Goodman model cpke60-1b - Heating & Cooling
What do I replace my Goodman Model CPLE24-1C with
goodmans 2 ton. going any larger would require changing orfice and or coil.
Apr 11, 2014 | Goodman Heating & Cooling
I'm trying to figure out how old my unit is. Make:Goodman Model:CKL36-1d Serial #:0201462038
get ahold of manufacturer (Goodman) give them model/sn and they will be able to tell you the year the unit was made.
Jun 06, 2011 | Goodman CKL36AR36 Air Conditioner
Can't find the manual for my Goodmans TV. I need to re-tune can you help? It is model number LV1570FVT.
Goodmans doesn't list that TV. Please review this link and check the model number again.
http://www.goodmans.co.uk/productlist.aspx?cid=BLCDTV&language=en-GB
Here are all available user guides for Goocman TVs:
http://www.goodmans.co.uk/supportcategory.aspx?cid=UGTV&pcid=UserGuides&language=en-GB
If you don't see your TV model, select one that is "close" and see if the manual helps you re-tune your TV. They probably all re-tune the same way.
Sep 30, 2009 | Televison & Video
Model gsc13042aa goodman central air unit sevice manual
just go onto goodman website and download pdf file if that doesnot work call godman with model #
Jul 01, 2009 | Goodman CLQ36AR49 Air Conditioner
Service manual for Goodman Heater # PGB036100-1
sounds like that model # is for the A/C coil or its a heat pump air handler. In any event I am not aware of any "repair manual" that is put out by Goodman to the public. They have classes on their equipment but they are geared to the professional serviceman.
If you would like to descrobe the problem, I will try to help you.
Nov 03, 2008 | Goodman GMS90703BXA Heater
No model number...
If this is a split system, look on the side of the furnace, no luck? remove the front panel. look for a little plate or sticker label inside there somewhere. If you are in California, there is a Goodman (A.K.A.) Janitrol, in Ontario CA. They may be able to help. (sorry don't remember phone #)
Dec 27, 2007 | Goodman GDS80904BNA Open Flame Heater
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
