I have to hit the power button several times to get sound.
  • 1,214 Answers
Is the power button slow,or maybe it has tobe fastened?
kolbrun
Posted on Feb 24, 2012
2 Suggested Answers
SOURCE: lamp out maybe
my tv did the same thing and since I was getting it to work most of the time I didn't do anything until the lamp went out alltogether. If you also get a warning that your lamp needs to be replaced, you better get one. You can get them pretty cheap on EBay and on the web if you google them. Approx. $140 if you search maybe less. From Panasonic it is over $550. It was easy to replace but still cant get the lamp timer meter to reset in mine. Good luck with itl.
Posted on Jul 04, 2008
Vizio p50 10a not powering on
Main power supply regulator board (SMPS board) fault. Check and replace it. If you wish to get more details visit the site linked here
http://homenol.blogspot.com/
Jan 25, 2017 | Vizio Televison & Video
Hi? My Sony Projection T.V model KP-FX432M91 is taking time to power on and once it has powered on it work fine.what might be the problem?
Power button may need to be replaced. Try turning on via remote.
Some TVs need to warm up before coming on. Hitting the power button several times may in all actuality be Turing it off and on.
Sep 20, 2016 | Sony Kp-Fx432M91 43" Projection Wega...
Duplo DC 10000s tower has the powerlight on but nothing else is working have i blown a fuse or need to reset a button?
If you hear a beep (sound) as you turn your computer on then look and see you you have another video card (built in one) to hook vga cord into (which will most likely solve your problem).
If you hear several beeping (sounds) most likely your memory dimms went bad or got dirty by dust (or humidity), try take them out and clean them with an eraser (like the pencils one).
If not try this:
What you need to try first is to disconnect the power cord off of the power supply and hit the power on button several times (which will try to re-enable to electronic fuse) if that doesn't work most likely the powersupply needs to be changed (and not the whole motherboard although this is an option as well :)).
Good luck.
Oct 23, 2014 | Computers & Internet
Have Sony KV-34HS420 with no picture or sound. Timer/Stand By light flashes 7 times with pause in between. What is the likely problem and cost to repair?
Hold hair dryer to back right side on high heat for a couple of seconds while you hit the power button several times. It only took 2 times for my set to power on. Good Luck!
Aug 12, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Zenith remote will not work tv, need code
hello here is how you get your remote to work...make sure tv is on
step 1.hold down code search button till you see the red light
step2. let go of code search button and hit TV once light should blink
step3. press and release the power button while pointong a TV u ((may have to press the power button several times)) once the Tv powers off press the enter button once
step4. press tv button and hit power
May 16, 2009 | Zenith DBZN-311 Remote Control
Need the code for a LG brand tv on a radio shack 3 in one universal remote control....
May 16, 2009 | Radio Shack (15-2147) Remote Control
E studio 202L copier won't copy unless interrupt button is lit
Sounds as if when your hitting the interupt button you are interupting a copy job the machine "thinks" it is doing, try clearing the print que on the copier.
Apr 13, 2009 | Toshiba Estudio 200L Copier
I lost my sylvania remote and bought an RCA universal remote
Mar 07, 2009 | Zenith DBZN-311 Remote Control
Sound
Sounds like you have a bad ground or cracked board or even several cold solser connections on or around your microprocessor IC. Could even be a bunch of cold connection , some around the sound output ic But my feelings are they are all around the Micro. Your gonna need to be goo with a soldering iron and a plasit pick tool to find the area ao if you have no experience in electronic troubleshooting i would take the set into a pro. Good Luck
May 27, 2006 | Sanyo DS31520 31" TV
Televison & Video Logo
Top Televison & Video Experts
