Question about Mitsubishi WS-55511 55" Rear Projection Television
Volume moves up and down by itself and then stays max volume
I have 2 issues.
First the volume will go from 0 to max a few times then stay max. The volume box stays on the screen all the time.
Second this morning the power button stopped working and the remotes will not shut off the tv. I unplugged the tv now it will not come back on.
I have no idea what parts I would need to order to repair. If it is even worth repairing.
    Master:
  • 538 Answers
Sounds like the main system board is kaplooiee..
well..do you like to dig into this sort of thing?..it will take around 400 and 2 to 3 hours..
Posted on Oct 28, 2008
  • A Womans Computer Man
    A Womans Computer Man Oct 28, 2008
    what vintage is that unit, anyway..
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
Cannot lower volume on my sony tv 32L5000
The electronic volume control section circuit is faulty. The system control section tries to adjust the volume, by sending command voltage to the volume control section circuit, but this circuit do not accept or process it. Troubleshooting to this type of fault, is skilled one. Contact any service technician, or the service center.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Timeslide" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 20, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
Volume controll is going nuts.
Hi Manuel
I suppose the problem of your unit is memory, sometimes this problem can be fix by applying service mode, but if not, then memory should be replace and I would advise you to send your unit to service center.
Jan 16, 2014 | Televison & Video
Volume control
Poltergeist in volume circuit is the diagnosis. Try a hard reset of the receiver to see if that does the trick with the electronics.
Sep 01, 2017 | Mitsubishi WD-82737 82" DLP TV
My HK 1005 incresases volume to max by itself
I had the same problem; got rid of it by changing the baateries of ma remote control.
Jun 27, 2010 | Harman Kardon DPR 1005 Receiver
Have an Hitachi 60sx12b. the sound meter bar stays on. can manually adjust the sound up but will go back down to 0. tv remote or sat. remote doesn't work at all. Please help
It sounds either volume down button is bad that turns volume down on its own or system control chip got defective and decreasing volume level.
Press volume down button on tv front and check is it working properly.
Let me know to find out further info to solve the issue.
Thanks.
Jun 05, 2010 | Hitachi Televison & Video
My Kenwood DPX-4020 suddenly turns up to max vol
you probably have a bad switch. you need to use a multimeter and check the resistance of your volume up switch, if less than a few meg., the switch is bad.
Oct 05, 2009 | Kenwood DPX-4020 CD / Cassette Player
Denon AVR-1604 too large front speakers blew the avr
Try disconnecting the speakers at the receiver. turn it on radio or any other source and turn up the volume. If the receiver still shuts of, there is an internal capacitor issue and needs serviced. More than likely though, it's a speaker problem. If the speakers were underpowered and at max volume, chances are the damage was to a voice coil in one of the speakers. If the receiver continues to stay on without being connected it's ok. check your speaker wires as well. Frequently loose braids on wires touch each other and create very little resistance until turned up, more volume, more resistance. Then the receiver puts itself into protection mode so no damage will occur. If you need further help, post a comment and I can help you troubleshoot further.
Aug 17, 2009 | Denon AVR-1604 Receiver
Volume auto turns down
hi i downloaded windows 7 and now my touch volume control does not work what should i do
May 28, 2009 | Computers & Internet
Problem with the volume
Two things can cause the problem your set has,one is the volume up button in the front of the set is pushed in too far and it has the momentary switch active all the time or the cleaning solution you use to clean the face of the tube has dripped down thru the lower edge of the frame into the switches creating a short and making again the switch active all the time.If the cleaning solution went down to the switches they will need to be replaced.If you are familiar with tv service you can remove the back cover and check that the button is not pushed in or it has corrosion built into.If you are not too familiar with tv service be safe and take the set for repair,if they come to your home it will be more expensive. Let Us know if you need more information.
Oct 25, 2006 | RCA 27V530T 27" TV
Mitsubishi WS-55511 55" Rear Projection Television Logo
104 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
