Question about Air Tools & Compressors
Need Parts List for Multi Power Industrial Equipment Air Compressor 2.5 HP
SOURCE: install reed valves hitachi air compressor need pics
I believe in your model of air compressor, when you take apart the head portion to your compressor you should have four reed valves. When you have it apart, there should be two "grooves" on the bottom "plate" and two "grooves" on the top plate (where the reed valves go). the bottom part is easy (as you should already know) to set in the reed valves, but as i have also found out, as you probably have, that its a little more difficult to line up the other reed valves to thier "grooves" on the upper "plate". What you do to make sure that they stay in place is dab a little oil or grease on the reeds and place them in the upper "plate grooves" and carefully set the upper plate back in place where it goes on the compressor. It will hold them in place long enough to install it on the compressor and the small amount of grease that was there will quickly be burned up with no effect to the opperation to the machine.
Sorry, long winded explanation. hope this helps and if it didnt get to you soon enough i hope it helps out in the future. :-D
Posted on Jul 10, 2009
  • 583 Answers
SOURCE: Need help with parts for air compressor.
Hi ,Crazy horse. information perfect . with a14.5 inch pully on the compressor and amotor running at 3450 rpm you can get with a 5 inch pully----1189.6 revs per min ---- with a 4 1/2 pully ---1071..6 revs per min so you hve to decide whether you want the max or the min from that compressor... If it was for me I would use the 5in . and set psi. with the cut in ---cut out switch ,this will be a good unit ,,if you need any more help don`t hesitate to call and thanks for the opportunityto help it is great when some one gives you good info .you did well
Posted on Aug 12, 2009
Testimonial: "Thank you so much! I had searched every where and no one could answer that question. I feel comfortable now! Job WELL done!"
SOURCE: Jobmate 3 gallon air compressor parts list/diagram
Good luck on this one. I own 2 jobmate compressors, one I bought and used very little before it blew apart and another a freind gave me to use for parts. Guess what the same part failed on both and I know of at ;east three more that also failed the same way.
I gave up trying to deal with Canadian Tire and Jobemate and junked them, as though they weren't junk to begin witn. You get what you pay for. I have a new Hausefield compressor and it is fantastic.
Posted on Jun 22, 2010
  • 36 Answers
SOURCE: Clark Air Compressor Problem
air leak?
Posted on Jul 30, 2010
Brokenish
Hey tony you got a headache there is a Pn# 1-877-888-3872 to order parts direct From sunrise or known job mate i talked to Canadian tire about this product they dumped 3 years ago because the compressor heads were not verey reliable to many returns or repair problems Not worth fixing
Posted on Nov 08, 2010
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
How do i find parts for my mastercraft model no:NS563 air compressor?
I find nothing for Mastercraft but boats.
I suspect your compressor is a common (Chinese) manufactured compressor as most. Probably uses common parts. If you know what part you need I'd search the www for local parts reseller (like Granger see link below) and take the part in. Grainger Industrial Supply MRO Products Equipment Tools
Bill, sells a book, but also has a good troubleshooting guide. Troubleshooting Your Compressor
Jan 19, 2015 | Air Tools & Compressors
NEED PARTS LIST FOR UST 1106C AIR COMPRESSOR
quisiera saber como puedo conseguir para mi compressor de aire model 1106c 2 hp 4.6 gallon ( LA VALVULA UNILATERALISM QUE ES DE LA LISTA DE PIEZAS LA # 50 .
Jan 06, 2012 | Air Tools & Compressors
Where do I go to order repair parts?
Air Compressor Parts & Accs - eBay
www.ebay.ca > Business & Industrial > Light Equipment & ToolseBayAir Compressor Filter Regulator Industrial Quality 0 to 160 PSI. C $41.83; Buy It Now; +C ... Power Ingersoll Rand Impact Wrenches, Ratchets & Tools. C $104.65.
Clarke Air Compressor Parts‎
about.com/Clarke+Air+Compressor+Parts‎rating for about.com
Clarke Air Compressor Parts. Search Now!
Over 85 Million Visitors.
Nov 04, 2011 | Clarke Power Products Inc AC2000 2HP 6...
Once compressor reaches 125 lbs. pressure, the relief valve opens and releases pressure. the motor then tries to engage but cannot come to full speed because of back pressure I am trying to find and...
Generally, the safety/relief is set to 140 to 160psi. The pressure setting is stamped on the side of the valve. Replace the valve if it will not hold stamped pressure(cost about $6 at Lowes Lumber).The pressure switch is usually set at the factory to 120 - 130 psi. The unloader part of the pressure switch will not release backpressure unless it reaches set cut-off. The 1/4 inch line attached to the pressure switch connects to air discharge tube at the intank checkvalve (brass valve). The safety valve should very rarely release pressure, only when pressure switch malfunctions and allows pressure to reach up to 160psi. The tank will hold over 300psi so dont worry about the 160psi safety. I am not sure about your exact model number or brand, however most small compressors work the same and share similar parts. For manuals to other similar compessors to to www.dewalt.com. Here you will find manuals to dewalt and porter cable compressors. I prefer to use generic replacement parts from www.grainger.com or from Lowes Lumber. These parts will cost less than factory replacement. If you need to replace the pressure switch, use SquareD brand from grainger. Watch fitting sizes and pressure range. Good Luck on your repair.
Apr 03, 2009 | Northern Industrial 2 Hp Twin Tank...
When i switch on my compressor it wont start, it produce humming.
Maybe you have the wrong voltage or line frequency? Your description leaves much to be desired. Is it old, new, used? Was it running and then suddenly stopped?
Mar 21, 2009 | Northern Industrial 2 Hp Twin Tank...
Compressor Support
Home Use: Compressed-air power tools can dramatically decrease the amount of time spent on a project. Many homeowners will use smaller, portable units (either hand-carried or wheeled) that move easily from the garage to the house, yard or roof. Common air toolsAir Tools such as brad nailersAir Nailers, reversible drillsAir Drills, and impact wrenchesAir Impact Wrenches require about 0–5 CFM (Cubic feet per minute — units in which air flow is measured). It's important to know if the compressor you purchase will drive the air tool you'll need for your project. For example, smaller air nailersAir Nailers run on 2 to 5 CFM at 70 to 90 PSI, while larger shearsShears, sandersSanders and polishersPolishers require up to 10 or more CFM and 100 to 120 PSI. Business Use: Air compressors used for business/professional applications are often classified “industrial grade.” They're packed with features that let you take on more demanding jobs with more horsepower, more CFM, more PSI and more (longer) run times. Though some industrial-grade compressors are portable, many are stationary units with large-capacity, ASME certified air tanks (up to 120 gallons), greater HP, more CFM air volume and faster recovery time to run a wide variety of air tools for as long as you need them to do the job.
Aug 27, 2008 | Jenny Products Inc AM780-HC4H 4 Gallon...
Air Tools & Compressors Logo
474 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
