Question about Kenmore Washing Machines
Washer does not spin until lifting the lid and closing. You can hear the motor running but no spin. If you lift the lid and close it you hear a clack and then the tub starts to spin. Any ideas for a h
Model# 110.20712990
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 60 Answers
AM SUGGESTING A PARTIAL CONTACT ON THE DOOR LID
Posted on Feb 24, 2012
SOURCE:
catriver
  • 878 Answers
SOURCE: Drain/Spin won't work unless lid is lifted up
Curdy, it almost sounds like your lid switch is loose or fractured and the lid actuator is not making the switch. Check this out first and post back...Catriver.
Posted on Oct 20, 2006
  • 1073 Answers
SOURCE: Spin Cycle
you can check the direct drive coupling between the motor and the transmission, if the coupling is good and not broken then you have a transmission problem
Posted on Apr 30, 2008
aasc
  • 1606 Answers
SOURCE: Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Posted on Aug 02, 2009
  • 5 Answers
SOURCE: kenmore washer mdl#110.23832100 spin cycle motor
Its going to be only 1 of 2 or maybe both things, on your washer its going to be a faulty transmission that is stuck in nuetral OR will be a bad clutch/brake assembly that is stuck or has a broken finger that is catching after you slow it down but usually it would make a bad clicking noise if that was the issue so plan on the transmission. Its actually pretty easy to do if you have some mechanical ability. Another rare but possibility would be the block that holds the tub on the tranny shaft, but you would hear a bad noise also when you lifted the lid.
Posted on Oct 01, 2009
  • 1937 Answers
SOURCE: Kenmore series 80 won't spin. If you lift the lid
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
We had the same problem:
See the following Whirlpool Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Nov 10, 2009
After rinse cycle won't washer won't spin
Sound like it could be a lid safety switch.
May 24, 2014 | Kenmore 22422 Top Load Washer
Maytag won't spin until you lift the lid
There is a bad spot in the timer when this is happening!!! It may work sometimes but when It gets to that spot, it won't, until you lift the lid and close it back down!!! Replace the timer!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_c2f37a3461344482
Jan 20, 2014 | Maytag Washing Machines
I have a top loading whirlpool washer. For some reason it stopped spinning. The water is coming in and draining I can hear the motor running but it wont spin. Any suggestions of how I can fix it without...
it sounds like the drive cupler or also known as motor cupler,,,tilt unit back and look underneath washer,,recomendid to have someone hold it so it wont fall forward on you,,then look for a plastic and rubber oreo cookie that is the cupler,,located between motor and transmission,,,second issue and a bit easyer door lid switch or safty switch,,lift cover and slowly close if you hear a click it is ok no click means no good,,,it shold click at the closed point,,if not unit beleaves door lid is always open and will not spin,,,also if unit aditates but no spin it is normally the door swich as well www.myabcspace.com/washerwizzards
May 17, 2010 | Washing Machines
Kenmore washer mdl#110.23832100 spin cycle motor
Hello, looks like your lid switch is on it's way out, replace it...you will find it normally about half way down under the lid. If not there you will find it in the control panel on the right side next to the water level control. The reason it works some times and not others is because some times it fails to push the lid switch down far enough to engage. the lid switch is a safety divice inteneded to stop you opening the lid while in a high speed spin. If you have any other questions please feel free to comment again. Mike
Oct 01, 2009 | Washing Machines
I have The same problem OPEN Lid and works fine
When you lift the lid, did the motor stop? Do you know if it agitates? If the motor runs and there is no agitaion or spin, check the coupler connecting the motor and transmission. If it agitates and does not spin, it could be a basket drive assembly. The lid switch can also affext the spin cycle. Many reasons why it won't spin. These are just ideas to look into.
Vic
Jul 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't agitate or spin
If you mean that when the unit should be agitating or spinning the motor is running, and you lift the lid causing the motor to stop running, it sounds like the coupler.
Mar 31, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washer will not drain
By lifting the lid you are performing the job of the timer. In your unit you have a neutral drain transmission and the timer is programmed to end the washing cycle by stopping the motor. When it starts back up, it reverses and the transmission is in the neutral state. The water drains and after about 3-4 minutes, the timer is suppose to disconnect power to the motor thus stopping the transmission inducing the transmission to shift into spin. When it starts back up, it spins. So when you lift the lid, you pause the motor and the transmission shifts. Close it and it spins. Replace the timer and you will be fine. If I can help further.....
Waiting to hear from you,
Eric Campion
Feb 13, 2009 | Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Follow up
that's odd. the washer would not run in the spin cycle if the lid is lifted but in your case, it would run if you lift the lid.
check the lid also. it could have been damaged and the contacts were able to swap location or change status.
it should be close contacts when the lid is close and open when the lid is open. check the resistance.
tnx 4 using fixya,
drcool
Oct 21, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Spinning problem
Following your description the problem is with the lid switch. Get an access to it and find out whether something prevents his smooth movment,its has a loose wire connection or the switch is malfunction and should be replaced. Good luck!
Sep 04, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
60 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
