Question about Sony CDX-540RF 10-Disc CD Changer
Reset button on Sony 10 Disc CD changer
Hi. I had the same problem. The magazine will eject, but on the hand held control inside my car, it is saying RESET. Where is the reset button?? Can you help?
Thanks
    Problem Solver:
  • 5 Answers
THE RESET CAN ALSO BE FOUND BEHIND THE REMOVEABLE FACE PANEL, MINE CAME UP E-99 I JUST HELD RESET IN FOR 5 SECONDS AND IT IS NOW WORKING FINE HOPE THIS HELPS.X
Posted on Aug 27, 2009
  • 3 Answers
There is a reset button the the converter box that all the wires go into.
Posted on Aug 25, 2009
The magazine for my CD 12 disc changer will not eject nor will it play ant CDs. It seems to be getting power as the light inside the slide door lights up as open to eject the magazine any suggestions? It...
theres usually a reset button hidden inside the door on the cd changer. use a paperclip to reset the device. sometimes theres a reset on the controller part of the cd changer Up by the radio ( if you have tha type )
Jul 31, 2010 | Pioneer Car Audio & Video
My eurovox radio/cd/tape player displays error message E-99 when i switch to cd
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
Oct 03, 2009 | Car Audio & Video
I have the same problem! I use to get on just fine.
Try doing a hard reset. Make sure you have everything backed up on your pc since you will have to do a hotsync once you do the hard reset. OK to do a hard reset do this:
1. Press and hold the power button.
2. While holding the power button, use the tip of the stylus ( or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your hand held.
3. Wait for the Palm2.gif Powered logo to appear, and then release the power button.
4. When you see the message that warns you about erasing all of the info on your hand held do one of the following:
a) Press UP on the 5 way navigator button on the bottom of your hand held to finish the reset and show the touch screen2.gif.
b) Press any other button to do a soft reset.
5. When prompted , tap to align the screen, and then set the language you want to use on your hand held. A screen appears showing the Palm logo and a progress bar. From there continue to set up your Palm and then do a hot sync. You should be able to reset a password if you want one. Best wishes....Hope this helps.
Sep 18, 2009 | Palm TX Handheld
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
Magazine won't eject
HI, the load motor has failed in your changer and , you will have to replace this. its part of the loading dock assembly and it turns all the gears associated with the loading and playing procedures.
If you are hearing continuous clicks, this will be the reason for the failed motor.
May 21, 2009 | Jensen XCH6RF 6-Disc CD Changer
Can't eject cd magazine - E-99 error message
I put a small pin in the reset button a few times and that then got the catridge to eject.
Apr 14, 2009 | Car Audio & Video
6 dsc changer stock radio 99 ford explorer cddj error
I've had GREAT success by resetting the changer. Try unpluging the changer with the power ON, wait a few, then plug back in. It's not hard to remove. Can I assume that you did NOT misload or install any CD' upside down? If not, then proceed with a reset. Can you eject the magazine? If so, proceed with reset. If you can NOT eject the magazine, then you will need to "open up the can" and do a manual eject with power assist by moving the gears while pushing the eject button. Sounds like a lot, but for me it's easy. Remember patience!!
Larry T
Winona Lae, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 26, 2009 | Pioneer DEH-P6800MP CD Player
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Jul 01, 2008 | Sony CDX-T69 6-Disc CD Changer
Sony CDX-540RF 10-Disc CD Changer Logo
938 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
