Question about LG WM1814CW Front Load Washer
LG WM1814CW Front Load Washer bearing and drum assembly required
Innitially this machine was very quiet and worked well, however it started getting louder and louder so I called in a repairman and he said it was a bearing and drum assembly which would cost $500 for parts and then labour. Unfortunately I could not afford that. I am currently using an old machine I had stored away. Is there any way I can get this fixed at a reasonable price or break it down for parts so that it doesn't all go to landfill? The machine is appx 7 years old and worked well until this. I did have some error codes at times and it was usually to empty the drain filter or uneven loads, but nothing came up for the final usage when it just stopped working. Any input is appreciated. PS I live in Canada.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 60 Answers
UR MACHINE NEED A NEW BEARINGS AND AN OILSEAL........IF U HAVE TECHNICAL KNOWLEDGE I CAN HELP U,,,,I LIVE IN LIBYA,,,,,,,U MOST HAVE , HAMMER. 10,12,13 SPANNER AND A SCREWDRIVER,,,,,,
Posted on Feb 24, 2012
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
Our washing machine is making a loud sound when spinning and a chemical smell is coming from within.
check transmission spin bearing and spring,. check tub bearing, lastly check for worn clutch assembly
Mar 06, 2015 | LG WM1814CW Front Load Washer
Lg washer makes noise only during the agitation cycle
It sounds like the tub bearing is causing the problem. To replace this bearing is a massive task so a professional might be required to do the job.
Sep 20, 2014 | LG WM1814CW Front Load Washer
LG front loader washer squeaks when drum is rotated manually
Possibly front boot seal give it a spry with sillicon spray.
Apr 27, 2014 | LG WM1814CW Front Load Washer
Washing machine vibration
I had same problem. It was actually wearing out the rubber gasket on front door. It ended up being the spider on back of drum. They corrode pretty good with the front loaders.
Mar 28, 2014 | LG WM1814CW Front Load Washer
Drum will not spin
You will need to change the rotor and stator,
Jul 21, 2010 | LG WM1814CW Front Load Washer
LG Tromm wm 1814cw makes loud noise
You will need to remove the back cover plate of the machine and locate the large pulley at the end of the drum. Remove the belt, then the pulley and you should see a bearing housing. Some models require a bearing and housing replacement, while others can simply be repaired with a bearing replacement alone.
Go here, and find the nearest Dealer for your part.
http://www.1stsourceparts.com/contact_us/branch_info.asp
Or you can try ordering direct from LG. If you are as handy with tools as you say, this should be a fairly easy job.
Mar 23, 2010 | LG WM1814CW Front Load Washer
LG WM2032HW Washer
You may have a bearing problem and it will need to be looked at by a qualified LG technician.  That is a big job and will require total disassembly of the tub and drum assembly to get to the bearings.  There are 2 of them.
May 06, 2008 | LG WM-2277HW Front Load Washer
LG WM1814CW Front Load Washer Logo
105 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
