Installing two hdd maxtor 80gb wd2500, installed win pro on 80gb went fine but keeps telling me that second hdd drive D needs to be formatted, but when i do, it tells me cannot format drive D
  • 749 Answers
You will need to use a disk utility to partition the drive first...
Partitioning and Formatting a Second drive in Windows 2000/XP
To partition and format new hard disk in a Windows XP
/2000 system, right click on 'my computer' and select 'manage.' Once you are in the management screen, select 'disk management'.
A screen showing your existing drives, including the new one, will appear. At this point Windows should open a wizard to help you partition and format your new drive. If it does not, right click the new drive in the lower pane and select 'initialize drive.'
Now you must partition the drive. To do this, right click on the new drive and select 'new partition' to launch the partition wizard. It will then prompt you for how much drive space you wish to allocate to the new partition. If you opt not to use the full amount of space for the first partition, you can create additional ones in the same way up to a maximum of four partitions per disk. You will then be asked for a drive letter which Windows will use to represent the partition you just created.
Note that if you are using the NTFS file system
on your main hard drive (the default with Windows 2000 and XP Professional) you will also have the option to mount your newly created partition as a directory in another volume. This adds the entire space of your new partition to that one directory, so any files placed in that directory will reside in the fresh partition but no new drive letter is created. Essentially you are using your new partition to expand the space available on another partition. Click no to this option (unless this is what you want to do).
Once you have chosen a drive letter or directory, you will be prompted to format the drive. Generally it's best to format with the NTFS file system at this point, unless the PC uses an earlier Windows operating system
like Windows 98. If that is the case, you will need to format the drive in FAT32 if Win98SE is to access to the data on the new hard drive. Once formatting is complete, your drive is ready for use.
Regards and Tahnk you for using Fixya.. Please rate!
Posted on Oct 28, 2008
Windows error recovery
the 160 gb hard disk that you are trying to connect have the os installed earlier on the same system tell us
Jan 26, 2013 | Dell Dimension 3000 PC Desktop
I have 2 hard disks, 80GB Maxtor & 500GB Hitchi. Both are SATA. Recently I found my system(Win 7) on 80GB was not able to boot. I tried repairing OS but failed. So I decided to install a separate...
Full format the harddrive with disk manager tool .Remove all partition recreate 5 to 6 times untill you are able to install windows.then reinstall windows sometimes virus problem corrupt the mbr record so if you recreate the partition it will work again.
Let me know if you need further assistance.
thanks for using FixYa.
Aug 09, 2011 | Hitachi Computers & Internet
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Windows Xp Setup Problem : "setup cannot access the disk". I have HDD: Maxtor Diamondmax Plus 9 80GB ATA/133 HDD.
try doing a F disk on the hard drive first then format it and make it the active drive and then try installing the xp software. if it has had another operating system say for instance windows ME it will not install on that drive without removing it. You can also go to www.maxtor.com and download their free hard drive tools to see if there is a problem that thier software can fix. the software is for free.
Jan 06, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
I have Intel 810e PIII 1 GHz 512 Mb Ram 20 GB HDD. OS Win ME I want to add secondary HDD. Which one should I preferr 80GB / 120GB / 160GB. and will install new OS say Win XP or linux in Secondary Hdd....
160gb - but ensure the bios is up to date and check the motherboard manual as that will or should explain about maximum capacity of hard drives but am sure it should be fine.
If it is not and does not detect all of it you can partition the partitions into smaller amounts ie 80 gb partitions each ?
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
Repeating Startup
U Will Have to Work in Safe Mode:
Press F8 Continuisly on Startup.
Go to Safe Mode:
Uninstall Unwanted Applications
Helped.Or Reformat;
Jan 09, 2009 | Microsoft Windows XP Home Edition
Hard drive
hi dear
use a cd booting
in command prompt c:\
type c:\fdisk /mbr
to fix your master boot record\
fdisk
and make your partiiton active.
after that installing your windows XP
oke
cropp
Mar 15, 2008 | Maxtor Hard Drive
OS installation problems
Hi, hi check your power supply, hard disks, cd drive, and memory FOR LONG BEEPS, ONE SHORT BEEP IN AN ENDLESS LOOP, BLUE SCREEN OF DEATH AT STARTUP Try using Memtest 86+ http://www.memtest86.com/ to diagnose your memory problem. You can also try the following methods. Turn off power, Unplug. Remove the cover of your PC. Remove the memory from the Motherboard. Note on the locks! Clean the memory contacts with an eraser yes that's right a rubber Pencil eraser. It should be shiny gold. Reseat your memory to the motherboard and Test! DIAGNOSTICS DOWNLOAD HIREN BOOT CD, WRITE IT TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 21, 2007 | Tyan Tomcat K8E Motherboard
Shrinked
This is the maxtor 4 installation utility: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=MaxBlast_4&vgnextoid=7add8b9c4a8ff010VgnVCM100000dd04090aRCRD Overview: MaxBlast 4 is a one-step, ATA/IDE hard drive installation utility. MaxBlast 4 makes hard drive installations and upgrades hassle-free for novices and professionals alike by automatically identifying, partitioning, and formatting any Maxtor ATA or SATA hard drive, making it data-ready in minutes. MaxBlast 4 replaces all previous versions of MaxBlast and MaxBlast Plus. Powermax 4.23: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=PowerMax_4.23&vgnextoid=a37d8b9c4a8ff010VgnVCM100000dd04090aRCRD Overview: The PowerMax utility is designed to perform diagnostic read/write verifications on Maxtor and Quantum hard drives. These tests will determine hard drive integrity. The PowerMax utility is effective on all ATA (IDE) hard drives with a capacity greater than or equal to 500 MB. Maxtor recommends the use of this utility for troubleshooting potential hard drive problems. These problems include, but are not limited to the following: * Potential hard drive surface problems (e.g., bad clusters, bad sectors, partitioning/formatting problems, etc.). * Drive recognition problems (e.g. hard drive that is not recognized by the operating system). * Software removal.
Mar 20, 2007 | Maxtor / 80GB / 7200 / 8MB / SATA-150 /...
Computers & Internet Logo
71 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
