Question about Neff 24 in. S5456 Built-in Dishwasher
Will not clean back dishes - Neff 24 in. S5456 Built-in Dishwasher
    Problem Solver:
  • 7 Answers
Try a good dishwasher cleaner. one for hard water .arms build up scale inside.slowing pressure needed for back wall.
also how you stak helps
Posted on Feb 24, 2012
Dishes not cleaning properly
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Nov 16, 2011 | Kuppersbusch 24 in. IG6344 Built-In...
Dishes come out with white chaulky film all over them.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Dec 17, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag dishwasher Model # DWC4910AAW SN A9830611KY Doesn't clean dishes anymore...leaves white soap (Cascade) residue on all; doesn't clean dishes anymore.
msbcox -- Check for residue in the strainer under the lower washbar. Remove the lower dish rack. Strainer is under washbar. Sounds like it is not draining properly. Write back if you need more help. -- SWT
Aug 04, 2010 | Maytag Dishwashers
It's not cleaning the dishes. Sounds fine, but
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Feb 18, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
How do I take the cage off so I can clean the dish?
If you don’t mind VOIDING YOUR WARRANTY, there’s a point at the bottom of the grate where an elongated spine pokes through a tiny hole in the metal dish. Use a screwdriver to pry the metal retaining lip of the dish back from that spot, and pop the grate out by applying pressure to lift the spine out of that hole, and the grate from the dish. BUT the problem is getting the grate BACK IN the metal lip when you are done cleaning. I opted to modify the grate slightly. I used a hacksaw to cut a tiny 1/8-inch section of the outer ring away from the bottom of the grate and removed the retaining spine in the same spot (from inside the ring) to allow enough flexibility to be able to squeeze the grate together to get it back in the dish’s metal lip. Now I can get the grate in and out, but when in, it is still secure enough to be able to lift the heater by grabbing the top of the grate to carry it.
Jan 01, 2010 | Presto HeatDish Compact Heater
How to clean dish? Safety grate covering face of dish does not appear to have a way to remove it so backed on dist can be removed and heat dish can be returned to near new condition. Thanks, Mike
This is the answer I got from Presto. I cleaned it with window cleaner, wooden spoon and paper towels. Dish works great now.
Buzzer sounds when heater:
- is tipped
- rests uneven on floor
- is too close to furniture or wall
- has too much dust on parabolic dish
The most common reason is that the parabolic dish is dusty.
To clean the heater:
1. Unplug the heater and clean it when it is cool
2. Spray a cloth with an all-purpose cleaner such as 409
3. Wrap the cloth around a long handle such as a wooden spoon
4. Wipe between the grate from the outer edge to the center
If you have further questions, please let me know. Or call us at 1-800-877-0441 Monday through Friday 8:00 a.m. to 4:30 p.m. Central Time.
Dec 21, 2009 | Presto HeatDish Compact Heater
Dishwasher just doesnt get dishes clean anymore. some food left on dishes. there is always water pooled in bottom of dishwasher, but I've cleaned it out well at the bottom
Check your vacuum breaker. Its some times mounted up on the back of your sink. If it gets stopped up it will cause your dish washer to not drain or clean properly. Good luck.
Aug 30, 2009 | Dishwashers
Does not clean the dishes
Hello, I can help you. With the dishwasher empty, toss in two cups of white vinegar and run the machine on its longest and hottest cycle. This will thoroughly clean the machine.
Now put in a load of dishes, be sure to run the kitchen faucet til the water is as hot as it will get and then start your machine.
Aug 11, 2009 | Dishwashers
I don't pre-clean dishes - never have. Recently,
Jul 20, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
Neff 24 in. S5456 Built-in Dishwasher Logo
51 people viewed this question
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
