Question about John Deere Garden
Battery light is on battery goes dead 445 john deere
The battery light stays on
wireguy212
  • 1627 Answers
SOURCE: I have a John Deere lx178 riding mower. The
you need to check the alternator with a volt meter set on a/c volts.the wires come out from under the top cover and go to the regulator,a small box with three wire terminals on it.it should be at above 20v running,if this is so and you have power to the center plug of the regulater,replace the regulator .if no power to center plug,repair the wire harness.if no power from alternator [white wires tested on ac ],replace the stator.
Posted on Aug 23, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
nova2nv
  • 197 Answers
SOURCE: john deere 445 with 22 hp kawasoki engine wont run
Remove fuel cap to see if there is alot of fuel spraying back into tank.I have replaced ALOT of fuel pump hoses that have split between pump and sender clamp inside of tank.Lack of fuel pressure creates a very lean condition with the injected models.
Posted on Nov 14, 2009
  • 52 Answers
SOURCE: John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Posted on Apr 18, 2010
Testimonial: "Thanks for the ideas. I will try your suggestions. Tractor used for snow blowing during the winter and gas did not stay in it long. Good ideas!"
spiegela
  • 3 Answers
SOURCE: john deere 445 tractor v twin 22 hp engine, john
Where did you get it fixed for $300. Dealer wants 6 hours labor and $400 in parts. Total cost will be $1,000.
Posted on Jun 05, 2010
How do i check my hydaulic fluid for my 445 tractor
JD Mower Maintenance - YouTube
? 16:56
https://www.youtube.com/watch?v=RYeP_QLhsoU
Mar 31, 2013 - Uploaded by GreenMachine757
Doing routine maintenance on my John Deere 757 zero turnmower. ... DIY Mower Seat Repair - Garden Tractor Seat - Zero Turn - eXmark ...
John Deere Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages6/
Service Transmission - John Deere Ag - New Equipmentmanuals.deere.com/cceomview/OMM144042.../OMM144042_D010.ht...DO NOT mix oils. These tractors are equipped with a hydraulic wet disc PTO clutch.... DO NOT use type "F" automatic transmission fluid. John Deere Low ...JD 445 Rider Mower Issues - Need Help Please - GardenWebforums2.gardenweb.com > Garden Forums > TractorsNov 12, 2009 - But I've read a lot of threads hoping to read about my issues, and was ...What tools I don't have my friends do, and both are real mechanics, big Deere fans ....it steer hard due to lack of fluid in the hydraulic steering cylinder. ... You may need to add fluid, run the tractor around a bit, and then check it again.
Jan 09, 2016 | John Deere Garden
445 john deere-temp gauge flutuates between hot and normal
Try replacing thermostat.might have trash in it causing it to stick on occassion.
May 18, 2014 | John Deere Garden
John Deere 445 Kawasaki engine Tractor shut down while mowing. Completely dead. No lights, nothing lights up when you turn the key.
check wires and cables for any wearing where they may have rubbed together or got pinched. Kind of sounds like its shorting out somewhere. I would start by removing your battery so it doesn't ruin the plates inside of it, if it hasn't already, unless you have removed it already....
I would start with that and if you can't find anything visually, hit me back and let me know what you all tried.
Good Luck Bud!
Aug 19, 2012 | Garden
John deer model 155c automatic keeps draining the battery dead each i go to use it put new same result
charge the battery unbolt the neg cable on the battery and place a test light between the cable and the battery and unplug fuses the switch and the engine harness one at a time til the light goes out if the diode for the charging system fails that will drain it as well a mouse chewing the wires cause problems as well
Jul 15, 2012 | John Deere Garden
John Deere 445. I would like someone who knows about this tractor answer the question as to why after replacing the camshaft why the motor backfires through the carb. If you read through all of my...
Of the 100+ camshaft replacements that I personly have done on the 425/445 and John Deere Gators I have come across 3 that backfired when completing the replacement.2 were do to bent valves coming in contact with the piston after gear failed and 1 was from a sheared flywheel key.The only other time I had this same injected engine backfire was on a John Deere gator 620i that had a faulty computer and fired @ 90 derees off.Do a compresion check and that will help out alot.
Aug 06, 2010 | John Deere Garden
JD Model 445 - Plastic gears. After replacing the new camshaft I need to adjust the valves. Does anyone have the specifications?
Remove the plugs. Turn the engine so the pistion is at top dead center for cylinder. Clearance should 0.010 when adjusting rocker to valve. Repeat for other side. I just replaced my cam shaft if a 1993 JD445. I'm planning to run for a couple of hours then check cleanace again. Hope this helps, Gerry
Jul 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
2001 john deere 445 will not charge any common problems? How do you test the voltage regulator?
Voltage regulators will keep the voltage at around 13.5 to 14 volts with the vehicle running. This is what keeps your battery charged while driving the vehicle. If is lower than battery voltage (usually around 12.3 to 12.8) then it is probably bad.
Jul 16, 2010 | John Deere 420,1020,2010,2020,2510,2520...
How can I tell the year of my John Deere 445 lawn tractor. Product # M00445C096237 ?
1993: 010001
1994: 020001
1995: 030001
1996: 040001
1997: 050001
1998: 060001
1999: 070001
2000: 080001
2001: 090001
http://www.tractordata.com/lawn-tractors/000/0/4/45-john-deere-445.html
Mar 10, 2010 | Garden
I have an eztrak john deere 445... quits.
The vent in your gas cap is plugged, it's a very small hole right in the center.
Mar 30, 2009 | John Deere 42 in. EZ Trak Bagger
Garden Logo
77 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
