Question about Life Fitness 9500HR Next Generation Remanufactured Treadmill
Notifi maintenance waxer needs refill - Life Fitness 9500HR Next Generation Remanufactured Treadmill
2 Suggested Answers
gymtech
  • 18 Answers
SOURCE: treadmill wont run its saying waxer empty and
Does this treadmill have a wax system ? If it does it will have side access panels on the side just above the rear leveler. The picture that shows here does not but need to be sure it does not really need wax.
If it does not have a waxer- enter maintenance settings on display console,I do not have one in front of me but I believe you hold pause button down and press clear twice. This should bring up maintenance settings.
Scroll using up down arrow untill you see replace wax bag or something to that effect. select [enter ] to save. press clear clear to restart.
Posted on Feb 07, 2010
How to use random orbital waxer/polisher from turtle wax model 65003tw
I am a professional detailer with 15 years experience. Place a small mount of polish or wax on the bonet of your machine and sork it into the paint until it hazes over. You can then either use a microfiber towel to hand buff the residue off or you can change to a clean bonet to buff off with the machine. You do not need a lot of pressure with the polisher, let the weight of the machine do the work.
Sep 21, 2013 | Vehicle Parts & Accessories
My hp officejet 4500 printer won't recognize a costco refill ink
hp notify I am hp tech engineer , you should not use refill ink
Mar 24, 2013 | HP Photosmart C4580 All-in-One InkJet...
I can't reset a fault named "wax empty" and my equipment doesn't work life fitness 9100
hit the stop button and hold down pouse key until the counsel repowers up and tougle throug to mantinace enter then tagel throug to waxer refill and hit enter
Aug 13, 2010 | Life Fitness 9100 Next Generation...
I have a life fitness treadmill and put new wax in the blader how do i start the machine and put wax on the belt?
you will need to go into service menu by pressing and holding the pause button then pressing the clear button twice , continue holding the pause until the service menu appears. then use the arrow up and select maintenance press enter then either use arrow up or down scroll and say refill waxer system or replacing wax bag press enter, this will reset upper console. Upon completion of this the go back into the diagnostic menu select system test press enter scroll up or down to waxer manual mode hit quick start and that will fire up the wax pump and your done
Apr 12, 2010 | Life Fitness 9100 Next Generation...
Treadmill wont run its saying waxer empty and notify maintainence
Feb 07, 2010 | Life Fitness 95Ti Remanufactured Treadmill
What is the check gauges light
CHECK GAGES light (1) indicates a potential engine failure(low oil pressure, low coolant, coolant overheating) has occurred.
· Check gages and shut down engine. Gages should read as follows: Oil pressure 5 to 10 psi (34 to 69 kPa) at idle; Water Temp gage below 230 degrees (110 C).
· Check engine oil level (Para 2-11) if OIL PRESS gage indicates low reading. Check coolant level (Para 2-11) if Water Temp gage indicates high reading. Notify Unit Maintenance if levels are low.
If CHECK ENGINE light (2) is on, check engine oil pressure gage (3) and water temperature gage (4). If both indicate normal, proceed with mission and then notify Unit Maintenance. If either one does not indicate normal, stop engine immediately and notify Unit Maintenance
Oct 16, 2009 | 1999 GMC Jimmy
The printer is showing ready maintenance on the screen
The printer keeps track of how many pages you have printer and will notify you when you need to install a maintenance kit and perform a maintenance reset. You can order a kit here and there is a video on how to install and perform the reset.
http://www.fastprinters.com/dell-fusers-maintenance-kits.asp#W5300
Mar 17, 2009 | Dell W5300N Laser Printer
Refilled cartridge problem
There's some kind of a chip chip in the catridge that notifies the printer that the same cartridge has been refilled. to get around this check keep atleast 2 or 3 empty cartridges, refill and cycle them. That should do the trick!
Dec 02, 2008 | Sharp UX-B750 Inkjet Fax
Life Fitness 9500HR Next Generation Remanufactured Treadmill Logo
127 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
