Question about Dynasty DGRSC 60-6G Gas Kitchen Range
Dynasty 60" range
Trying to increase the flame size at the burners?  Thoughts or help please
    Scholar:
  • 162 Answers
By unscrwing the orifices, this are where the burner mets the valve that turns it on.
Posted on Dec 09, 2008
Flame height on my 36 " 6 burner Viking Range Top
remove the knob, the center shaft is hollow, slide in a small blade screw driver to adjust the flame cheers
Dec 11, 2013 | Viking VGRT360-6B 36 in. Gas Cooktop
Kenmore lp gas sealed burner stove,when opening or closing the oven door the top burners decrease in flame size and go out frequently.
This seems like a pressure regulator / flow problem. If you are running more than one appliance from bottled gas this can occurr if the supply pipe is not of sufficient size. When 'wafting the door' you are increasing air flow to the oven burners which in turn will consume more gas to balance the burn, this starves other burners that are running at the time.
Cure; increase regulator pressure (remove the foil cover to expose the screw) with the top burners alight adjust the screw 1/4 turn at a time until the flames are bright blue at heart and organge tipped. Increase as much as you can without the falme distorting away from blue/orange. If this doesn't cure it you may need to increase the size of your supply pipe to 15mm so that the volume of gas is greater and then split it off to normal lpg pipe to each apliance thereby creating a more even flow of supply. Often a system using say heating and gas fire is perfectly fine but add another appliance like a cooker or change your cooker to one which has more powerful burners and you can expose weaknesses in the flow system.
Jan 15, 2011 | Kenmore Kitchen Ranges
When I turn on the range I am getting orange flames on all 6 burners. The problems seems to be intermittent but when it happens the flames are wild unless the burner is on simmer.
try it with the window open and again closed. if flames are good with window open you will need fit an air brick in the wall or unblock the brick you have.
Feb 15, 2010 | Dynasty DGRSC 36-6 Gas Kitchen Range
Dynasty gas range - orange flames
It is normal, it will disappear after a little while, when you bang on the burners, particle fell off form inside of the burners and it caused the orange flame. Yellow flame means not enough air or burner is internal clogged.
OVEN FLAME TOO HIGH
HI, To adjust the size of the flame, turn the orfice clockwise to make it smaller. you can also try and adjust the air shuttle on the burner.
Are you trying to change from natural to LP?
Please let me know if I can assist you further.
Thanks
Vic
May 24, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Low flame on gas top burner
Hello Husky!! We can help you get the correct parts to repair this wonderful range. You sin=mply need another burner head to be replaced. We have parts and will make sure we get this out to you asap so you get back up and running soon. How many burner heads would you like to order? Please call or email us asap and we'll get these parts right out to you. We look forward to working with you. 972-859-0929
Feb 01, 2009 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Explosion in heating chamber when oven is lit.
the air adjustment is open just a little to much the flame will have a hard time to go to the other side, try closing the vent to the burner just a Little bit and try the oven,another problem that i see is that the ignitor is getting to weak to ignite the flame on time.
Dec 09, 2008 | Dynasty DGRSC 60-6G Gas Kitchen Range
Dynasty DGRSC 30 Gas Kitchen Range parts replacement
Have you tried contacting Jade Products who manufactures Dynasty ranges? 866-607-5694
Sep 23, 2007 | Dynasty DGRSC 30 Gas Kitchen Range
Dynasty DGRSC 60-6G Gas Kitchen Range Logo
71 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Jaime Hernandez
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
