I have a Xerox 7232. how do I change the waster toner bottle?
SOURCE: How to reset waster toner bottle full Xerox 3535
I used a cotton wool bud to clean that clear window previously mentioned, then re-inserted..
Posted on Sep 28, 2008
SOURCE: Xerox 7232 and As400
016-799 is a printer paper conflict error. All you have to do for the AS/400 to print, is to make suree that tray 2 in the printer is set up to do landscape printing. There has to be at least one tray for portrait, and one for landscape in order for the AS/400 to print.
Posted on Sep 17, 2009
  • 239 Answers
SOURCE: How do I change the waste toner bottle?
The waist sump is in the Drum Unit.
If the messege says to replace sump unit, either the drum unit has to be replace(Copy Cartrige) or, if you wish to do this,
remove the copy cartridge and remove the front black cover with the small rectangular metal cover. I beleive they are 3 - 5.5 mm black bolts.
On the back there is a black knob that has to be rotated, to swing the drum out. On the front there is a brass spacer that has to be removed.
Pull it off and pull out the drum. the top of the drum has to come off and the bottle comes out. Vacume out the toner into a waist bag, or dump the toner in a plastic bag. its your choice.
If not buy a new drum unit.
The machine needs to be reset in the maintaince area of the menu.if you cannot find it, the machine will come up with the replace waist sump.
You will need to find this, or call Xerox to have a service repair person enter diagnostics to remove it from the machine.
Posted on Oct 16, 2009
  • 79 Answers
SOURCE: xerox work centre 7120 message
You can either dump out the waste toner into a garbage bag, or replace the whole toner collector. If you decide to dump it out yourself, you need to make sure that the container is extremely clean prior to reinstalling it into your copier, as sensors on the copier end detect the level of used toner by optic sensor.
-David.
Posted on Nov 04, 2010
lbrown1806
  • 488 Answers
SOURCE: I need a list of erro codes and definations for
When a fault occurs, the touch screen displays a message on how to clear the fault. Some faults indicate customer maintenance, while others require the attention of the Key Operator and/or System Administrator. The following table represents some of the fault codes and their corresponding corrective actions. These may appear in the Print Queue or Faults List available in the Machine Status mode.
002-770 The job template could not be processed due to insufficient hard disk space. Delete unnecessary data from the hard disk.
003-750 No document was saved for the double-sided Booklet Creation feature. Check the setting of the double-sided Booklet Creation feature.
003-751 The specified document area is too small. Select a higher resolution or a larger scan area.
003-754
003-755 An error occurred in the document scanner. Reset the document, and scan again.
003-756 The fax document is completely white. Check that the original is not white, or that the front and back sides have been reversed.
003-760 Incompatible features are selected in the document scan conditions. Check the selected options.
003-761 The paper size in the tray selected by auto tray switching, differs from the paper size in the tray selected at the tray selection. Either change the paper size for the tray, or change the paper type priority setting.
003-763 An error occurred when reading the Gradation Adjustment Chart. Place the chart properly on the document glass.
003-780 Compression of scanned data was unsuccessful. Lower the resolution or reduction/enlargement ratio to reduce the data size, or send the document in
smaller segments.
003-795 The reduction/enlargement ratio exceeds the setting range when the scanned document is enlarged/reduced to the specified paper size. Directly enter the reduction/enlargement ratio, or change the paper size.
003-981 Stapling mixed size documents is available only for documents with the same width. Cancel the staple feature or reset the documents with the same width.
005-210
005-275
005-280
005-283
005-284
005-285
005-286 An error occurred in the document feeder. Contact the Xerox Welcome Center.
Posted on Jan 16, 2011
Where is used toner bootle dsm 635
it has not waster toner bottle on the machine, the waster toner is being recycled in the photo-conductor unit (PCU) so if the machine show replace the waster toner bottle just clean the PCU of the machine on the drum upper area
Sep 21, 2015 | Gestetner 3532 4532 Dsm635 Dsm645 Toner 4...
How can i resolve error 010-333 for xerox 7232
Fuser unit change problem continue nvm change 744-004 change value 0
Feb 09, 2014 | Xerox WorkCentre 7232 VSE All-In-One Laser...
Where is the waste toner bottle on the xerox workcentre 5030 located at?
  1. Open the Waste Toner Bottle Access Door. The door is located on the left hand side of the machine, behind the Bypass Tray.
  2. Pull the colored cap from the top of the bottle and screw the cap onto the opening of the bottle.
  3. Remove the used Waste Toner Bottle and dispose of it according to the instructions contained in the new Waste Toner Bottle box.
  4. Unpack the new bottle from its box.
  5. Install the new bottle in the machine. Make sure that the bottle is placed correctly in the machine cover.
  6. Close the Waste Toner Bottle Access Door.
Mar 30, 2011 | Xerox WorkCentre M-24 Color Copier
Xerox work centre 7120 message say change waster toner, I found where it is but how do I change it
-David.
Nov 03, 2010 | Xerox WorkCentre M-24 Color Copier
Here's what I did.
Emptied the waste toner cartridge. Left it out of the machine. Held the microswitch (located to the right of the optical sensors) in the "cartridge in" position with a paperclip. Printed one document. Inserted the waste toner cartridge. Error now gone!
GCC.
Aug 27, 2008 | Xerox DocuColor 3535 Copier
242 people viewed this question
jasbo
jasbo
