Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Where to load staples on konica minolta bizhub 751/601
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
Nitrotrike
  • 589 Answers
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Posted on Feb 10, 2008
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
Kevin Hayes
  • 167 Answers
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Posted on Feb 17, 2009
Where can this part for the printer be purchsed ? konica minolta bizhub 160
Except you don't say what 'this part' is :>)
Never mind. Here you go. Or look in Yellow Pages for a technician.
  • Konica Minolta bizhub 160 Supplies and Parts (All) www.precisionroller.com > ... > Konica Minolta > bizhub 160 Konica Minolta bizhub 160 Supplies and Parts (All) for less. Free shipping on orders over $75.00!
  • Konica Minolta Bizhub 160 Toner, Parts, Supplies, and ... www.arcservicesco.com/1016/konica-minolta-bizhub-160-i-toner-parts... Additional Info Konica Minolta Bizhub 160 is a Digital Printer and Copier which was introduced February 10, 2012. Suggested Retail Price:$1,029
  • images of konica minolta bizhub 160 parts bing.com/images th?id=oip.mcd31c057681b6e2e393bc136df5885ddo0&w=140&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m850c92a4f48e9107608f3f81e06b2feeo0&w=99&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mdb0ced5306197a197806530dbb355967o0&w=74&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mb7d2a296bf50d1a0bb42098505ce2c61o0&w=133&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.maedc8ec17eba695445679a648922e7e3o0&w=70&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2 See more images of konica minolta bizhub 160 parts
  • Konica-Minolta bizhub 160 160f 161 161f Parts Manual www.qmanual.com/printer/konica-minolta-1/bizhub/konica-minolta... BRAND: KONICA-MINOLTA: BRANDSKU: No: TYPES: Parts_Manual: SIZE: 1.49M: PAGES: 35: FORMAT: PDF: LANGUAGE: English: QUALITY: High resolution: ...
  • Konica Minolta Bizhub 160 Printer / Copier Parts & Supplies https://discountcopiercenter.com/konica-minolta/bizhub-160.html Save big on Bizhub 160. We offer the lowest prices and highest quality, with free shipping on any orders over $100!
  • Konica Minolta bizhub 160 Parts Guide (160_PARTS) www.atec.ro/parts.../konica-minolta-mfps/konica-minolta-bizhub-160... Konica Minolta bizhub 160 Parts Guide; PN: 160_PARTS
  • Apr 01, 2016 | Konica Minolta Office Equipment & Supplies
    How to fix error code C0103
    one of your paper draws not working check all for proper operation might have paper behind them
    Jan 14, 2015 | Konica Minolta Konica BizHub Press C7000...
    How do you replace the staples in a konica minolta c650
    pull out the blue cartridge do not throw away you then place the staple cart from the box you have insert into the cart,
    Apr 29, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
    Bizhub not collating when stapling
    did you select collate in the print driver, try reloading the driver check the web site
    Self Help Product Support Konica Minolta Business Solutions Inc
    Apr 01, 2014 | Konica Minolta Bizhub 222 Black and White...
    How do I replace staples in the Konica Minolta Bizhub 600?
    The saddle stich or the booklet??? saddle stich is like church program with staples in the middle. Booklet is staples on the left side of the paper or the corner stapler to different staplers and depends on the finisher model?
    Aug 08, 2011 | Minolta Office Equipment & Supplies
    Folding and Stapling a Booklet on Bizhub C250
    1)The print driver has two collate buttons and you only need to uncheck the first one (which is the windows driver not the Konica Driver) or
    2) Install a new driver
    Oct 02, 2009 | Konica Minolta bizhub C250 All-In-One...
    Where do you load staples.
    see here:
    http://www.fixya.com/support/t1332551-staples
    Dec 10, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
    LOADING STAPLES
    There is no manual for that, this procedure should be shown in backside of front cover.
    Jun 18, 2008 | Konica Minolta bizhub C351 All-In-One...
    Konica Minolta bizhub 350 All-In-One Laser Printer Logo
    323 people viewed this question
    Top Konica Minolta Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Ben
    Ben
    David Burkhart
    David Burkhart
    Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
