Question about Blanco Plumbing
Leak at new strainer waste fitting
Fitting new strainer waste cant get it water tight
    Problem Solver:
  • 11 Answers
Did you put the rubber gasket and cardboard sleeve on the bottom of the sink(next to the nut and did you use plumbers putty on the top part of the sink under the top section of the basket. Hint if you put some soap on the gasket under the sink between it and the nut it will be easier to tighten also you must secure the top part of the basket as you turn the nut if not the plumbers putty will not seal. If you do not have the strainer basket holding tool wrench you can substitute with a pare of needle nose pliers. Large channel locks or pliers can work to turn the large nut on bottom. If you can recruit a helper to hold the top part of the strainer basket with the needle nose pliers it make the job of tightening the large nut easier. When a large amount of the plumbers putty has squeezed out and the strainer is flush with the sink you should have a tight seal.
Posted on Mar 01, 2012
2 Suggested Answers
SOURCE: We purchased a Silgranit sink
SILGRANIT II COORDINATED SINK WASTE DISPOSER STOPPER & STRAINER UNIT Fits disposer with 3-3/8" inside diameter only. It should just snap into the insinkerator sink flange.
Posted on Feb 17, 2011
Water is on the floor underneath the washer
have you checked the water fitting at both ends if they are dry and both tight look at the waste connection i would advise getting PTFE tape for screw fittings any diy store will have it just ask, but checking that all fittings are tightly done up and hoses aren't broken it might be seals inside the washer that might be worth getting someone to look at sorry cant be any more help.
Apr 09, 2012 | Whirlpool Duet GHW9150P Front Load Washer
The stopper on the waste strainer has disappeared and a replacement strainer is not readily available in UK. Is there a way of repairing the existing strainer as I cannot recall what the mechanism was...
Get a "FIT ALL" basket for now just to make it so you can use the sink, and most people will never see it . Order a new strainer that fits, They might send you just the one complete system
The thing that happend is your hoping to get everything done.. Dont let that upset you .
It will take a week or two. But you have a working sink and let Blanco worry. They will do what ever they need to.
I hope this works out for you Be safe and be happy,
Thanks for using our service
Tom
If you could take a second or two and rate us, this way we can better understand what we need to do better. thanks again
Sep 10, 2011 | Blanco Sink Waste Strainer / Stopper...
We purchased a Silgranit sink and the recommended stopper-strainer (model no. 441098). Our plumber says that this unit is designed to fit through the sink bowl and attach to a waste disposal system (ie....
Jan 17, 2011 | Blanco Sink Waste Strainer / Stopper...
I recently installed 2 Kohler bathroom sinks 16x19". One of them keeping leaking at the bottom of the sink where the 1 and 1/4" pipe connects. I did not put plumbers putty in as instructed. It leaked, so I...
remove the waste fitting and clean off all the putty. Using a clear or white silicon put some under the waste fitting collar then insert it into the basin hole. Next put the washer and nut on and wind it up to about 1/2" from the basin. Using the silicon again put plenty on between the washer and basin ensuring complete coverage of the waste circumference. Hand tighten the nut until silicon pushes out from the sides of the joint. Finally tighten about 1/2 turn using water pump pliers.
Wipe off all excess silicon.
You can tighten a little more if the waste fitting is all metal but i'm guessing its plastic and it is possibly being overtightened.
Feb 22, 2010 | Kohler FANDANGO SELF-RIMMING LAVAVATORY...
How to attach the drain assembly, in a backwash
you could try a sealent from your local hardware store ask the people there tell them your situation and they will tell you what you need
Oct 29, 2009 | Moen 22174 Basket Strainer with Drain...
The part at the top of the dishwasher that spins around fell off during the wash cycle. How can I get it back on?
Hello
This is called the upper spray arm and there is a hole in the center of it that let's it slide on a shaft and then there is a cap that covers this shaft and helps hold it in place.
here is a web link that explains all of this and more ok so feel free to read all of it there is a lot of good information there
The sprayer arms seldom cause any trouble, but sometimes the spray holes in the arms become encrusted with detergent or minerals. When this happens, the holes must be cleaned out so that the arms will work efficiently. Remove the lower arm by twisting off the cap that holds it to the motor shaft. Wash it thoroughly with water and mild household detergent. Sharpen a lead pencil and break off the lead point. Use the tapered end of the pencil to **** out the holes. A wood manicure stick can also be used.
A clogged strainer can cause the dishwasher to flood or overfill. Clean the strainer regularly, or after each load of dishes is washed.Do not use toothpicks, matches, or metal objects for this job. Lightweight wooden sticks could break off in the ports, causing blockage; metal could scrape and enlarge the ports. After cleaning, place the sprayer arm back on the motor shaft and twist the cap back on to hold it in place. Follow the same procedure to clean the upper sprayer arm.
Removing and Cleaning the Strainer
The strainer is located directly under the lower sprayer arm. When the strainer becomes clogged with food and detergent debris, the dishwasher may flood or overfill. On some dishwashers, the strainer is a plastic or metal component consisting of two semicircular halves. To remove this type of strainer, pry it up. On other dishwashers, the strainer is a one-piece component. To remove this type, remove the cap that holds the sprayer arm on its shaft. Then remove the sprayer arm and the strainer.
Wash the strainer in the kitchen sink with water and a mild household detergent. Use a fairly stiff brush to get all the debris out of the holes and slots in the strainer. Rinse the strainer well and replace it. If part of the strainer lifts out for regular cleaning, check it and clean it -- if necessary -- after each load of dishes is washed.
Troubleshooting Leaks
If the dishwasher leaks, and you know the problem is not related to tub overfilling, the pump, or inlet valve problems, the plumbing connections may be faulty. Most dishwashers are connected to the water supply with metal pipe fittings, and the leak could be at these fittings. If the fittings are threaded, tighten them with an adjustable wrench. If this doesn't work, chances are the threads are stripped or the fitting is cracked or otherwise damaged. In this case, replace the fitting.
Most dishwashers discharge used water through a pipe or a hose connected to the drain or garbage disposer under the kitchen sink. If the drain line is made of flexible hosing, it may have cracked from prolonged exposure to hot water. Examine the hose; if it's damaged, replace it. If the hose is leaking at its connections with the disposer or dishwasher, tighten the fittings or clamps at the connections, or replace the clamps. Also check for water leaks around inlet valves, drain valves, and anywhere you see flexible hoses and hose connections. Leaks at clamps can be stopped by tightening or replacing the clamps. Leaks in hoses can be eliminated by replacing the hoses.
Sep 16, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Bath waste
! goes over the threaded piece that screws into the piece that goes under the tub...and the other goes between the tub and the waste assembly thereby creating a sandwich with one on top and one underneath the tub....then screw the piece down tight through the tub and into the waste assembly and your good to go.....
Good luck and thanks for rating my effort.....the Fang.
Mar 25, 2009 | Lefroy Brooks BATH WASTE KIT - LB1370-ST -...
I need a new franke sink basket strainer for my franke sink model PRX11021 - stainless steel. What is the model number that will fit this sink and can I order it online or go to a local store?
You should purchase a complete basket strainer assembly. Home Depot or Lowes have some very nice ones. They are a standard size.
Tell them it's for your kitchen sink.
Jan 28, 2009 | Plumbing
Plumbing Logo
529 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
