Question about Zoom H4 Handy Recorder
Uploading files into projects
Is there any way to use a (.wav) file uploaded from the computer into an H4 4-track project? The manual describes importing files, which I've done. I can listen to the file in stereo mode, and see the file listed in the project when I import it to 4-track mode. But I can't get that file to be assigned to a track so that it can play back and be used. What is the point of importing a file if it can't be used? I guess an associated question would be, if you're recording in "Always New" mode and saving tracks, is there any way to select one of those saved tracks to playback and use again within the zoom, or do you have to dump them all into the comp to review and work with them?
  • 1 more comment
  • bobdvm Oct 28, 2008
    ok, I see how to select saved tracks - that was a spur of the moment question that I thought might have some bearing on getting .wav files into a usable form, but it doesn't. I guess there is some little bit of code on the file that assigns a track, and without it the zoom can't use it as a 4-track recording track?
    No, I got it finally. The zoom 4 track works with .wav, so that isn't the problem. The trouble seemed to be that the imported file has to be mono. I haven't tried MP3 or bitrates other than 44.1 but I think those might not work. I also didn't try importing stereo after setting it to stereo link in 4track - that also might work. Anyway, once you have a mono wave 44.1 file, you just drag it into the project, on the computer. I found that the file turned up in track #4 - maybe this is the default. You won't see it right away: you need to select the 4th track, and then scroll to the track data field with the jog dial, and enter it, and then scroll within that with the jog dial and you will find your imported track. Select it with the jog dial, and you're golden.
    ok, as a further note to this, you can import .wav stereo files into a project as long as you stereo-link the channels you upload into. It can be done after the fact I think. You won't see the files until you link the channels (I found the file in channels 1&2) and then enter the track data field and scroll and select as per above. It doesn't work with MP3 files - they have to be pre-converted to .wav before uploading to the zoom.
  • 962 Answers
Most of the time you have to convert the wav files to another format Such as MP3 or WMP. there are converters available for this purpose online.Google audio converters. Maybe you will find one that you can afford . Or even find freeware.
Posted on Oct 28, 2008
How to Online Convert MP3 file to WAV (Audio) file format?
The immigration attorneys Convert your audio like music to the WAV format with this free online WAV converter. Upload your audio file and the conversion will start immediately. You can also extract the audio track of a file to WAV if you upload a video. We are constantly improving our service. Right now we support over 20 input formats to convert to WAV. For example: MP3 to WAV, WMA to WAV, OGG to WAV, FLV to WAV, WMV to WAV and more. If you have a file that we can't convert to WAV please contact us so we can add another WAV converter.
Oct 09, 2012 | Audio Players & Recorders
Need service manual d52w20
Hello
I've the service manual for your TV; D52W20. It is in PDF format. I can't upload it to you by this window, as it does not allow me to upload PDF files by it. If you send your Email ID by Fixya comment box, I'll send a copy of it to you by return mail. OK.
Oct 31, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cannot convert my finished project into uploadable youtube file such as avi. or wmv.
Maybe you should try to convert your video to FLV format with Leawo Free FLV Converter and then upload to youtube.
Dec 03, 2010 | Ulead DVD MovieFactory for PC
From iTunes, I have converted the m4a track to WAV and then copied that over to my Tascam DP-02CF via the USB connection. When I go to import the track it says "Import file not found". What am I doing...
Your wave file is probably in stereo and you need to change it to mono. I use the free Audacity program to do this.
Once you have uploaded your wave file into audacity on the left side click on the down arrow which will bring up several options, click on the 'split stereo track' option. Then delete one of the tracks. You can then export the file as a wav file, you might want to rename with mono in your name so you don't write it over your previous stereo file. You can then import the file into your DP-02
Feb 14, 2010 | Tascam Dp-02cf Digital 8-track Recorder
Having trouble transfering my wav files from computer to tascam ( dp 02) even from cd to tascam . so i am unable to use .help? i have transfered my mp3 audio files to wav and tried to drag and drop from...
I had the same problem too but I figured it out. First you have to make sure your wav file is converted to (MONO) as opposed to Stereo, (which is the default channel setting). The best thing to do is to download a converter program, in my case I downloaded AVS Converter program which all I did was upload the wav file switch it to Mono 1.0 and that was that!! The Cons: for this program it costs money to download for your own keeping. I also suggest Audacity program my computer wont let me download it but a co-worker of mine has it and he said it's free to download.
Feb 02, 2010 | Tascam Dp-02cf Digital 8-track Recorder
How sites like rapidshare ziddu file factory and magaupload etc...... pay me for just upload them my files wht they get to pay me money??? rgrds /karim
once your files are uploaded by you
people need premium accounts to download those files which they purchase from these sites
tell me incase any issues
Oct 30, 2009 | Toshiba 50H82 50" Rear Projection...
File import in 4-track mode impossible
Convert the audio to Mono WAV (16Bit, 44.1KHz). This can be done by using Cubase(Hope you got Cubase LE with Zoom). In an empty project import the audio, then mark the whole track using the Draw tool and then got to File->Export. Here select the above options and export. Import this file into Zoom H4 either by copying directly into the memory card or through connecting the Zoom to computer ( I copy it directly into the memory card's STEREO folder). Now if you import it to any project, it will appear there. You can now use Zoom H4 as a Karaoke device!! Anyway, sad that Zoom H4 doesn't support stereo tracks in the 4Track mode.
Aug 14, 2009 | Zoom H4 Handy Recorder
Olympus VN4100 PC-Upload to Itunes???
The format of these files is WAV. I think you would need to convert the file format from WAV to MP3 in order to play it on the Ipod. You will probably need to locate third party software to do this type of conversion. Then you can copy and paste the file from your computer hard drive to the Ipod.
Mar 08, 2009 | Olympus VN-4100PC Digital Voice Recorder
Iwant prroject
dont search using mp3 keyword, if you upload your files in binary mode will be enough.
try searching for "binary file upload/download using java"
you can find a lot of binary file uploads projects.
this will upload your mp3 and any other files as well.
Jan 31, 2009 | Microsoft Windows XP Professional
Roland VS2000CD
Shelly, I have a 2480 but it must be very similar. Import the drum track as a wav file into two of your tracks within the same project. You must make sure the file is a WAV file and nothing else.
Hope it works, on the 2400, I am sure it must since it is a must have.
Mike
Dec 16, 2007 | Roland Vs-2000CD Digital Studio...
Zoom H4 Handy Recorder Logo
112 people viewed this question
Top Zoom Audio Players & Recorders Experts
Jaysan Lunt
Level 1 Expert
Paul Bade
Are you a Zoom Audio Player and Recorder Expert? Answer questions, earn points and help others
