Question about Garmin StreetPilot c310 GPS Receiver
Garmin Streetpilot c310 Battery / Receiver problem
1. When i turn off the power to the cradle, the unit does not give the option stay on via battery..this has happened only in recent days
Not sure if this would have a bearing but...was away on hols and the unit was left in the car, temps did drop to 4°C at times but the unit was in the glove compartment...
2. Since this battery issue has been happening, the receiver is taking a lot longer to locate the satellites...
Would it make any performance difference to switch to WAAS / EGNOS instead of Normal (based in Ireland)..?
Thanks
The lighter coloured facia part pops off if you gentley prize it off with a knife or small screwdriver. You can then see the screws that how the outer housing together. unscrew them to get to the battery. The battery has a aluminium cover over it with the batttery stuck to it with tape. Unscrew the top fixings of the cover and prize off the battery. I then cut the wires near the battery (one at a time) so i could solder the new battery in the circuit.
Posted on Apr 13, 2010
Battery not charging and takes several minutes to locate maps also clock shows wrong time.
C310 is slow in finding maps. If the battery is not charging it may be time to change it. However this is not an easy job.
Oct 30, 2009 | Garmin StreetPilot c310 GPS Receiver
Garmin C530 won't power up. I fully discharged battery and recharged. Unit gets warm while charging, still won't turn on. Replaced battery, charged..gets warm...still won't turn on. Are there any other...
How old is it and does it get quite a bit of use
If so then consider replaceing the battery
Ebay has a good selection from a wide range of reputablesellers and very good prices
Check Here
Aug 26, 2009 | Garmin StreetPilot c530 GPS Receiver
Showing low battery
the battery is failing, the life span of the garmin battery is around 2 years, contact garmin for a replacement battery.
Aug 25, 2009 | Garmin StreetPilot c310 GPS Receiver
How to reset the Garmin streetpilot III deluxe
DO NOT DO THE FOLLOWING unless you know why you are doing it. If you press and hold ROUTE when the unit is powered up, you do a master reset. This will clear all data and user variables. Unlike previous Garmin GPS receivers, this will NOT clear the temp compensation curves and non user data.
If the MENU key is pressed and held when the unit is turned ON, an undocumented test screen is activated which incidentally measures battery voltage, temperature and a few other things. Pressing QUIT (several times) from the test screen gives you a set of display test screens.
Mar 27, 2009 | Garmin Streetpilot III Deluxe GPS Receiver
Voice Prompt
My husband had the same problem with his i2 Street Pilot.
He went to the Garmin web site and downloaded the latest
updated software version. You can then chose the language options, too.
Dec 31, 2007 | Garmin StreetPilot c310 GPS Receiver
Mi streetpilot shut down when it's not pluged
Dead Battery. Garmin will replace battery for a charge if the unit is out of warranty.
Aug 10, 2007 | Garmin StreetPilot C330 GPS Receiver
Problem with garmin c510 st pilot
the update will not load... i had this problem.. i just took the memory card out and re-started the unit... works fine again... Dave
Aug 03, 2007 | Garmin StreetPilot c310 GPS Receiver
Garmin StreetPilot c310 GPS Receiver Logo
253 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
