Question about Google Gmail
Talk to a CSR
Gookle added a secomd sign in. Ptease remove it
  • Google Master
  • 1,214 Answers
I am of the opinion that Google themselves have to remove it.
kolbrun
Posted on Feb 26, 2012
How do I replace a stator on 1981 csr 250
using a standard flywheel puller remove flywheel then unscrew coils
Mar 01, 2015 | 1981 Power Source - 1983 Kawasaki KZ1000,...
Csr racing mods
What do you want to know?????
Dec 19, 2014 | Csr Motorcycles
APN settings for straight talk phone sm-s975l model
you must do a hard resset of your device .
aftr that you download hotspotshield or tigers vpn like apn from your p[lay store , hope your problem will solved regards
zeeshan
Oct 10, 2014 | Cell Phones
Oil capacity
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your CRS despair not for a mere $0 you can download another one. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
Best Scooter Oil Change Video
2005 Hyosung XRX 125 Moto ZombDrive COM
http://fullmanuals.com/brand/csr
Select your CSR model
CSR B09 50 2008
Jan 02, 2014 | 2008 Csr B09 50
No spark to engine CSR NKT1 / AJS NAC12
Hi I have a ajs nac 12 09 lost all power was having problems with barrel an thought that was the issue how Eva I replaced barrel now Evey thing works just can not get spark plugs leads are gd I am unsure how to test coil packs and cdi wiring is not my strong point if some one could talk me though it step by step at be very greatfull
I will leave my email address just incase Swinburne89999@gmail.com thanks guys
Sep 06, 2012 | 2011 AJS NAC12 125
How charge the battery?
Hi, Josepmanel the best way to charge a battery is slowly. I like to use this analogy, would you rather be awakened from a deep sleep with gentle nudging or a violent kick in the rear.
1. Remove battery and check for corroded or damaged terminals clean any dirt, corrosion or electrolyte that is on top of the battery as this will cause premature battery drain, inspect for cracks and swollen/expanded sides which are a sign of overheating and replacement should be seriously considered.
2. Acid plate type batteries should be checked with a hydrometer with recorded readings for each cell to be compared with after charging readings and for sulfation, the cell will appear milky, and incorrect acid level. Fill low levels with distilled water to upper level and remove acid from over filled cells with hydrometer until the level is at upper mark and dispose of acid in the sink mixed with a quart/litre of water.
3. Connect a voltmeter set on the DC scale to the battery and record the reading for comparison after charging.
4. Attach a drain hose that is not pinched, kinked, or plugged to the nipple on acid plate type batteries and let the other end hang into a plastic or styrofoam cup.
5. Connect a 1-2 amp trickle charger that has automatic charge rate reduction if possible and let charge for 24 hours.
6. After charging recheck each cell with a hydrometer a 100% fully charged cell will have a specific gravity reading of 1.270-1.280 and 1.180-1.190 has only a 25% charge battery should be load tested and considered for replacement if necessary. Reconnect your voltmeter and
any readings in the 10-volt range means you have a dead cell and the battery needs to be replaced. Readings between any 2 cells of 50 points or more indicate the battery has failed and needs to be replaced.
7. No maintenance AGM or GEL batteries need to have a voltmeter reading of 12.8-13 volts for a full 100% charge and 12.2 volts is only a 25% charge and should be load tested and replaced if necessary.
For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have nice a day.
Motorcycle Repair How to check the Regulated Charging Voltage on 2009...
How to charge scooter battery Yamaha Vino 125 Battery Tender Jr HD CSR Ona 2009 service manual DOWNLOAD FREE FULLMANUALS COM
2009 CSR Ona specifications and pictures
Sep 11, 2011 | 2009 Csr Ona
My pc is on but monitor is not . what i can do. ptease let me know. thank you
unplug pc cable if u get 'no signal' mesage th monitor k
else buy new monitor
Feb 11, 2011 | Dell Dimension 9100 PC Desktop
Changing from a crib to a toddler bed
1-Lower drop side to lower position. Then on the opposite side of the crib, remove stationary side. To remove stationary side, press the small tab on the end hardware(brown plastic piece that connects the rail to the frame) and then pull rail up.
2-Before reinstalling the conversion safety rail(csr), remove the mattress support bolt that is on the side the the csr opening will be(the foot of the bed). A new bolt will be used to reattach the mattress support in the next step.
3-Slide csr hardware onto the hardware on the crib ends. Insert two 1/4-20x2" bolts into each end. One bolt will replace the mattress support removed in step 2. Be sure to put the bolt back through the mattress support bracket before screwing into the end.
I have the instruction page with pictures if you would like a copy emailed.
jmsmith2003@msn.com
Sep 15, 2007 | Childesigns Carrollton Crib
Google Gmail Logo
18 people viewed this question
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
David Payne
David Payne
Colin Stickland
Colin Stickland
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
