Question about Tascam DR-1 MP3 Player
My tascam dr 100 gives a 'writing failed' file error' message and stops recording
While recording using the built in mics, the rec light flashes and I get a 'writing failed' message 'press enter'.
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Try using a smaller memory card. This only happens to me when using a 4- or 8-gig card. 2-gig and below, No error.
Posted on Nov 10, 2013
2 Suggested Answers
SOURCE: Tascam dr-1 recording problem
There is a "PB Control" button. I had the same problem. You've inadvertently told it to change the speed or something on playback. Make sure that none of the indicators at the top of the screen are active (i.e., white letters on black background). Press the PB Control button to toggle it on/off. Also, any files transferred to a computer will not be affected.
Posted on Feb 08, 2009
How can I switch the mic input from the built-in mics to XLR input?
on the left side of the unit there is a small switch , , set this switch to MIc , or if using a condenser mic set to phantom-mic this gives the mic power , but I will caution you to watch you units power ind as with that setting you battery will drain down quicker than usuall , you will get best results with balanced mic's as the other types will introduce noise (thumping sound) into the recording also try to keep cord lengths down to less than 15 feet as this will introduce noise into recording as well
Mar 17, 2016 | Tascam DR-40 Portable Digital Recorder
I downloaded the contents of my Tascam DR-05 to my computer because it was full, but, instead of doing it as always, by just downloading the soundfiles, I copied the file folder dr005 to my computer,
Eric have you tried to do a "Quick Format"? If I'm not mistaken when that is done, you re-format your card and the small memory in the DR05. I had trouble with mine at first but when I did the formatting after I put the bigger 2GB memory card in the DR05 worked great. I record on "All Files" too, that seems to work well also.
Hope that helps,
Patrick
Oct 14, 2014 | Tascam DR-05 Portable Digital Recorder
How do I recovered deleted files from a Tascam DR-1MP3 player
Hi! As far as I can tell, there is no way to recover anything deleted off the recorder (found this out the hard way!) Best advice I can give is back it up on a hard drive asap before deletion. That way your material can be put back onto the device at a later date. It\'s a pain but it\'s saved me a few times!
Sorry I couldn\'t be more help!
Jun 28, 2014 | Tascam DR-1 MP3 Player
Dr-40 stops recording after 5 seconds
Check if your DR-40 has auto-rec turned on. If so, it will only record once a certain input level is present, and will stop if the input goes below that level. The recorder will turn back in when that level is exceeded again.
May 10, 2012 | Tascam DR-40 Portable Digital Recorder
When turning on it will only go to a blue screen says go to safe mode or get tech support but even in safe mode it will only go back to blue screen. Can't download anything or do anything. At the...
Try uninstalling a few unnecessary programs
Just run fewer programs or buy additional RAM click start right click on my computer select properties you will see all imformation about your computer including installed ram
or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly
click start right click on my computer,properties advanced scroll down to system and recovery open settings write and debugging information the drop down button select none
ideally, it should already be the default debugger for your system.
The Dr. Watson debugger program logs all information related to failed processes to the Drwtsn32.log file. In addition to this, the debugger program can be configured to create memory dump files related to the failed processes. You can refer these dump files to analyze the reason behind a process failure.
Perform the following steps to configure Dr. Watson as the default debugger program to record user-mode program errors:
  1. Open Start menu, select Run, type Drwtsn32.exe -I and then press Enter. This command sets Dr. Watson as the default debugger.
  2. Next, run the Drwtsn32.exe command.
  3. In the Dr. Watson for Windows dialog box, select the following check boxes:
    • Append to Existing Log File
    • Visual Notification
    • Create Crash Dump File
  4. Now, when your computer restarts after the STOP 0xC000021A error is generated, run the Dr. Watson command.
  5. Here, view the paths to the Dr. Watson and User.dmp logs.
  6. Open Windows Explorer, navigate to the log files and then open them.
  7. Here, check the cause behind the STOP 0xC000021A error.
also you might download and use this registry cleaner it is 100%totally free to use
http://download.cnet.com/ccleaner/
hope this helps you
Jul 24, 2011 | Computers & Internet
How do I change the greeting message?
You can record your own greeting message (max. 2 minutes) that is played when the answering system answers a call. If you do not record a greeting message, a prerecorded greeting message is used. 1 {GREETING REC} 2 Within 10 seconds, press {GREETING REC} again. 3 After the base unit beeps, speak clearly about 20 cm (8 inches) away from the MIC. 4 To stop recording, press {STOP}.
Mar 08, 2011 | Panasonic KX-TG5632 Phone
My answering machine message is out dated and needs to be changed how do you do it?
Recording your greeting
message
message (max. 2 minutes). If you do not
1 {GREETING REC}
from the MIC.
Feb 11, 2011 | Panasonic KX-TG6021M Cordless Phone
Foot pedal won't work with hands free microphone
The 3750 won't let you control the telephone record jack. The only way you can get a mic to work using the Tel Rec jack is by pressing and holding the 'Tel Rec' button for about 1 second. But this isn't compatible with the hands-free operation.
If you're looking to do hands-free recording, it uses the built-in conference mic. Press and hold the 'Conf Rec' button for about a second and it should start recording. This built-in mic is located on the right-hand side of the machine near the front by the headset jack.
If you want to control the machine via a foot control while in Conference Record mode, you'll have to change the 'Foot Control Dictate' setting in the menu. Here's how:
1) Press and hold the 'Erase' & 'Search' buttons for about 5 seconds until the menu appears.
2) Scroll through the options until you get to 'Foot Control Dictate' and set this to 'Yes'.
3) Press 'Stop' to exit the menu.
4) Press the 'Conf Rec' button to enter record mode.
Now you should be able to control the start/stop of the record function via the foot control.
Hope this helps...
Apr 13, 2009 | Dictaphone 3750 Desktop Cassette...
How to record with a tascam DP-02CF? The manual assumes that you have used one before.
You need to first plug a mic (or guitar) into an input. Then you have to assign that input (A or B) to a track. You do this by selecting the input (pressing the input's assign button) and then selecting the track (pushing the tracks select/rec button) above the track. The track select button will light green when you press the input assign button of the input assigned to it to show where the input is assigned. (To unassign the input simply press the lit track select button again while the input assign button is pressed).
Then you have to select the track for recording. Simply press the rec button above the track alone and it will light red and stay lit. Now press the play and record buttons and you'll be recording.
Hope this helps.
bd.
Jul 18, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam us 144
Stereo requires two different inputs, as the very name implies. If you're using just one mic, it is possible to "pan" that input to both left and right, but is not truly stereo. For true stereo, you must have at least 2 mics, or 2 or more of any other sources...accordianman
Feb 22, 2008 | Tascam US-144 Sound Card
Tascam DR-1 MP3 Player Logo
347 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
