This will produce a receipt. However, if more than 30 items were entered, the
receipt will be issued in a summary receipt.
Copy receipt
You can print a copy receipt by pressing the Rkey when the receipt ON/OFF function is in the “ON” status.
To realize this function, you must enable the function. Please refer to page 62 (Job code 63).
Nov 11, 2008 | Sharp XE-A404 PC Desktop
Casio TK2300 - receipt printing
Hi. It sounds like you have the receipt switch in the on mode. You'll probably find it can only do two receipts when they are called up when in receipt off mode, so slide the switch to off, then make a sale. at the end of the sale, press the receipt button once. Wait for print, then press it again. you can program it for a third if needed by doing the procedure I gave you, but use a 3 in place of the 2.
Mark
Oct 13, 2008 | Casio Parts Cash Register PC Desktop
Printing question marks on the receipt paper
It'll be the BAUD rate, try changing it in the till software to 9600 or 128200
Apr 29, 2008 | Star Manufacturing Star TSP700 Receipt...
Casio QT 6000 Point of Sale Terminal Logo
24 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
