Question about Irons
Can i use a descale solution for domena press
Domena steam press S P 4000
3 Suggested Answers
SOURCE: I need a new steam pipe for my Domena TF 3700
My local dealer had one in stock!!
Posted on May 21, 2009
  • 3 Answers
SOURCE: domena excellence sp400 how to change thermostat
You can get a manual from http://safemanuals.com/brand-user-guide-instructions-owner-manual/DOMENA, unfortunately they charge for there manuals. I believe if you where in the UK asking this question you will get an answer faster from a local dealer! Good Luck!
Posted on Nov 29, 2010
I have a domena steam press and there is water coming out and soaking the clothes. Water comes out as steam but as well as this it drops out as water.
Lime scale build up inside the elementchambers causing poor heat transfer to the water the steam being cooler thAn usual condenses back into water it reaches the porthole the steam is ejected from and you get this leaking effect steam and water together your need to professionally get the device descaled
Jul 03, 2016 | Irons
The iron has been all descaled, however we cannot get any steam when pressing the button. It is a Tefal express generator model 3 years old.
Once you have descaled the boiler and refilled your frontpiece of the iron itself (hopefully with distilled water - any supermarket) you press the "reset"/ "restart" button on the back end of the steam generating unit. When the water is hot enough press steam button & turbo button a few times - WARNING: make sure iron is facing downwards and cover ironing board with old rag because initially brown steam splatter will come out on first few steam releases.
Feb 14, 2015 | Tefal Irons
No steam coming throwc
Normally when water is put inside steam irons, it get stored in tank then if thermostat knob is set for steam then water moves to bottom heated portion of iron. Water converts to steam as base plate is hot, heated steam comes out through perforated holes. If holes are blocked due to scale formation steam flow is blocked. The descaling has to be done as per instructions given on descaling wax manufacturer. sometimes if water does not enter through a rubber washer that is water tank to heated bottom portion then also steam will not get generated hence no steam. Please check above points and identify the problem.
Jan 08, 2015 | Irons
My domena steam press leaves brown stains on my
You may have to use only distilled water in your iron.
Sep 14, 2014 | Irons
How can I get my Domena SP400 steam press to produce steam
Blockage " mineral deposits" get a de-scalar and follow the directions. Only use distilled water in steam iron.
Sometimes vinegar will work depending on mineral deposits causing blockage.
Apr 21, 2014 | Irons
Domena excellence sp400 how to change thermostat in steam press need to take a pin out to get access to elements and thermostat
Nov 28, 2010 | Singer Irons
Hand steamer conair GS15R will not produce steam. It is on, it is full of water, the body gets warm, and it makes noises like it is steaming but nothing comes out.
Hi.
The iron steam lines may be clogged with limescale.
Try first using descaling solution to clean the lines.
Do descaling several times.
If that does not work, then the thermostat may have started malfunctioning and cutting off earlier than normal. This will cause water not getting enough temperature, and iron not steaming.
Try using a descaler product, often that can fix the problem.
Jan 14, 2010 | Conair Irons
How do I descale my steam press
Run a vinegar and water solution through it.
Aug 14, 2009 | Irons
Rowenta steam iron no longer steams
Your local grocery or hardware store will sell "descaler" for coffee pots and irons.
Mix as instructed (water/descaler) and pour the disolved mix into the iron. Set the iron on the highest steam settings (heat and steam volume). After it is hot, let it steam into the sink, pressing the steam button over and over to let the descaler work through all the tubes/passages, until it has all been pumped out.
Refill with more descaler (if it is not completely unplugged) and repeat until you are satisifed with how the iron is working.
After descaling, run clean water through it with the same process (but no descaler) several times.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Mar 24, 2009 | Rowenta Professional DE841 Iron
Irons Logo
65 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
