Hii cannot make calls from my phone at all,it seem to reject all calls i have reseted my phone to factory setting and i did a hard rest and still not working i called my sevice providor prior to doing all this and they helped me doing that,everything is ok from there end.i have full reception on the phone and i have tried my sim in a differnt hand set and working fine,phone is unlocked and i have used wireless on it during the problem and works fine there.can anyone help here please.
SOURCE: My Nokia 1200 Won't Ring!
all your contacts belongs to Private Group... Remove them from this group.. or delete theme all and save again...
Plz rate me...
Thanks...
SOURCE: nokia 5310 won't send or retrieve MMS messages or connect to web
Nevermind! I found the solution. You just have to go to nokia.com and choose your phone and you can have them text the MMS and web settings directly to your phone and then you simply save the settings and after I did this, no problems. Works like a charm now! Stupid AT&T customer service.... Grrr.
SOURCE: sim card rejected on nokia 2630
is it the same sim u used in setting the password? insert the original sim and change security settings to none
SOURCE: nokia 6300 doesn;t work with sim card
Hi there, you may try to reset the whole software on your cellphone. Provided to back up all the necessary contacts, messages on your Cellphone. There is a need to update the software version of your cellphone to make it working again.
You
SOURCE: Call barring has been activated on my nokia N95
backup your phone then 3 finger reset then restore it
