Question about Sony KV-32FS13 TV
Sony kv-32fs13 chirps and flashes
When I push the power button on my Sony Trinitron kv32fs13 it chirps about six times and while it is chirping the standby light flashes two short and one long. After that it powers down and keeps repeating a four blink pattern. I already fixed many bad solder joints and nothing changed.
    Genius:
  • 1,139 Answers
Hello 0279737,
This problem is caused by a shorted Horizontal Output Transistor. I would suggest that you have this TV checked by a qualified TV technician. This type of problem requires dealing with dangerous voltages, and repair should only be attempted by a trained technician.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jan 08, 2009
My SONY KV32FS13 DO NOT HAVE IMAGEN ON THE SCREEN NO GET ANY CHANNEL OF TV OR CABLE ONLY WORK WITH DVD EVERY TIME WHEN TURN ON COME OUT NO SIGNAL.
Try pressing Tv/Video on the remote control and see if it doesn't switch input modes. If it doesn't, follow these steps:
1) Press the menu button
2) Navigate over to Channel Setup
3) Move down to Video Label and select it
4) Make sure none of the video inputs are labeled "SKIP". If so then do the following
5) Highlight the input labeled "SKIP" and select it
6) Use the up and down arrows and you should see a different name for the input. This will enable the selected input to be used.
7) Exit the menu by pushing the menu button on the remote.
8) Press Tv/Video on the remote and you should see the other stuff (cable, vcr, xbox, etc.).
Aug 15, 2010 | Sony KV-32FS13 TV
Sony KV 27FS16 TV does not power on
The chirping is the power supply trying to start. This is not a repair that I would recommend a novice attempt. PLease have this unti serviced. Expect a parts cost in the $20-$40 range for power supply caps.
Dan
Aug 31, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Model KV32FS13, blinking lights.
check the horizontal output of your tv set,if short you need to replace it.
Dec 09, 2008 | Sony KV-32FS13 TV
About Sony Trinitron KV-28LS36B
there are two possible defects in your circuit.
However, if the led blinks for about 10 times your tuner is defective 90%.
You will need a scope to check or you will need to take it in for service.
Oct 13, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Red light blinking
thear two ic that have gone bad this set need to go to a repear shop for this work to be done.
Mar 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron KV-32FS13 will not power on
The set should have a blinking standby light when you attempt to turn it on. Please update this with the count and that should give me enough to propvide some details.
Dan
Mar 19, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony trinitron KV-32FS13
The HOT transistor is shutting it down. (horizontal output transistor)
it cost about 8.00 for the parts and 100 for the labor.
you will require help from a tech.
Jan 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-36XBR800 36" TV
I get a black screen after power on...then a bright white light in the middle of the screen.Then the red light flashing and turns it self off.
Oct 27, 2007 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony KV-32FS13 TV Logo
235 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
