Question about Sony Cyber-Shot DSC-P52 Digital Camera
Dsc-P52 lens cover sticking
On switch on, with the selector on Still or Movie, the lens cover will not fully open and there is a rasping noise. The screen displays the current view with a message "Turn the power off and on again". Doing this doesn't correct the problem. On switch off the lens cover will not close.Switch on in view folders or set up mode , the lens cover closes and the functions work OK.
You need to go in and physically open the lens cover.
1. take out batteries 2. remove memory card + the small phillips screw.
3. remove the 3 remaining exterior screws. carefully with a small flat tip screwdriver pry the plastic halves slowly. eventually they will come apart. 4. at the bottom remove the small ribbon cable. 5. disconnect the mini motor wire, black and red. 6. unscrew the motor drive for the lens cover and then open the lens. 7. purchase a new lens cover motor. 8. If your screen still says turn off , then press menu and delete some files. good luck ! Work Slowly and carefully and ground your hands to a pipe somewhere before working on the unit. the static electricity could ruin the circuits !
Posted on Oct 06, 2012
SOURCE: DSC-P52 Memory?
There is no differance in the disc sandisk might be cheaper but go for a 1GB you will be glad you did
Posted on Apr 11, 2007
Lee123
  • 42 Answers
SOURCE: DSC P52 cybershot camera
I cannot provide the answer but i think it may have something to do with the shutter mechanism. When you dropped it, something inside the mechanism may have bent or stopped. Don't take the camera apart yourself, take it to a specialist such as an electronics store. I hope this helps. Good Luck!
Posted on Sep 11, 2007
t00nz
  • 4738 Answers
SOURCE: Sony DSC-P52
Take a picture with the camera and download it to your computer. If the picture also shows up black, then this sounds like it might be a defective CCD imager. If so, Sony should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/11/sony-konica-minolta-cameras.html
Applicable cameras include:
Cyber-shot DSC-F717, F88, P10, M1, P12, P2, P31, P32, P51, P52, P7, P71, P72, P8, P92, T1, T11, T3, T33, U10, U20, U30, U40, U50, U60, V1
CD Mavica MVC-CD250, CD400, CD500, and FD Mavica MVC-FD100, FD200
Posted on Jan 27, 2008
  • 62 Answers
SOURCE: cybershot DSC-P52
http://www.nodevice.com/user_manual/sony/cameras2/dsc-p52.html
This site will take you to a free download location for a PDF version of your user manual for this camera. On page 60 it gives details on how to set up the "special effects" for b&w picture taking.
In Summary:
1.Set the mode selector to the "Camera" icon.
2. Press "Menu"
3. Select [PFX] (P. Effect) with the horizontal arrows
4. Select the type of effect with the vertical arrows
5. To cancel the picture effect in #3, select "off"
I hope this helps!
Please rate my response if it was helpful to you, thank you!
OpenSource 13
Posted on Apr 07, 2009
SOURCE: DSC-P52 will only stay on for a few seconds
Then you need new batteries.
Automatic lens cover does not fully open
1. there's a problem inside of the camera especially the gear if the camera fell down or applying excessive force to the lens part. The gear was broken thats why it was not fully open and having weird noise inside.
2 if you went out to the beach or place a lot of dust.possible the sand or dust goes indide of the lens gear and cause of stuck up and not fully open the lens.sometimes becuase of this the gear was damage or broken and you need to bring to service center.
Jun 03, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
When I power on the lense cover only partially opens and will not close when I turn the camera off. Sony DSC-P52
The problem could be from simple dust accumulation to a camera drop. If you take it to the service center, it would be an easy fix, and won't cost you much.
Feb 14, 2010 | Sony Cyber-Shot DSC-P52 Digital Camera
Sony Cybershot DSC-P52: Lens Cover Failure
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it's something simple, a power-down reset may help. Turn the camera off, remove the battery, let the camera set for at least 30 minutes, then replace the battery and power up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may have a problem that requires professional repair.
Dec 18, 2009 | Cameras
Cybershot DSC-P52
In Summary:
2. Press "Menu"
I hope this helps!
OpenSource 13
Apr 07, 2009 | Sony Cyber-Shot DSC-P52 Digital Camera
Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Jul 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Sony DSC-P52 Lens Cover Problem
Is there a setting for the lens gear on the DSC-P52?
Jan 31, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
Cybershot 3.2 seems to work fine until you push button to take photo
when i turn the camera on it says turn the power of and on again and the lens cover will not open
Nov 25, 2007 | Sony Cyber-Shot DSC-P52 Digital Camera
Sep 11, 2007 | Sony Cybershot S650 Digital Camera
Shutter problem
sand in the mechanism? Or other kind of wearout... If the lens cover does not open completely due to some mechanical problem, the camera will not work (there are switches to detect cover full open and full closed). Probably needs some repair, cleaning or replacing the cover gears
Sep 15, 2005 | Sony Cyber-Shot DSC-P52 Digital Camera
Sony Cyber-Shot DSC-P52 Digital Camera Logo
101 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
