Question about Baxter OV300G Stainless Steel 27817 Watts Toaster Oven with Convection Cooking
Ov300g flame no call for heat
Burner fires up for 5 seconds shuts off and module flashes twice for flame no call for heat
  • 43 Answers
The ignition module could be faulty, could be a loose wire, bad control board, bad temp probe, this is something you'll want a technician to take a look at, you'll spend more money trying to fix it yourself.
Posted on Jul 15, 2012
What ever setting I use Toaster, Pizza etc the oven runs for 3 minutes and stops and in the read out window E 1 comes on the screen
Unplug the unit for at least 30 seconds. Plug in, set clock. When making pizza punch in the time you wish it to run, such as "7:30" then "start". Watch carefully the first time to see how much time it takes to cook to your liking.
Sep 03, 2014 | Oster Digital Countertop Oven With...
What should one do if the toast in oven catches on fire? please respond.
Switch the over off at the wall and unplug it first. Remove the burning toast with steel tongs or something similar that wont burn you and place toast in sink in water to extinguish flames if there are any
Your oven should be okay to use again under the following circumstances
  1. The toast was simply left in there too long, hence it caught on fire
  2. There was only smoke or a very small flame and the interior of the oven was not blackened
If in doubt or the flames were of reasonable size, or the interior of your oven has been blackened with smoke, do not reuse the oven without getting it checked over by a licensed electrician. There is a risk that you may have overheated and melted some of the wiring.
May 10, 2011 | Black & Decker Toaster Ovens
How do you set the clock on the delonghi DO400 toaster oven
  1. Press for 5 seconds the TEMP./SELECT/CLOCK but- ton (7) (the hours flash on the display).
  2. Press the TIME/TOAST COLOR buttons (8) to the desired time (hours). The time set will begin blinking on the display.
  3. Press the TEMP./SELECT/CLOCK but- ton (7) (the minutes flash on the display).
  4. Press the TIME/TOAST COLOR buttons (8) to the desired time (minutes). The time set will begin blinking on the display.
  5. Press the TEMP./SELECT/CLOCK but- ton (7) to confirm. It is pos- sible to press the button at any time during cooking to display the current time (the display shows the time set).
  • If you wish to change the hour on the display once it has been set, press the TEMP./SELECT/CLOCK but- ton (7) before proceeding to set the new time as described above.
  • It is possible to display the current time even after starting a function, by pressing the TEMP./SELECT/CLOCK button (7) (the time is displayed for 2 seconds).
Oct 14, 2010 | DeLonghi DO400 Toaster Oven with...
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    Oven gives air flow fault message . I did check all the safties ,motors everythings looks fine any suggestions
    Check your combustion switch to see if it has a screw to adjust the amount of vacuum needed to prove the air flow. Adjust it down. Bypass the switch to see if the problem continues, if it does it is in the PCB or the ignitor control. If the problem goes away then replace the combustion relay switch (proves air flow).
    May 13, 2010 | Baxter OV300G Stainless Steel 27817 Watts...
    Igniter on Wolf Stove clicks continuosly
    Depends what Wolf model you have, if you have model AS48KI and the flame looks really high, (it supposed look like a flower), most cases the top burners are misaligned, you can try to re align the burners by turning them around. afterward if the burners are still clicking it may be ignition problem. Have fun.
    Aug 14, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
    Non stop ignitor clicking
    The thermostat tells the ignitor what to do. So, I believe the problem should be takrn up with the heat foreman
    Jul 29, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
    Recall: I bought a Euro Pro Convection/Toaster Oven w/Rotisserie and it caught fire today from a non-food related problem. Is there a recall on this item? There was no food in the oven and it was...
    Today I was warming up a baked potato in mine it was on 350for about 20 min when I went to shut it off the nob melted right off the ovenit was so hot I could not shut it off had to unplug it and the top of the ovenwas also very hot, is there any recalls on the MODEL # TO161
    Jul 11, 2009 | Toaster Ovens
    Ttm602 toaster,browning one side ,even on highest setting , of 5
    The problem is with the heater (bars) connection, which would be under the cover on the left side. Caution ! You're dealing with electricity which may cause a fire. That said, the solderless connecters on the heat elements and the wires probably need replacing,that's all,I did it to mineand it worked. DON'T forget the caution!!!!
    Sep 10, 2008 | Toastmaster TUV48 UltraVection 1400 Watts...
    Toaster does not work!!!
    I investigated further (took it apart again to satisfy my curiosity) and it appears that one of the top heating elements (the front one) is open (burnt out). I cannot see an easy way to replace it (contacts are spot welded) and I can't find a place to buy the element. If I could it probably won't be worth it since a new oven costs $25 at Target (B&D TR0490W). Too bad since the oven looks like new. I assume the upper elements burn out more frequently because heat rises from the lower elements and adds extra heat at the top.
    Jul 02, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
    Baxter OV300G Stainless Steel 27817 Watts Toaster Oven with Convection Cooking Logo
    Top Baxter Toaster Ovens Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Dave
    Dave
    Are you a Baxter Toaster Oven Expert? Answer questions, earn points and help others
