Question about Dell E173FP 17" LCD Flat Panel Monitor
Replaced LCD Screen
The monitor I had developed large blocks of dead pixels in it, so I disassembled the monitor and looked at the LCD panel itself and discovered that it was a LG.Philips LM170E01 (A5)(NC). I looked online and found a replacement screen that was a almost brand new LM170E01 (A5) LCD Panel. When I disconnected the old LCD Panel at the 30-pin LVDS connection, and plugged in the new panel, the screen did not work. The backlight lit up the screen and I can tell the controls worked, but the image is not correct. There are vertical lines across the entire screen and no adjustment makes them disappear. They vary in color, but almost seem to be in black and white. When I plug the old monitor back in, it still works, there are just the large spots of dead pixels on it as before. I'm not sure what the difference between the monitors is. Any information would be greatly appreciated.
  • 46 Answers
There 2 diffrent LVDS connectors normally on the monitor. a plat one with contacts on one side and a female connector that accepts pins on the end. I would make sure the connectors match. If that does not fix it I would change out the logic board. Check www.lcdrepair.us for instruction videos and parts for that unit.
Posted on Jun 21, 2008
How can you fix dead pixel?
FIXING DEAD PIXELS These WEB site gives instruction on removing dead pixels, but there is no guarantee it will work except replacing the LCD screen.
http://www.makeuseof.com/tag/best-software-solutions-to-fix-a-stuck-pixel-on-your-lcd-monitor/
http://komku.blogspot.com.au/2008/03/dead-pixel-on-your-laptop-screen-how-to.html
Nov 27, 2012 | Computers & Internet
LG W2261 VP HDMI problem, 1920:1080 doesnt fit right, there is 2cm dark screen at the edge of the display Got drivers installed for analog -vga and digital -hdmi Tried the buttons on monitor...doesnt...
This problem seem to be the LCD screen have dead pixels or a bruise spots on the LCD screen itself that why you have dark spot or spots on the LCD Screen.This problems can't be repair because this problems doesn't causes by the electronic circuit boards.Tried move the monitor as an angles to the right or to the left might help some lessen the dark spot on the LCD screen that all you could do.If this problems is a very dard bruised spot will not help all or if it is dead pixels on the LCD screen itself.
Nov 21, 2012 | Computers & Internet
What does it mean by dead cells?
I assume this is related to your LCD monitor.
I think you mean dead pixels. The LCD monitor has tiny pixel elements, one for each red, blue, green color and each one of these colored pixels are turnes on by a transistor. When a transistor fails then the colored pixel it controls does not light up. This is a dead pixel and it shows up as a tiny black dot.
If the screen displays a blue screen, a dead blue pixel will appear as a tiny black dot in the blue screen.
You normally would not notice a few dead pixels unless they are grouped together.
Sep 20, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
Black marks on screen i think it needs a degaus but dont know how to do it
LCD monitors do not need degaussing. They operate in a completely way to CRT monitors.
Tiny black marks are most likely dead pixels, if the black marks are large then the LCD screen may be damaged (cracked glass).
This type of damage cannot be repaired simply, the screen needs to be replaced.
I suggest you put your money towards a new LCD monitor.
Sep 03, 2010 | LG Flatron L1710M 17" LCD Monitor
What are the possible disadvantages of computer monitors?
Monitors, otherwise known as displays or screens, currently come in two formats: LCD and Trinitron ("the boxy thingy").
LCD pros: Flat, low radiation (as far as I know) LCD cons: displays can either come with or develop "dead pixels" - pixels that remain a solid color or display black, are very fragile - pressing the display surface is not "healthy" for the display
Trinitron pros: deep color Trinitron cons: relatively moderate-to-medium radiation
Both types of displays can suffer from "screen burn" - if an image is displayed for too long (several hours/days) it will permanently "burn" itself into the display and be visible at all times.
Jul 15, 2010 | Computers & Internet
My Syncmaster 225bw suddenly developed a horizontal line about 1/4 of the way up from the bottom. It looks like a single line of bad pixels. Is this possibly the screen itself, is it an inverter problem?...
If the inverter is bad you will black screen, the lines can be caused by failed T-CON board which is part of the LCD panel assembly. You may try reseating the ribbon cable on the LCD panel.
Please see LCD panel in my albums here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
May 14, 2010 | Samsung 225BW LCD Monitor
Large dead pixel space that is spreading.
Panel will need to be replaced that will be only cure would not be cost effective to do so
Jan 04, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
I have a fine black line that goes across my screen I rebooted an
This is a dead row of pixels. The LCD panel itself needs to be replaced. It would be far cheaper to replace the monitor.
Sep 29, 2009 | Dell UltraSharp 1704FPV 17 in. Flat Panel...
Black spots appeared on 17" LCD Monitor-SyncMaster740N
you might have what you call "dead pixels" or a "stuck pixel" try a simple test like this one now it is not the most creative one, but it does help to see if that is the case. u might be able to Fix a STUCK pixel, but unfortunately you can not fix a "DEAD pixel" simply because it is DEAD.
try this website for simple fix instructions.
if is dead pixel what you have, if u can live with it, great, if not , it might be a good reason to get yourself an another monitor.
Good luck
Jun 17, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Dell E173FP 17" LCD Flat Panel Monitor Logo
900 people viewed this question
Clive
Clive
Alun Cox
