Question about Winter Sports
1994 POLARIS 580 TRIPLE MISFIRE
THE MOTOR HAS FIRE,GAS,AND GOOD COMPRESION.BUT ONE OF THE CYLINDERS DOESN'T FIRE?
3 Suggested Answers
  • 35 Answers
SOURCE: 1997 Polaris XLT Triple. Do I really need to pull
I have 1995 and a 1997 XLT. i have rebuilt the recoil on the 95 and all it takes is the few bolts to take off the cover and take the pipe off. if the 97 is any thing like my dads 94, you may have to pull the engine up a bit, the bottom left bolt cant fully be backed out with out hitting the side of the belly pan retainer, all it takes to pull the motor up is one nut in the back of the motor mount, and one bolt off the front, and it will tip up enough
Posted on Feb 17, 2010
  • 46 Answers
SOURCE: i have a 1995 polaris 600 triple it fires but does
CHECK THE COMPRESSION OF THE ENGINE, IF IT IS AT ABOUT 120PSI AND DOES NOT HAVE A DIFFERENCE BETWEEN CYLINDERS OF 15% THAN CHECK YOUR FUEL PUMP. YOU DO THIS BY REMOVING THE SPARK PLUGS AND FUEL LINES TO YOUR CARBS AND PULLING IT OVER. IF FUEL COMES OUT OF YOUR LINES THAN THE FUEL PUMP IS GOOD. THAN I WOULD CHECK YOUR CRANK SEALS FOR LEAKING
Posted on Jan 06, 2011
93 xlt 580. Only runs on 2 cylinders sometimes at cold. Change plugs and works sometimes.. Not always same cylinder.. Any way to check stator,coil?
Ask The SnowMan Your Sledding Questions Answered: Off ...
www.off-road.com/.../ask-the-snowman-your-sledding-questions-answer...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris.../41045-93-xlt-carb-settings.html
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ... XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from www.snowmobileforum.com
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
Jan 04, 2016 | Cars & Trucks
Po303 misfire
this code identifies that the computer in your vehicle has picked up that cylinder 3 is not fireing properly so i would say change the plug in cylinder 3 if not cured change the plug lead if thes dosent work then distributer cap or the electronic distributer check all these things in this order its just elimination really
Sep 02, 2012 | Ford Taurus Cars & Trucks
Mulitply cyclinder mis fire
Basically this means that the the car's computer has detected that not all of the engine's cylinders are firing properly.
A misfire diagnostic code P0300 indicates a random or multiple misfire. If the last digit is a number other than zero, it corresponds to the cylinder number that is misfiring. A P0302 code, for example, would tell you cylinder number two is misfiring. Unfortunately, a random misfire code doesn't tell you specifically which cylinder(s) is/are mis-firing, nor why.
Symptoms may include the engine may be harder to start, the engine may stumble / stumble, and/or hesitate and other symptoms may also be present.
If you need this or additional details about DTC Fault Codes, feel free to contact us clicking the links.
Hope this helps and have a nice day.
Oct 26, 2011 | Mitsubishi Outlander Sport Cars & Trucks
When my car is ran on computer is has cose PO300 PD. What does this indicate?
DTC P0300 - Random/Multiple Cylinder Misfire Detected
A P0300 diagnostic code indicates a random or multiple misfire. If the last digit is a number other than zero, it corresponds to the cylinder number that is misfiring. A P0302 code, for example, would tell you cylinder number two is misfiring. Unfortunately, a P0300 doesn't tell you specifically which cylinder(s) is/are mis-firing, nor why.
Hope this helps.
Oct 03, 2011 | 2004 Chevrolet Malibu
Car is running rough, cylinder 4 is miss firing
at least try changing number 4 cylinder spark plug and wire, see if it makes a difference.
good luck !
Sep 11, 2011 | 2000 Mercury Grand Marquis
Have a 1994 Yamaha Virago 750. Just running on rear cylinder. Good compression and fireing.
Have you checked the spark at the high tension lead or at the sparkplug of the front cylinder?
To make sure the plug is in working order take it out, attach it with a wire to the cylinder, connect the HT lead and see if the spark really reaches the gap. if it doesn't or it's weak then the plug is shorted replace it.
Jul 20, 2011 | Yamaha FZ 750 FT (U.S Motorcycles
I have a 1995 polaris 600 triple it fires but does not want to keep running seems like not getting gas it will fire on full choke off it wont even fire
Dec 24, 2010 | Polaris New Genuine Polaris Snowmobile...
92 250 polaris indy lite snowmobile that back fires when pulling over
I have the same problem.....I believe it is a result of low compression. I have also noticed the problem to be worse in warm climate. Check compresion on both cylinders would be a good place to start.
Jan 24, 2010 | Polaris New Genuine Polaris Snowmobile...
Indy 500 motor knocks
could be bad gas. try running fresh gas. if that dont work you have internal problems. make sure it is firing on both cylinders though. when you start it cold you can feel if one is running hotter than the other. do a compression test. 120 psi is normal and no more than 10 lbs difference between cylinders. if one is low motor needs a rebuild
Jan 20, 2009 | Polaris New Genuine Polaris Snowmobile...
Winter Sports Logo
43 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
