Question about Endurance T3 Treadmill
Dcmd67m digital signals to control the board
To run the board endex dmd67m I need to know what signals are fed to the slot 1 and then after 5 optocouplers on the controller. If anyone knows, and ran the board so please answer - the manufacturer of the post unresponsive.
Hi, on the DCMD67M the motor run for short time (less than 1 sec) and stop and the error led (red) turn on, P1 displayed on the screen. What is the problem. Thanks
Posted on Mar 12, 2013
MOTOR ELECTRICO BH FITNESS 2.0 H.P.P.
180V DC-4A.
desimantado, perdida de potencia
precio.
605276703 NOGALES
emin.nogales@yahoo.es
Posted on Jun 01, 2012
Is their one or two crank sensors on a 2003 olds alero
What engine does yours have ? 2.2L 4 cyl. or 3.4 L V-6 If you have 3.4 L it has two A an B
• Crankshaft position (CKP) sensors
The CKP sensor B is a variable reluctance sensor. The magnetic field of the sensor is altered by a crankshaft mounted reluctor wheel that has seven machined slots, six of which are equally spaced 60 degrees apart. The seventh slot is spaced 10 degrees after one of the 60 degree slots. This sensor provides the ignition control module (ICM) with 7X signals, or seven pulses for each revolution of the crankshaft. The pulse from the 10 degree slot is known as the sync pulse. Both of the sensor circuits are connected to the ignition control module (ICM). A signal converter within the ICM produces digital 3X output pulse to the powertrain control module (PCM), the 3X reference is known as the low resolution engine speed signal.
The CKP sensor A contains a hall-effect switch. A hall-effect switch is a solid state switching device that produces a digital ON/OFF pulse when a rotating element passes between the sensor tip and a magnet. This rotating element is called an interrupter ring or blade. In this case the interrupter ring has 24 evenly spaced blades and windows and is part of the crankshaft damper assembly. This sensor provides the PCM with 24X signals, or 24 identical pulses per crankshaft revolution. The 24X signal is used for enhanced smoothness and idle stability at a lower calibrated RPM. The PCM supplies the sensor with a 12-volt reference, low reference, and signal circuit.
Mar 01, 2017 | 2003 Oldsmobile Alero
I am looking for a cirit board for a endex DCMD67 for a flowfitness treadmill.
Dear Sir:
Thank you by your request, I hope everything is fine.
I will help you inmediately.
Please go to the next web page expert:
www.fitnessrepairparts.com
You will find any Parts Electronic(Circuit Boards+Electrical Parts+Mechanical Parts) Manuals+Schematics, etc.Of course you need to pay for to buy everything you need.
Thank you in advance, sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 28, 2011 | Exercise & Fitness
How i do tv chanel tunig
Hello Ansarielectr, The Panasonic TH-42PWD7 is a professional grade progressive wide screen plasma display. It's not your normal HDTV. You probably already know this. This display requires a component /composite video terminal Board that mounts to slots 1 & 2, or slots 2 & 3. The item number for this component is TY-42TM6Y and can be purchased through the Panasonic support website here for about $270. Once you have this component, you can connect the TH-42PWD7 to a digital HDTV cable box to receive signals. Just make sure you're on the right input signal. Hope this helps.
Dec 28, 2010 | Panasonic TH-42PWD7 42 in. EDTV-Ready...
I am looking for a cirit board for a endex DCMD67 for a bodyfit treadmill.
my DCMD67 circuit board keeps blowing the fuse or tripping fcl in house sw/bd.
Does not want to start, have had motor checked is ok, leads r ok. What to do?
Aug 12, 2010 | Endurance T3 Treadmill
I'm having an aspire m5640. it does not boot. beep?
Yes if there are error on the system you should most likely hear a beep most of the time when there is no beep it is due to bad ram. Some times beep codes can't detect bad ram and your computer will not boot.
Open the computer up and see how many ram chips you have if you have more than one take the one in dimm slot 2 out. There should be small writing next to the slots 1,2,3,4 or Dim 1 dim 2 ect ect. you always want to keep slot 1 with ram so start by pulling out the ram out of slot 2 and turn your computer on. If your computer still dosn't post pull the ram out of slot 1 out and insert the ram that was in slot 2 into slot 1 if still no luck it's most likely your board but the best way to test this is to know that you have a good working stick of ram you could purchase one and if it dosnt work bring it back ... theres also the chance of your video card being bad but there is usualy a post code for it (beep code)
if you have no clue on what ram looks or how to open your computer just google for installing ram on a computer and you should find step by step guides
Jun 02, 2010 | Acer Aspire m5640 PC Desktop
Looking for a replacement endex pwm board
Call Body Solid @ 1-800-633-1227 ext 520 thats Parts and Tech support
May 15, 2010 | Endurance T3 Treadmill
Plug-ins
Don't you have a manual? Most of the time the schematic diagram is part of the manual which is on the Mother Board CD. If you have a manual we will follow a different route of troubleshooting then if you have no manual. My suggestion is that you acquire 1 manual, 1 motherboard CD disk, 1 CD/DVD with the OS on it and 1 more CD/DVD with the drivers on it. The last two disks are to have the installer as part of their content. You have to remember that MB's are very delicate and can be damaged easy. The only part of the computer is not the mother board. The MB has the following parts: (1) The BIOS, which controls the computer inputs and outputs upon start-up for a few seconds until the nest step takes over. (2) The Central Processing Unit (CPU), which controls all processing and sequencial effects. The CPU, also, generates and controls the radio signal that carries the computer information (something like a composite TV signal), plus it interrogates the Random Access Memories, to store signal, to remove signal and to move signal to another location. With modern computers there is more and more pressure on the CPU, which is asked to perform manumentals tasks at very high speeds, speeds that genrate many joules of energy, which is removed by the cooling system (heat sink and blower or a cryogenic generator). It is always suggested to buy a MB that has the CPU installed at the factory, where every care has been taken that no heat will remain on the CPU chip. Modern computers have another chip for doing the mathematics, but even though it does not get as hot, it does require cooling, also; (3) the Random Access Memories (RAM). Their role is to replace the Hard Disc or parts of it, so that there will be no moving parts during the execution of a program and thus incrase the speed of operation. (4) The Video processor, which prepares the video signal, so it can be recognized by the Video processor and projected on the screen. (5) The Audio processor, which prepares the Audio Signal, so that it will be recognized by the audio processor and fed to the audio amplifier and speaker. (6) On the upper left side of the board there are conectors for various purposes, some older type like an RCA audio socket and the others, the modern ones are the USB sockets. There originally was one kind of USB connectors, but later it was realized that their speed was not exactly dazzling. So another type of USB 2.0 sockets and connectors were designed. The plug of a USB can be plugued in both sockets just as easy. The Video connector has remained the same for several years now, where the RCA sockets and plugs were replaced by better more efficient, miniature sockets with their corresponding connectors. As we almost said in the bottom part of the Board there are sockets with their connectors in line and they are called the PCI sockets, where one can connect a PCI board. Almost all desktop boards are PCI, where the Laptops are endowed with the modern looking PCMCIA sockets and corresponnding connectors. Finally we can look at all the things that the Mother Board does and be amazed.
A Computer also has a sophisticated Power Supply, properly cooled and toward the front of the computer there are slots for the various plug-ins that require external intervention. There you will find the HDD's, the floppy, the CD/DVD Drives, plus a number of other ainsileries that plug in and do medical radiography, or other inductrial functions. There are huge computers at banks and other financial institutions. The computer owned by the Social Security, a highly specialized financial computer, is the largest computer in the world.
Jun 15, 2009 | Computers & Internet
Analog / Digital stations
Hello mikekahan,
OK you are not going to like this but here we go any way. First of all I need to explain how your channels are created.
When the RF signals come into the headend of the Down converters they are separated into pre channelized designations DC (Down Converter) 4 Stream 1 (DC 4-1, DC 4-2...) now once this is done the down converter signal is fed into a channel processor which takes the incoming signal from the Down Converter remodulates it and puts it on an assigned channel 4-1 could become channel 4, 4-2 could become channel 5 and so on. Once this is done you end up with your regular channel line up for analog channels, now for digital its a little different you have IRDs (Integrated Receiver Decoders) which take the off air or satellite Digital RF signals and convert them into MPEG Streams which is the fed into what is called a SEM (Motorola Architecture) Stream Encryption Module which assigns numeric designations to the MPEG streams and then converts the MPEG streams back into RF. Now at this point we have analog and digital signals what then has to happen is the the analog signals must be turned into MPEG streams to go through the system so what happens is from the channel processor the analog signal is put into a SE (Stream encryptor) Like the SE1010. This takes the analog stream and turns it into am MPEG stream and feeds it into the SEM also and the SEM assigns a numeric designation just like the digital signal and this can sometime follow the same numeric designations as was obtained from the Down Converter, So what you end up with is analog and digital signals having the 4-1, 4-2, 5-1, 5-2, ..... format. This is where other equipment comes into play These designations are then kept in a database and are matched to their proper channels by use of the DAC and RADD along with an IPG server. These allow the SEM to assign true channel designations to the converted channels, now the SEM DAC, and RADD talks to your STB, this is way the channels are correct because the SEM and the DAC/RADD are matching what is on the IPG (Interactive Program Guide). When you remove your cable box the tuner in your TV does not know how to deal with the DAC, RADD and IPG signals so it only displays the RF information which is the 4-1, 4-2, 5-1, 5-2 data.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 27, 2009 | RCA 20F424T 20" TV
PCIE problem
You said you built the PC yourself. One of the most common causes of faults are because the motherboard screws are to tightly fastened. I would release off all the screws by 1/4 of a turn and try again. If this problem persists then i would recommend a visual inspecton by an engineer.
Jun 20, 2008 | Abit IN9 32X-MAX Motherboard
I'm getting a SC 558 error
SC558 Abnormal zero
cross signal
- Timing & Condition -
Zero cross signals
generated within certain
period do not reach a
predetermined target
value.
• Poor connections
• Blown fuse
• Defective AC drive board
• Defective main control
board
• Defective I/O control
board
1. Make sure the following are connected
properly:
• CN212 and CN229 on the I/O control
board
• CN303 on the main control board
• CN7 on the AC drive board
2. Check the current through the signal lines
in the above harnesses.
3. Replace the fuse (FU101) if it is blown.
4. Test the AC drive board, I/O control
board, or main control board by checking
the signal line at each pin.
[Signal Check]
• Zero cross: CN7-5 on the AC drive board/
CN229-6, TP216, or CN212-B8 on the I/O
control board/CN303-B4 or TP120 on the
main control board
Any problems get back to me
Than You
Mar 11, 2008 | Ricoh 6513 Copier
Endurance T3 Treadmill Logo
740 people viewed this question
Top Endurance Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Tom Chichester
Are you an Endurance Exercise and Fitnes Expert? Answer questions, earn points and help others
