When adding water some times it wont work it says prime
This can go out by draw out some hot water. However if this happens very often then you need to perform a descale.The brewer should be descaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. Descaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend descaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The descaling process involves using 48 ounces of undiluted white vinegar. Learn how to descale your brewer.
SOURCE: Love my Keurig B60. Bought the B70 with lager cup
You have to remove teh 5 screws from the bottom plate on the unit and they there is a small translucent corrugated hose fastened with a small ty-rep. Remove this hose and simply drain the stainless tank to the sink and replace the hose over the barb, slide the ty-rap back in place and it is EMPTY. Takes ten minutes start to finish. Phillips screwdriver and needlenose pliers are all that is needed.
SOURCE: keurig b60 coffe maker will not do anything.
These brewers are defective & Keurig is replacing them with new units @ no cost. Just call the toll free # (866-901-2739) & they will ship out a replacement in 3 to 10 business days. I own (2) of the B77's & they have both been replaced. Even if not the above mentioned model, call them anyway & see what they will do for you......
SOURCE: Keurig B60 coffeemaker stopped pumping water
This morning my Keurig sounds like it begins to pull water then stops. I tried to cut it off then back on. Still didn't work.Removed water from reservoir and K-cup and added pure vinegar. Ran machine several times without filter or Kcup by pressing cup selector several times. You must open K-cup holder and close each time. I had to do this about a dozen times before the water began to draw again. Flushed system by filling water reservoir with fresh water, and brewed just plain water until vinegar was gone.Works like brand new.
SOURCE: New Keurig B60 stopped working!
I had the same issue. I now believe that there was some "vapor lock" type issue. Mine would say the same thing, and i could hear the pump running, but the water level was not changing in the reservoir. I unplugged it, removed the reservoir, let it cool, then tipped it on its back for a few minutes, then on each side. Truthfully I was trying to see if there was some kink in the tubing. Couldn't find a problem, so set it back up and it runs great again.
SOURCE: The brewcover on my Keurig B60 broke. Both screw
Hi. go to keurig.com/parts and order what u need. J.
We have here also a video for this problemhttp://www.keurig.com/What-If-Brewer-Ind...
