Question about Makita 6932FDWDE 14.4V Impact Driver
Makita electric drill
The wires on my drill are totally frayed. It still works but looks pretty scary.   Can you instruct me how to replace the wire? I really like this drill and would like to repair it.   Thank you. Hannah
  • Stuart
    Stuart May 11, 2010
    What drill is it, and which wires are frayed? In most cases you can just get some cable/wire from a toolshop/repair centre and with the tool unplugged rplace like for like. If you ask at a repair centre they could probably supply you with a wiring diagram if it is a manufacturer that they deal with.
  • 2,176 Answers
The header lists 2 different tools but if you give me the model number I will find a cord set for you and the wiring diagram that you need. If you also give me the area (US only) I will try and find someone local that has what you need.
Posted on Jul 20, 2009
My Makita 6402 drill stopped working. I press the trigger and it does not make any noise at all
You will need to have someone take it a part and see where the problem lies.
Start with the electrical plug, both the wall plug and inside the drill where the wire attaches to the switch.
Often, the switch is the problem, but the wire itself can be bad, if the cord is worn.
There is such a thing as the wire separating inside the cord.
We will hope the unit is not "toast".
God bless your efforts.
Oct 25, 2016 | Makita Drills
Variable speed not working, the trigger is either full on or off. speed switch 1 or 2 works
Replace the switch because a power mosfet inside is defect
650583-6 look for that switch partnumber also ferify it because this is for the model in the netherlands but most time its the same by Makita and its not to expensive will succeed to replace succes. but be careful when pulling out the wires using a thin watch screwdriver to push the unlock holes next to the connector contacts.
Nov 01, 2015 | Dewalt Makita Bhp452 18v Cordless 1/2"...
Plugged my Makita Makita 7.2 18 volt ni-mh or li-ion battery Charger into 24O volt by mistake HELP
The circuit board is protected by means of a fuse and a varistor. The variatistor looks like a painted coin (penny-size) with a wire attached on each side. This is connected in parallel of the chargers main supply. The varistors job is to shortcircuit the main power (this causes the fuse to nlow) in the event of too high voltage, thus protecting the rest of the electronics.
you need A new varistor, new fuse and some basic soldering skulle.
enjoy :-)
Feb 10, 2014 | Makita 18V LXT Lithium - Ion Cordless...
I have a Makita BMR100 radio. Stock speakers are 3.25" 8 ohm with an 8 watt 8 ohm amplifier. I replaced speakers with better 4" 4 ohm but they're not really compatible with an 8 ohm amp. I...
Buy an 8 ohm speaker and wire it in series-parallel look up images of of combination series-parallel wiring this allows wiring all speakers and keeping the 8 ohm loaf on the amplifier. Should get more linear volume between speakers. Not sure if replacement is worth it, those speakers are pretty good and work well with rain and jobsite conditions. I am planning to install some 8 ohm half inch tweeters on my Makita radio and using the series parallel wiring. Plead note series-parallel wiring is not series wiring or parallel wiring. It is s totally different way of wiring it that uses both names.
Jun 02, 2011 | Makita BMR100 Radio
I used my makita 18v 1/2" cordless drill then charged it and put it away. When I tried to use it again a month later there was no power. I tried to recharge the battery but red light would only stay on...
WOW! Count yourself very lucky. Most batteries don't last half that time. The newer battery probably has a lower amp hour rating than the first one. When replacing the battery (and you must replace it) look for the one with the HIGHEST amp hours - which is usually written on the battery or packaging. You can also ask at a Batteries Plus store if they can re-build the original battery for you- since the unit is so old, and Makita might not make replacements for your drill. You could rebuild the battery yourself,it is only 12 AA or C batteries wired together, but ni-cads can be dangerous when soldering and can explode if you slip up. Best bet is to get a new or rebuilt battery.
Jul 02, 2017 | Makita 18V 1/2"CRDLS Drill Kit
I cannot register my new 3/8 inch B&D electric drill as instructe
OK try going to Blacnanddeckercom and in the header you will find a link on the right hand side to register your new tool. Let me know if you need more assistance.
Feb 12, 2010 | Black & Decker Drills
Why doesn't my HP 1501 Makita hammer drill work
The problem was the cord at the base of the drill. The wires were broken, cause by constant bending. After souldering the wires, the drill works perfectly.
Thanks.
Jul 28, 2009 | Drills
Maikita bhp 451 transmissions
the gearbox is good,what the problem is,is the nylon speed change ring that goes on the outside of the gearbox that takes the power of the gearbox,the end of the teeth,about 2mm or less strip making only noise when in 2nd or 3rd gear,,they sell it with the new gearbox and charge you,,,,,but you can buy it separatly,,,the part no.419558-2,,pick key 01820914
Nov 02, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita 6932FDWDE 14.4V Impact Driver Logo
70 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
