I just can't do anything and i just got the phone yesterday.
SOURCE: Can't receive calls on my ZTE warp
somthing wrong with your settings.
restart your cellphone,
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
SOURCE: cant send picture message with my zte warp
could be that the file data is too high or that the receiving phone doesn't get phone messages, try sending a text photo to a old phone you have you to your email. If that works then its probably just the receiving parties issue.
SOURCE: my zte warp sequent text just keeps sending but never actually sends the text
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Just an fyi, sounds like a common issue.. as I have the same issue all of a sudden. So all the mumbo jumbo about its "probably" this or that is wrong. It's the phone. Also I updated the software and firmware... n that just made it worse.
