Question about Samsung CLP-510 Laser Printer
Need to reset counter for transfer belt
Have a new transfer belt on teh way but need to reset teh counters as hte machine has just stopped working and i have to keep using it until teh new transafer belt arrives. I have reset the imaging unti etc vis the EDC maintentance menu but cannot access teh transfer belt counters in that way - please help
  • 18 Answers
To reset the counter on the toners and transfer belt see:
http://www.dunfield.com/clp510/
Posted on Jan 04, 2009
Why the c-3461 error comes
Sir/Mam,
Press Utility/Counter, Details, "Stop 00 Stop 01", (Password if required 92729272)
After replacing a fusing unit or transfer belt unit, perform New Release to clear its life counter.
1. Select the key as follows.
[Counter] ? [Life] ? [New Release]
2. Open the front door.
3. Select a unit where New Release is made.
4. Press the Start key and perform New Release. Exit out
Apr 10, 2016 | Konica Minolta Bizhub C451 Copy-print-scan
How to reset the counter for my fuser unit on my Konica Minolta c552 copier
Utility/Counter, Details, Stop 00 Stop 01, (Password if required 92729272) Counters, Life,, New Release, Open the front door (Not the Toner Door), Select Fuser or Transfer Belt, and press the Start Key. Then exit all the way out.
May 26, 2015 | Konica Minolta Office Equipment & Supplies
Develop ineo 501, machine stopped, showing " have the fusing unit replaced soon, contact the service representative" -no error code. There is also "license management error occurs" but this promt was way...
that unit is manufactured my konica minolta. it is a Konica Minolta Bizhub 501 and will use the same fuser even though the image units, toners, and transfer belt have to be chipped for the ineo. There is a picofuse in the fusing harness that blows as soon as it is installed and that starts the fuser life counter. the counter is reset when a new fuser (or new fuse, if the fuser is still good) is installed. You will need to replace the fuser for the message to go away.
Jan 05, 2015 | Office Equipment & Supplies
How do you reset maintenance count on a dell 3130?
You don't. You can't.
When you install a replacement Transfer belt (it has it's own counter chip) that resets the transfer belt pagecount, and as a result clears any transfer belt life related warnings/errors.
When you install a REPLACEMENT Fuser (that has it's own counter chip) that resets the fuser pagecount, and as a result clears any fuser life related warnings/errors.
PLEASE NOTE - The fuser supplied with the DELL 3130 when new DOES NOPT have a counter chip - the fuser life warnigs are triggered by the printer pagecount. Installing a fuser from another printer (even if it has a ZERO pagecount WILL NOT reset the fuser pagecount (because the 'ship with' fuser has no counter chip.
Aug 27, 2014 | Dell 3130cn Color Laser Printer
The tools reset the counters for the 'transfer belt unit' (TransferBelt_for2500W(E).exe), the 'fusing unit' (FuserUnit_for2500W(E).exe) and the '2nd transfer roller' (SecondTra
Refer the parts life counter reset.Every time you change the fuser ,imaging unit parts you need reset the counters.Touch the screen exe. nad reset.
Jan 24, 2013 | Konica Minolta magicolor 2500W
I have a konica Minolta bizhub C250 and the screen is reading "replace transfer unit" and "replace fusing unit". I contacted a local repair guy that said he might be able to reset the counters and the...
I can only tell you they are definately resettable as I do it all the time.
The fuser "fuse" is located in the connector wiring. Once you get the fuser out just look in the area where the large connector is. It is a very small fuse similar to a resistor, green, and is encased in shrink wrap.
The Transfer belt fuse is behind a small black cover. If you pull the transfer belt unit out of the machine about 6 inches, it is located on the front right corner. In other words standing in front of the copier with the belt unit partially out it is on the corner closest to you. You have to remove a screw, a c-clip, a small metal plate and the small black cover is held on with a very small phillips screw.
He is the parts availablitity and part number info.
Fuses are available at http://www.digikey.com/
Transfer Belts
Replace glass fuse 80ma , counter resets automatically.
Item # 507-1218-ND
Fuser Units
Fuse is wrapped in shrink wrap. Cut it out and splice in a 1/16 ma fuse.
Item # F2307-ND
Good Luck and Thank You for using Fixya.
Oct 08, 2010 | Konica Minolta bizhub C250 All-In-One...
XEROX PHASER 6110 MFP REPLACE TRANSFER BELT MESSAGE
If you have replaced the Image Transfer Belt, and the printer still does not work, you will need to reset the counter. Xerox would not tell me how to do it, so I did some investigating.
1. Enter Service Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press Enter
6. Enter Password 1934
7. Arrow to Transfer Belt and press Enter.
The display will show Clearing Counts and then return you to the Tech Menu. Press exit several times to exit the Tech Menu and then power cycle the printer.
May 18, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Reseting counter after installing new image transfer roller unit
You need to go into tech rep mode to reset.
press: stop 0 0 stop 0 1, then 0 0 0 0 0 0 0 0, press enter, then press counter on the left, select life, then highlight image trans roller and press the C button, repeat for paper dust remover and exit tech rep mode
Jan 17, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Samsung CLP-510 Laser Printer Logo
5,647 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
