How do you renew your IP Address? - Computers & Internet
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    are you familiar with Dos command?
    President:
  • 1,257 Answers
Goto start > click on Run > type 'cmd' > now when you come to dos prompt type "ipconfig /release " and then hit the enter key..Now type "ipconfig /renew " this will renew your ip address..If you want to change it manually then goto internet connection > select internet properties > open Tcp ip properties.You will get a dialogue box where you can change your ip address if it is assigned manually...
Regards
D I L I P
Posted on Oct 28, 2008
Reset ip address
If you use DSL or a cable modem you could try (as mentioned above) resetting your IP address. Go to the RUN command, type "command"
There you can type:
/ipconfig
(shows your current IP)
/ipconfig /ALL
(more details such as when the current IP "lease" expires)
/ipconfig /renew
(renews your IP address)
/ipconfig /release
(drops your current IP)
Bell High Speed users need only reset the modem to obtain a new IP. You can check your current IP address from http://www.ip-details.com
IP Details com Find your IP address Information
Jan 14, 2014 | Lexmark E260dn Laser Printer
Renew ip address
To renew your IP address in Tablet:
Remove the SIM card and then insert it (or) reset the WiFi if it is a Dynamic IP address it will get change.
Before and after changing check the internet IP address from the site IP-Details.com .
Jun 30, 2013 | Tablets & eReaders
Renew ip adress
OK. You need to reset the modem to renew ip address from the current one.You can't reset the ip address using the router reset method.So reset or switch off the modem and then switch on it.Then new dynamic ip address will assign will be generate for your connection.Check ip address using the site Ip-Details.com before and after resetting modem...I hope you will get the answer by my reply.
Jun 15, 2013 | TP-LINK Computers & Internet
Release ip address. I want to be seen on the internet with a different IP address. When I plug the cable modem directly into my computer I can release and renew and get a new IP with the network card, this...
The easiest way to release and renew your IP with a router that doesn't have that feature is to unplug the modem (not the router) for a few minutes - overnight while your sleeping to be sure.
May 23, 2011 | U.S. Robotics MAXg USR5461 Router
How to release and renew the IP address in Win Xp.
Go to start
Go to run
type cmd
to renew the IP command is
ipconfig /renew
to releaed the command is
ipconfig /release
May 03, 2010 | HP Pavilion dv6000z Notebook
How do i renew the ip adress for my linksys router ?
Goto your web browser.
Enter 192.168.1.1 and put admin for both username and password.
The admin screen for your router should have a MAC address clone feature. If you enter the MAC address (which is found on the main page of the admin screen) and change the last two boxes, it will renew the IP address. Don't change the first 4 of the mac. When putting different numbers in the last two, it has to be hex (1-8 for first digit and a-f on the second digit).
Hope this helps,
Mar 05, 2010 | Linksys Wireless-G WRT54G Router
What's an IP address?
internet provider address. ring your provider and they will sort it
May 24, 2009 | Acer Aspire One PC Notebook
Cannot renew ip address
You may have to perform a DNS Flush..Sometimes with wireless, the laptop cache in the IP address that is used when you are connected wirelessly. You can Flush this down the toilet by performing the following command at a DOS Prompt by going to run, and type in CMD, then input the following command in. Once this is done, try to renew your IP again!!
C:\>ipconfig /flushdns
May 12, 2009 | Computers & Internet
Need to renew ip address for my emachine T3516
just right click on your local connection on the desktop by the clock and click on "repair". this should clear the cache and renew the IP addy and DNS for yur connection. OR
Follow these steps to quickly release and/or renew the Internet Protocol (IP) address of a computer running Windows XP, Windows 2000, or Windows NT. Here's How:
  1. Click the Start menu button on the Windows taskbar.
  2. Click Run... on this menu.
  3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
  4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
  5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
  6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
Tips:
  1. If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
  2. To bring a computer back onto the network after moving it to a different location, or experiencing an unexpected outage, first release, then renew the IP address. Computers on DHCP networks often (but not always) re-establish network connectivity automatically
Oct 28, 2008 | Gateway Computers & Internet
E Machines not renewing IP Address
suspect your cable modem is looking for the MAC address of your compaq's NIC. if you run IPCONFIG /ALL on the Compaq (Start run, cmd <enter> then IPCONFIG /ALL <enter> , you can get the 12 digit MAC address.
In the router setup, there should be an option to CLONE MAC address, put in the MAC address of the COMPAQ. Then release and renew the IP address in the Router from the cable modem. The router should then get a valid IP address from the cableand you should be able to connect both systems to the router and surf.
Sep 03, 2008 | Computers & Internet
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
