I have a Canon printer, Mod.# MP450. I am getting an "error code 5100" on the screen. Additionally, the off/on button is blinking green and the alarm is blinking yellow. I have been also receiving the low ink warning.
  • 4 Answers
Firstly, hi, any way check that ur ink cartriges are not low. if not you may have a software problem. Try uninstalling the software, taking the plug out of the back and try again. Install the software and turn the fax back on. It may work, if not u may have an hardwear issue, return it tp Canon with the warranty on the fax
Posted on Oct 28, 2008
Canon MP560 Gets error code 5100
Hello and Welcome
Error 5100 means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
  1. Turn off printer
  2. Remove both the cartridges from the printer
  3. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  4. Return the cartridges
  5. Turn on the printer.
Error will be removed
If the problem exist then then go to Canon authorized service facility for repair. You can also get support by Canon by phone, at 1-800-OK-CANON (1-800-652-2666)
Further assistance i am here to help
Please click on Four thumbs which are given below to this solution "if it is helpful"
THANKS & Keep Using Fixya
Mar 13, 2011 | Canon MP560 All-In-One InkJet Printer
Error 5100 on/off flashing and alarm flashing
Hello
Remove the error code 5100 1. Turn off printer. 2. retaining button Stop/Reset (red triangle in the circle) press button POWER - indicator it will light up with green color. 3. let go button Stop/Reset, continuing to hold POWER. 4. press button Stop/Reset 2 times, while holding POWER button, after which you will let go all buttons. 5. when indicator is lit BY Solid GREEN - press Stop/Reset 4 times! (this is the key) 6.turn off printer by POWER button, then turn on. 7. You should be set. If it didn't work, try it again, slowly. It WILL work!
Hope this helps, if so do appreciate my effort by rating the solution Good Luck, Cmptrlink
Dec 31, 2010 | Canon Pixma MP450 All-In-One InkJet...
ERROR 5100 CANON PIXMA MP 450 It does not work when off from KOPJUTER
Hello
Dec 17, 2010 | Canon Pixma MP450 All-In-One InkJet...
Error code 5100
5100 is service error. just follow this steps to fix this,
1. Hold RESUME then press & hold POWER
2. Release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
for reset waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 28, 2010 | Canon Pixma MP450 All-In-One InkJet...
PIXMA MP 450
try these steps ...
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Aug 30, 2009 | Canon Pixma MP450 All-In-One InkJet...
Canon PIXMA MP450 "Servic Error 5100"
Try this... it worked on my MP450... Turn the printer on and open the lid, it shows the cartridges. Now let the cartridges settle to the left. You can notice that the cartridges run on a metal belt. It might be dirty, mine showed a black stripe on it. Take a cloth, a cleenex will be fine and clean it up. Move the cartridges to the right (force them with your hand) and clean the part of the belt left behind them. Now turn it off, close it up and turn it back on. It should work
Apr 02, 2008 | Canon Pixma MP450 All-In-One InkJet...
Canon printer displays error
CANON
PIXMA MP450
Discharge of the code of the error of the overcrowding of sump - "pampersa"
1. You will turn off printer.
2. retaining button Resume/Cancel (red triangle in the circle) press button POWER - indicator it will catch fire by green color.
3. you will let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which you will let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!
6. you will turn off printer by button POWER.
Sep 18, 2007 | Canon Pixma MP450 All-In-One InkJet...
Canon PIXMA MP450
Try by holding the "triangle" button 5s, and release it.
Feb 16, 2007 | Canon Pixma MP450 All-In-One InkJet...
67 people viewed this question
jasbo
jasbo
