Question about LG LSC26905TT Side by Side Refrigerator
WHAT SHOULD MY FREEZER TEMP BE SET AT - LG LSC26905TT Side by Side Refrigerator
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 60 Answers
3 IS GOOD,,,,,,TO ENABLE THE THERMOSTAT TO REGAIN REST
Posted on Feb 24, 2012
What does the temp display on the freezer tell me?
unless this is a dedicated freezer only and not a side by side or over/under , there's no way it's going to get down too 0 degrees inside a warm home , nope not gonna happen
also its not good for you to set this there as compressor wont cycle properly there and entire freezer will ice up , then believe it or not it will get warmer not colder wastes a lot of power as well
Sep 10, 2015 | Freezers
Freezer too cold
Is this a model=>FGHC2342LF Sounds like the freezer=> 240597203 Thermistor may be defective??There should be one in the freezer that regulates the temp and this one may be causing the compressor to run continious and you may not be getting the correct reading from freezer. Have you seen this?
Sea Breeze
Jan 06, 2014 | Frigidaire FGHC2342LF Gallery Series...
How to set temperature on GE Profile PSS26NGPA WW?
Press and hold temp up button then press quick freeze button at the same time, your temp settings will be displayed on display for fridge and freezer, fridge temp is + and freezer -, cycle by pressing quick freeze, set temps by up and down temp buttons, once done, push vacation button. your temps are now set, turn the unit off for 2 mins the turn on. reaction is now set and normal. regards Russ
Jul 03, 2012 | GE Refrigerators
Jenairrefridgerator model jcd2292ktb, what is the temperature for freezer and refridgerator
If you want to set the temperature your Fridge/Freezer should maintain, you need to set the Freezer to between -19c and -23c, however if you will be keeping Ice-cream in this freezer then it's best to set the base temp @ -21c minimum, -23 preferable, or the ice cream may begin to break down (very slowly I might add). The Fridge needs to be set to a maximum Highest temp) of 5c, any higher and the food will not stay as fresh and bugs will be able to breed, preferable temp is approximately 3-4c.
Jun 20, 2012 | Refrigerators
What is freezer and refrigerator temperature suppose to be set on
Jun 20, 2012 | Jenn-Air JSD2789GES Side by Side...
Last two weeks refrigerator temp goes anywhere from 30-35 degrees and freezer temp -5 to -1 degrees.several times a day we attempt to set temp to reccommended temp, but no success.we do not have mannual,...
fridge temp should be 30 to 35 degrees/freezer -1 to -5 f or between 2 to 5 C for fridge and -18 to -22 C for freezer several times a day is too often...... try once every 2 days without opening door in between checks....
Feb 11, 2010 | GE Profile PSW26P Stainless Steel Side by...
Upper freezer temp. alright Lower refrigerator to
Sounds like the airflow balance is off. When you turn the aircontrol to max what you are actually doing is starving the frig compartment of cold air, cold freezer, warmer frig. It is recommended to set both controls to middle and see if it helps the problem.
Jul 30, 2009 | Whirlpool Refrigerators
Freezer temp
Hello I can help with this problem , You can set it to the factory setting thats normaly in the middle , wait 24 hours for temps to equalize and check temp in freezer with an accurate thermometer it should be -10 to +10 deg. Far. to adjust temp move dial up or down only one digit at a time and wait 24 hours on each adjustment until its at a correct temp.
Dec 30, 2008 | Kenmore 53612 / 53614 Side by Side...
Ice at the bottom of the freezer
It sounds like the freezer has leaking door seals and air is getting in to the freezer compartment. Your temperatures are set about right. Regards
Oct 02, 2007 | LG LRFD22850 Bottom Freezer Refrigerator...
LG LSC26905TT Side by Side Refrigerator Logo
115 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
