Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
H3000 doesn't start.
My two year old H3000 doesn't start all of a sudden. Maybe it has broken fuse? How do i replace it?
Thanks Sean
  • c2gentry Nov 06, 2008
    Can you replace the switch then or do you have to take it in for repair?
    Problem Solver:
  • 10 Answers
No fuses. The only thing in the circuit is the switch, so it's probably that. Good-luck.
Kirk Thompson
San Juan,PR
Posted on Oct 29, 2008
Ho do you replace the floor hose on a h3000 floormate?
Hello! The water channel hose is no longer available. You may be able to locate the part through a vendor online or through an authorized service center. The part number is 59177042. I have included a link where you may go to locate a service center near you. Service Center Locator
Hope this helps!
Aug 03, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover hnf7167 won't start 40 cycle
it is about to go out completely it has lasted as long as any one that I have ever had
Mar 22, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
My Hoover floormate motor started smoking. It is over 9 years old. I keep the floor brushes clean. I am wonder if replacing the mother is worth it.
MSRP on this motor is $69.95. Labor may be another $30.00. I often see these units in thrift shops, which may be worth a try.
Jan 29, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
Spin brush will not spin. local repair man said one gear stripped and motor would need replacement. is this correct??
There is a plastic rod that sticks out of the back of the spin brush, this makes all of the brushes rotate. The motor would need to be replaced if it was not turning on anymore. this doesn't sound right...?
I think it is just a broken piece of plastic on the block brush which will need to be replaced.
You can find a schematic and the parts you need on this link
H3000 Link
Feb 02, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
I did not get a manual
Here is a link that will download the manual you're looking for.
Good Luck
Jan 23, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Alyx 2000w, no power. Help!??
Its a possibility then that if the fuse has been replaced that the cable inside has either come apart or you have a broken switch. If its only a year then you should be covered automatically with Hoover's guarantee.
Mar 05, 2009 | Hoover F5411 SteamVac Jr. Canister Vacuum
Brushes not contacting floor
It is unlikely that you have worn the brushes to the point that they no longer contact the floor properly unless you use it daily and have a very rough tile or concrete floor and even then they should outlast the machine. It is more likely that there is a problem with the switch that moves them up and down for different floor settings. Also remember that the brushes will be up while the unit is in the upright position no matter what the switch is set to only when you bring the handle down in the operating position do the brushes lower to contact the floor. Pull the brushes out and check to see nothing is interfering with the operation of the brush adjustment or for any broken parts. As for the squeegee they do get deformed and this will prevent the unit for sucking up the water properly so it should be replaced if needed. For any parts visit if you don't see what you need listed email them someone can help.
Aug 13, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Does not pick up water
Posted by Dreams642 on Apr 20, 2008
I have had my Hoover Floormate for years. It has always worked great but the last few times I used it the amount of water left is tremendous and the container for dirty water was not full at all. I looked at it and the hose going up from the bottom thru the handle is broken how do I fix this.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Floormate H3000 Upright Wet/Dry Vacuum. You can down load the owner manual from the Hoover website . It looks like the one of the holding or recovery tanks my not be in place, leaking, cracked or damaged, or the clear tube is leaking and needs replacing. I looked 2 the owner’s manual and it does not show the clear tube but the vacuum does come apart and just back track the clear tube and mark the screws when you disassemble the unit. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 20, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
