Question about HP DeskJet 3325 InkJet Printer
Test print great, document printing blurred
I justed used a refill kit to refill the black ink.The text was blurred and looked as though it was running out.Filled the cartridge and did a test print after running through the auto cleaning.The test print looked good.The black text printed fine.Then tried to print a Doc. from MSword and the text is again blurred and looks like its running out of ink?! more test prints and all is ok.then back to MSword and the same problem.(tried notepad and wordpad and the same problem)Checked for latest driver too. I have the latest. any suggestion? uninstall /reinstall?
  • 1 more comment
  • Anonymous Nov 02, 2007
    First wasn't printing with black ink at all, then re-installed the ink cartridges and test printed, printed great, made a copy, copied clearly. Then tried to print from word and e-mails, the printing is blurred.
  • kenb82 Jul 21, 2008
    I have a similar problem ... I have just put in a new re-manufactured ink cartridge (black) and before it was printing blurred/streaked. That tells me I am out of ink (or almost). Test prints are fine, nozzle check and head cleaners fine. Reset the printer, restarted the computer. And my printer HP D5160 is printing light blue ink instead of black from firefox and notepad. The other cartridge worked, but was just out of ink and was also remanufactured. Is this a problem with the cartridge or the printer? I have spent many hours on this and I still print in light blue.
  • Anonymous Mar 15, 2014
    Blurred printing
If someone has recently removed a paper jam, make sure that there's no little pieces of paper left in there that may have torn off.
Posted on Aug 02, 2008
I have the same problem. Cleaned the cartridge, changed it, every time I print a test page it works fine and when I print from anything else, from any application, including word, outlook, powerpoint, or notepad it doesn't work. The black looks like it is running out of ink. I tried reinstalling the driver, checking the connections, cleaning the printer itself and it still doesn't work.
Any suggestions?
Posted on Jul 14, 2008
The other thing that might be the problem is that the jets are cloged durring the test print you may have noticed small lines that are missing. these are th jets that need cleaning.
you could try and clan the printheads yourself. but i would sugest to take it to a cartridge refilling store like cartridge world and have them clean the print heads for you
Posted on May 13, 2008
  • 42 Answers
Try to heat up the printhead of the cartridge on hot water about 90degre celsius and clean the head whit a clean soft paper (toilet paper is great and cheap) and make a clean nozle on the printer software.
Posted on Oct 22, 2007
  • 624 Answers
Have you tried a new cartridge yet? I know it doesn't make sense at first but I suspect the cartridge has a problem and your test print isn't exercising the printer like the Word doc is. If the new cartridge works than the problem is probably poor quality ink, the hole you used to refill isn't sealed correctly or the cartridge or jets were damaged in some way.
Posted on Dec 01, 2006
4 Suggested Answers
JMuskovitz
  • 135 Answers
SOURCE: printing black squares in word.doc
It sounds like this is an HP driver issue. HP drivers have built-in "optimizations" (that unfortunately have bugs) for things like printing photos. Different programs (word, for example) try to take advantage of these optimizations in different ways. When they work, they give superior photo printing (faster, with more accurate color). When they don't, you get black squares. This is why "converting" it to PDF worked for you -- Word printed it through the PDF driver instead of the HP printer driver, then when you printed the PDF file, that program avoided those optimizations when it sent the images to the printer. Unfortunately, the translation caused quality loss. If your goal was to print out something like a "proof-sheet" of photos, you might try the free photo organizer at www.preclick.com. It will print these for you, captions and everything, and should be able to avoid the driver issues.
Posted on Apr 11, 2007
sagarjd
  • 95 Answers
SOURCE: How do I reset the ink levels?
We have an issue of missing or replace yellow cartridge. Please feel free to contact the HP support for replacement of the printer, if the printer is in warranty status. HP would replace the printer.
Posted on Jan 13, 2008
  • 3 Answers
SOURCE: black ink does not print
I have a problem about my printer here. it doesnt print black color even if i replaced it with new cartridge...anyone have solution about this pls help....joy
Posted on Apr 02, 2008
I have an HP Officejet 7210 All-in-One. I would like to know if there is any way to print a document that only needs black ink, even though a message always pops out that I have to remove and check the...
Hi
Black is not True black. It is slightly brown.
Printing in black uses mainly black but may also a tiny amount of a mixture of some of the other colours.
To minimize the usage of other colours:
HP Solution Center > Settings > Print Settings > Printer Settings > Color > tick Black Print Cartridge Only > OK.
HP ink can be expensive. It is possible to economize on HP inks in some cartridge formats by using Ink refill kits.
I hope this helps.
Aug 24, 2011 | HP Officejet 7210 All-In-One InkJet...
I have a Canon pixma mp990 Recently it has stopped printing with the larger black ink cartridge that is meant for printing text (PGI-220BK) All the other cartridges print fine I was using a non-canon...
It looks to me that your non Canon cartridge has blocked the print head. I see this all the time. Remember the compatables are not pigment based but just watered down ink so you can get it to flow through a syringe into the cartridge. This however is the classic outcome of trying to save a few pennies on an expensive bit of kit!
Jul 30, 2011 | Canon Office Equipment & Supplies
My printer does not print the test page the text. It only print the microsoft logo.
Most of the "text" on the "test-page" requires that the BLACK ink on the printer is working correctly. Refill or replace the BLACK ink-cartridge.
May 18, 2010 | Brother MFC 240C All-In-One InkJet Printer
Will not print text in documents, only headings.
When you go to print on your settings select print in black only. Did you buy Brother ink? Having old cartridges refilled or buying generic can pose a problem. I remember correctly brothers have a chip on the ink cartridge? I have gone through so many printers and its really not worth going any further, seems as though you have put sometime and effort in to this 100$ printer. Take 100$ & buy a kodak easy share all in one the ink is 15$ brand new.
Jul 24, 2009 | Brother MFC 490cw Color Inkjet...
Dell 926 injection refill kit didnt work
The ink your purchased is likely a cheap watered down version of what your printer is meant to take. You may notice that the ink smears when you rub the page directly after printing. Why you chose to use the blue and red ink to make black blows my mind. These refill kits are insanely cheap and buying the black could not have been much more. Not using black ink in the black cartridge would explain why your print is faded. Also, there is no way to reset the ink levels on this type of cartridge. As long as the printer still prints, just ignore the ink level indicator and print until the ink runs dry. I recommend Cartridge World for ink refills because they use high quality ink to manufacturer specified volumes while still saving you money.
Feb 05, 2009 | Dell 926 All-In-One InkJet Printer
Black ink
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Oct 13, 2008 | Canon MP610 Photo All-In-One Printer
Horizontal white lines through the text
Your ink cartridge (s) is dried up, even some new ones are dried up, even tho' they're sealed.
Some self-tests don't use black.
Sep 21, 2008 | HP DeskJet 6122 InkJet Printer
PIXMA MP500
The number 5 is a Pigment text black while the number 8 is a dye photo black. The text black is for black text mainly and the photo black is for use when printing photos. Since the text black is always running out it means you are printing a lot of documents in plain paper mode.
I recommend using QUALITY refill ink like Hobbicolors which is sold on eBay and will save you a bundle of money. The MP830 is a 5 ink printer so you need the 5 ink kit like the IP4300.
Dec 20, 2007 | Canon Pixma MP500 All-In-One InkJet...
Printer will not print in Black at all
Had a similar problem.
It turned out to be poor quality ink refills that I bought at the local mall. Found a good ink supplier who charges $4.00 per cartridge.
Try removing the ink cartridge and cleaning with warm water or a little alcohol and a clean soft cloth or swab in the area where the cartridge is seated
Nov 27, 2007 | Epson Stylus 880 InkJet Color Printer
Lexmark Z517 wont print black ink
I have a z600 that i use. If not used for about a month the ink does clog the print nozzles and eventually ink cartridge does dry out. To avoid this even if i dont have to print anything I run a diagnostics test that prints out a nozzle aligment test every two weeks.The great thing about this is that it uses very little ink.You can find this test in your software that was provided by Lexmark. This will keep your nozzles cleaned and you will notice this helps extend the life of your cartridge.
Sep 21, 2007 | Lexmark Inkjet Z517 Photo Printer
HP DeskJet 3325 InkJet Printer Logo
1,395 people viewed this question
Clive
Clive
